Question about Dryers
Hi, my gas dryer heats up when I first turn it on for a short time, but, once the heat goes off it does not go back on.
Replaced gas valve solenoid kit. the kit just has two solenoids up front take out the two screws on the bottom of front cover and lift up and pull out cover. shut off gas and unplug dryer, there are two screws that hold on a plate that holds the solenoids on unplug the solenoids they just pull them up and replace them one at a time there is a two prong and three prong make sure they go back in the same spot as old ones
Posted on Jul 31, 2008
Dryer has heat for a short time and then the heat stops
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 26, 2011 | Kenmore Dryers
Heats up for short time then goes cold. Cleaned out dryer vent. removed front of dryer and cleaned out inside trap and blower between trap and exhaust
heatman101;
Aug 10, 2011 | Maytag MDG2706A Gas Dryer
My dryer heats up ok but after a short time it just blows cold air
heatman101][
Aug 03, 2011 | Dryers
Kenmore gas dryer no heat, have cleaned all components with shopvac and rags, still no heat, spins and all seems good, geta little warm once out of every 30 times i turn it on, any idea's?
heatman101';
Jul 03, 2011 | Kenmore 73102 Gas Dryer
My gas dryer will ignite and stay on with the flame for only a short period of time every time i start it it will light but withen a couple minutes it goes out.any help?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 11, 2011 | Roper RGX4634KQ Gas Dryer
Heat starts and runs for a short time than gas shuts off
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 27, 2010 | Roper RGX4634KQ Gas Dryer
Gas turns on ....link and ducts clean....gas only goes on for few seconds then turns off and few seconds later turns on again for short while...hummm
heatman101
Oct 12, 2010 | Kenmore 67082 Electric Dryer
The dryer wont get hot in hot mode. The back by the heating elements were very dirty, after cleaning them they came on for a very short time then went off, any ideas?
heatman101
Aug 29, 2010 | Zanussi TC7102W Electric Dryer
I have a Kenmore Dryer, Model # 110.64952300. It will start, heat, and turn for about 20 minutes. Then it blows the fuses in the fuse box, stops heating, but keeps turning. Can you help me figure out if it...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
I would check the heating element...it probably shorts out once it gets hot and then touches metal that shorts it out...
heatman101
Aug 20, 2010 | Dryers
Gas dryer not maintaining heat. 70 Series Kenmore/Whirlpool 76722
Fuse is ok . Problem is the soils on the burner valve . If the dryer heats when started , the electricity goes thru the coils to open the valve . Once the coils get warm , 1 will open (short) until it cools back down . The coils can be replaced just by removing the front panel . Only 2 screws hold the coils in place . No turning off gas , dissasembling dryer .
Jul 14, 2009 | Whirlpool Dryers
Dryers Logo
Top Dryers Experts
