Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Easyshare 5300 I recently changed the cartridge and now the printer prints,however,the image is very light. I tried to re-calibrate, however, I am still getting very light printing. Thanks
  • 1,049 Answers
Check that you are not printing in "draft mode". If you are not, I would try cleaning the surfaces under the cartridges with a cotton swap and alcohol.
Posted on Jul 29, 2008
No magenta printing
Dirty mirrors will gives you dull color images..It seems color combination faulty..
chk original cartridges installed? or refilled cartridges?
Take supply status page..
chk colors..If color is dull(light) clean laser scanner assembly mirrors.
Do the color calibration..
chk drivers.,
Print from other file..
HP LaserJet 3030 Printing comes out light but copies are fine.
Have you calibrated your printer after changing ink cartridges?
Mar 19, 2014 | HP LaserJet 3030 All-in-One
My HP CM1312nfi laserjet has started to print a shadow behind all color text and images. The same day this started, the printer kept going into cooling mode as I attempted to finish a print job. I moved...
According to your problem first clean the toner cartridge by dry cotton carefully. May be the toner is almost finished or get damp few toner of the cartridge. Refill the toner cartridge. Then install the cartridge properly and reboot it. It will solve your problem.
Jul 25, 2011 | Office Equipment & Supplies
Printer not printing photos with all colors
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and that the cartridges are not damaged.
  3. Verify that the KODAK Ink Cartridges have not been refilled.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door.
  6. Check the printer status monitor on your computer (or the LCD screen on the printer) to determine if there is sufficient ink available for your print job.
  7. NOTE: Once the "Black ink cartridge is low" or "Color ink cartridge is low" message is displayed, print quality can be affected.
  8. Reprint the picture or document that had the quality problem
If still same quality then...
  1. Load inkjet paper into the paper tray.
  2. On the control panel, press Menu.
  3. Select Calibrate Printer.
  4. Select Print Calibration Page
  5. Press Start.
  6. When the print is complete, press Cancel to end the calibration process.
  7. Check the six color bars on the printed calibration sheet.
Are the color bars completely filled with solid color?
If no then:
  1. Press Menu.
  2. Select Clean Printhead, then press OK.
  3. Select Deep Clean, then press OK. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows steady, press OK.
  5. Select Calibrate Printer.
  6. Select Print Calibration Page
  7. Press Start.
  8. When the print is complete, press Cancel to end the calibration process.
  9. When the print is complete, press Cancel to end the calibration process.
  10. Check the six color bars on the printed calibration sheet.
If again No...
then printhead needs replacement... call Technical Support to get it replaced
May 25, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
I changed the black cartridge in my hp 932c and now there is a faint double image of everything in black. I switched cartridges and still have the problem.
The Deskjet 932 has a sensor that allow the printer to perform an automatic calibration whenever a cartridge is changed. It should not be necessary to ever manually force a calibration, but if you want to you can do it from the front panel as follows:
1. Turn on the printer.
2. Press and hold in the power button.
3. While holding the power button in press and release the form feed button three times quickly.
4. Release the power button.
This will print a calibration page which will be scanned automatically as part of the process. The calibration may fail if the 78 cartridge is not properly printing yellow or the 45 is not printing properly. It may also fail if the sensor is fogged with aerosol. This can be resolved by cleaning the sensor with a damp q-tip. The sensor is located in a small black plastic box located in the lower right rear of the carriage.
Mar 01, 2010 | HP DeskJet 932c InkJet Printer
Iam having MFP 1522NF printer...In that while copying...right side of paper is coming light.
Hi Kaurrs,
I have a 1522nf myself.
Here are a few steps you can try to get this printer fixed
1) Try scanning to the computer to check if the problem is related to the scanner bulb or to the printing side of the unit, if you see the problem on the scan job we can tell tall problem is while capturing the image.
2) Print a supply status report to cjeck on the level of toner on the cartridge, you can print this directly from the physical unit : MAIN MENU>REPORTS>SUPPLY STATUS, if the toner level is low (less than 10 %) i would try replacing the cartridge
3) You can try running 3 calibrations in a row from Main Menu>System Setup>Print Quality> calibrate colors> calibrate now
4) Run 2 cleaning modes under the printer main menu>service>cleaning mode
If after doing this you still have problems you can contact me directly to :
Jan 12, 2010 | HP LaserJet M1522nf Multifunction Printer...
I have changed the cartridges in my printer nd it
This is an issue with the printhead of the printer. Please follow the below mentioned steps:
  1. Reseat the ink cartridges and the printhead of the printer. If you need help in doing so please go to the link
  2. After you are through with reseating the ink and the printhead, the printer would ask you to go through a calibration and the light on the printer would begin to flash.
  3. To calibrate the printer, put paper in the paper tray and press Start button on the printer. After you have printed the calibration, you will have to scan it so place it on the scanner glass and hit the start button.
  4. After calibrating the printer, try a deep clean by pressing the Cancel and Copy buttons at the same time for two seconds. Wait for a minute and the cleaning process would complete.
  5. Try printing a Demo sheet by pressing Copy and Cancel button.
If the problem still persists, you can get a free printhead replacement from Kodak.
Oct 06, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Try running a deep clean and after the clean, calibrate the printer. If that doesn't work, call kodak tech support, you may need a new printhead.
Sep 07, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Logo prints out blurry
It would more likely be the transfer belt then the fuser. Try doing the calibration 3 times in a row and see if that helps.
Press Select (Swoosh)
Use arrows to go to Print Quality
Use arrows to go to Calibrate Color
Use arrows to go to Calibrate Now
Press Select to Confirm Calibrate Now
Jul 28, 2008 | HP Color LaserJet 2600n Printer
If you could possibly manage to access the machine status menu and have it print to check the drum's life, fuser life, developer, etc.. pls refer. Kindly replace the toner cartridge accordingly use the menu settings when replacing any color if needed. Please print solid image or block in each color Cyan, Magenta, Yellow and Balck. Well see if what color causing the problem. Please let me know the print result it may be; washed out or too light, too bright or black, double image, or not clean. Don't hesistate to contact me again about the result.
Best regards,
Rosener Guyano
Jan 31, 2008 | HP Color LaserJet 3500 Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
