Question about Acer Aspire 5610 Notebook
Black screen hey i got this acer 5610z in the trash .. lol,,, and it powers up but no screen.. is it trash or can i fix it ?
  • Anonymous Mar 15, 2014
    Hey I put a new battery in and it still have a black screen and will not come on what I do now trash it
    Problem Solver:
  • 7 Answers
ACER PICTURE PROBLEM – MY SOLUTION
I had a similar problem, but I got a picture before it broke up and went off. The screen was backlit, but no video (screen was receiving some power).
The LCD needs a very stable voltage to work, this is provided through the LCD connector ribbon. In my case the ribbon was damaged and I replaced it.
I have had no problem since.
I discovered this through trial and error; I first changed my transformer power supply and then the video inverter card.
You may find the link below helpful as it contains articles that photographically show you how to open the laptop for repairs.
http://www.insidemylaptop.com/category/1-acer-laptops/
Hope this helps. (Please rate my advice)
Posted on Feb 23, 2009
    Genius:
  • Acer Master
  • 1,252 Answers
Check display on the monitor through the vga port of the laptop, if there is display then its the porblme of your screen
Posted on Oct 16, 2008
Acer Aspire 5610Z. Upgraded to Win 7. Screen resolution changes
Your laptop was not designed to run windows 7 or be compatible with it. It may run fine with windows 7 but issues might come up sooner or later like the one you're experiencing.
[EXPERIMENTAL]
Download both of these (as I don't know which one of thsese two your laptop needs). Keep mind that doing the following could render your system inoperable and use at own risk. When downloaded, extract ZIP , open desired folder and find SETUP or INSTALL program. Right click and choose properties, then navigate to compatibility mode, then select windows Vista from the menu. Then apply changes, ok and close window and attempt to start.
Acer Aspire 5610Z VGA Intel Driver Vista
Acer Aspire 5610Z VGA NVIDIA Driver Vista
May 27, 2010 | Acer Computers & Internet
My acer orbi cam is not working,i can fix this,can you give me some advice?thaks
no ur screwed j/k lol mines *** smethimes to what model is ur acer cause mine is 5610z
Mar 05, 2010 | Acer Aspire 5570-2758 Notebook
MY ACER 5610Z LAPTOP STARTS UP BUT WONT LOAD WINDOWS
WIth the limited fault description its a guess at best. you probably have a corrupted driver or hard disk fault. If you can try a replacement hard drive and reload OS you should get progress.
Sep 29, 2009 | Acer Aspire 5610-4648 Notebook
Acer aspire 5610z blank screen after power up...
Is it a black screen with a cursor?
turn on the monitor.
Jul 13, 2009 | Acer Aspire 5610-4648 Notebook
ACER ASPIRE 5610z BLACK SCREEN
You could have a defective screen - follow this to determine the fault.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 19, 2009 | Acer Aspire 6930-6771 Laptop
Fix Acer Aspire 5610z Laptop Screen
you need a new screen!!! www.computereworld.com I can fix this for $170 total, that is a new screen and the labor. submit a request on my site, or call me 662-549-2362
Jan 08, 2009 | Acer Aspire 5610-4648 Notebook
ACER SCREEN IS BLACK BUT CAN FAINTLY SEE LOG IN BOX
Sounds like the backlight for the LCD is dead, either the light itself or the power inverter. If you're not a tech, you should take it in for repair. If you are a tech, you can usually find replacement lamps and inverters on EBay. Hope this helps.
-kinerf
Dec 09, 2007 | Computers & Internet
Acer aspire 5610z
Hey Lizzygurl,
One thing I would recommend straight off is installing updated drivers for your laptop. It's quite simple to d.
Go to http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html?CFID=5315383&CFTOKEN=78274075
This is a driver guide for Acer laptops.
Select Notebook, and then Aspire 5610z. And then from the right hand list, find the appropriate driver. This should fix the issue.
If it still doesn't help, then I would suggest giving Acer a quick call on this issue since it's all internal.
-Chad
Dec 07, 2007 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5610 Notebook Logo
103 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
