Mike : ck the inlet to the ice head inside the freezer it will be frozen and need to be de iced .. then see if there is a trough instead of the tube for your model most have this upgrade and it prvents the ice build up at the point . ,, hope this helped mmm fed back pls ..
Dodge, I defrosted the inlet and the water tube is a trough instead of a plain tube. Still no ice though. The line running from the water inlet valve to the ice maker still has no water in it. So if the ice maker tells the valve to send water up to it, Im guessing the whole ice maker unit needs to be replaced. Unless there is a separate solenoid somewhere that does that?
Thanks,
Mike
mike if you take a jumper wire in insert in into the (T) & ( H ) terminals holes on the icemker heat it will advance the motor / pull the wire after its moved about 1/3 of the rev . this will start the harvest cycle and just as it complete's the cycle it will call for water . and if no water the head is bad .. the valve that lets the water in is the dual valve / and on filter models it does go through the filter . ( but filters don't stop the water .) you may want to try filling the ice tray with 8 oz of water . and when it freezes the thermo in the head will call for the harvest and it it does not then the head may be bad . and the freezer must be 15 deg or colder 5 deg is best to cycle the icemker . if too warm 15 deg to warmer it will not make ice , mm hope these help . feed back pls ..
Well ice maker is shot I guess. When I put the jumper wire into T
Not sure why it cut off. But when I put the jumper into T
Not sure why it cut off. But when I put the jumper into (T)
Motor did nothing.
as is the=> D7824706Q Ice Maker Module Whirlpool now owns Amana, Maytag, Jenn-Air and Samsung will not let me post their manuals to the public. I can answer your questions as need so If you need more answers or diagrams or photos Click Here=> Sea Breeze If you have any questions please ask, Thanks, Sea Breeze
Amana DRS2660BW Wiring Diagram
Amana DRS2660BW Ice Maker Parts Breakdown
Ok, I defrosted the inlet and the water tube is a trough instead of a plain tube. Still no ice, its still not sending the water from the inlet water valve up to the ice maker. So if the ice maker tells the valve when to send water Im guessing it would be bad or is there a different solenoid that tells the valve to send water to the ice maker?
Thanks,
Mike
Well Id say the ice maker itself is shot. Wouldn't even rotate the motor when I put the wire into T
