Question about Panasonic Lumix DMC-FX01 Digital Camera
HELP! Took pictures and now they're not showing up
I have a panasonic lumix and have used this for two years now. Recently, I have take some pictures and now I can't find them! When I go to review the picture a black screen comes up. When I take out the memory card to check them out on the computer they're not there! It's showing a picture was taken on my camera-but no picture can be found! HELP!
    President:
  • 1,114 Answers
First do not panic! It is possible to recover your pictures if you take care. Take the card from the camera (powered off) and if it has a "write protect" tab then lock it now. Do not try and write anything to the card or you risk causing more problems.
You can either plug in you camera to the PC as it should appear as a “Removable Drive” or put the card in a card reader attached to your PC.
Next, if you are comfortable with using a PC then you can download a FREE utility that will recover your photos from the following link:
http://www.cgsecurity.org/wiki/PhotoRec
If you need something a little more "user friendly" then you will need to buy the software. If you search the web for photo recovery software you will find many.
One I have used successfully is RescuePro that used to be bundled with some Sandisk products. Now you can get it from the link below:
http://www.lc-tech.com/software/prwindetail.html.
You can try the demo to see what you can recover before buying.
Remember - Do NOT try & write anything back to the card until you can recover your pictures to your PC safely!
Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Jul 28, 2008
Screen flickers and pictures have lines across them on my lumix DMC-TZ3
The camera is probably damaged, this also happend to my DMC-TZ5 as well after a few (5-6) years of heavy use but without any visible damage, a repair is most likely more expensive than just buying one of the new lumix cameras which have also improved A LOT, so you wont be disappointed!
Apr 08, 2016 | Panasonic Lumix DMC-TZ3 Digital Camera
Does not show picture only thumbnail is displayed
this can happen with photos not taken with this camera.
If you copied them from PC or if you took these pictures with another camera using this memory card, this can happen.
Sep 12, 2011 | Panasonic Lumix DMC-FZ28 Digital Camera
Panasonic Lumix DMC-FS5 cant upload photos!!
Did your friend use the "safely remove hardware" function when removing your card from her computer? That could corrupt your card if she didn't. Try this...take your card to a store like Walmart that has a Kodak picture kiosk. They can usually read everything on a card. There, you can print the pics or even make a cd of them. Afterwards, format your card in your camera.
Dec 14, 2009 | Panasonic Lumix DMC-FS5 Digital Camera
Lumix FX12 LCD screen shows purple haze
raegag
wsd*g
jagskfsda
vwomcjcwkjksdfs;adjkfksjcvijsiarue45646514sd5v13sd4f86vaf21g623g4f861++-+sv+svgsfgsg+fgasvcsdgwg
the answer is 123456789654321456789654123 dota boysssssssssss
Jan 16, 2009 | Panasonic Lumix DMC-FX12 Digital Camera
Pictures gone
Did they show in the screen as you took them?  Try reading the card in a different device  - a card reader connected to the pc . Good luck
Oct 31, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
Panasonic Lumix DMC-LC1 Digital Camera Problem
Contact Panasonic - there is a widespread problem with CCDs in the last 3 or 4 years - keep pressing them for free repair as is your due with faulty goods, even outside the warranty period.
See the following link:-
Widespread CCD problems in consumer imaging productsCCD Sensor Problems in Consumer Imaging Products .... Given that the Leica DIGILUX 2 is a variant of Panasonic's Lumix DMC-LC1 design, it isn't surprising ...
www.imaging-resource.com/badccds.html - 51k - Cached - Similar pages
Nov 11, 2007 | Panasonic Lumix DMC-LC1 Digital Camera
Lumix pictures blurry
you might have accidently slowed your shutter speed in the settings
Oct 27, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Cannot erase images on Panasonic Lumix
Go to the menu and Select 'Format.' This will erase all the pictures from the memory card or internal memory so be careful.
Oct 14, 2007 | Panasonic Lumix DMC-LZ7 Digital Camera
Panasonic Lumix DMC-tz1
lens mechanism needs cleaning ( moisture ) and possible alignment ( jarred ) ; charge or replace batteries , before getting estimate ;
Jul 31, 2007 | Panasonic Lumix DMC-LC33 Digital Camera
Panasonic Lumix DMC-FX01 Digital Camera Logo
62 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
