Question about Sony Handycam DCR-TRV350 Digital Camcorder
Error Code C:31:23
Received code and tape case won't close any more
  • 10,594 Answers
Its mechanism problem calls Take-up Reel Sensor Problem. novoice can't repair it.
Posted on Jul 28, 2008
Tape stuck, Mechanically Eject
Try staring up the camera while hitting the rewind button
Oct 29, 2013 | Sony Handycam DCR-TRV520 Digital Camcorder
I have a Sony Handycam DCR-HC-48 and the tape door won't close along with a 32.11 error code.....HELP
Try these steps:
1. Open the tape cover fully until it clicks open.
2. Turn the camcorder on to "VCR Mode."
3. With the cover still open and the camera in "VCR mode," take out the battery.
4. Put the battery back in--out should pop your tape.
Keep us updated.
Jun 06, 2011 | Sony Handycam DCR-TRV140E Digital...
Washer says f26 and won`t spin the clothes out. is there anything i can do?
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Cancel twice.
The above procedure is the specified way by whirlpool technicians to clear the error code.
Feb 02, 2011 | Washing Machines
Door not open
Before doing anything the numbers on this code tell you to clean camera and heads.
After it should all be fine.
Jul 02, 2010 | Sony Handycam DCR-TRV280 Digital Camcorder
Error code 5110 canon MP830 all in one printer at first i had an error code 6A00 after cleaning the printer head and rdestarting my printer I then received an error code of 5110 my email is thank you
  1. Turn off the printer.
  2. Disconnect the power cable.
  3. Open the printer cover.
  4. Check for any orange protective tape or white polystyrene and remove if necessary.
  5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary.
  6. Close the cover.
  7. Reconnect and turn on.
for more help visit https://cbrtechsolutions.net or
CBR Tech Solutions
Dec 30, 2009 | Canon Office Equipment & Supplies
Keep getting 0E4 CODE ????? ON JVC MINI DV
In the case there is no DRUM FG input in the
drum rotation mode for 4 seconds or more. This
error is defined as [E04], and the mechanism
mode is shifted to STOP with the pinch roller
set off.
1. The drum cannot be started or drum rotation is stopped
because tape transport load is too high.
1) Tape tension is extremely high.
2) The tape is damaged or soiled with grease, etc.
2. The DRUM FG signal is not received by the syscon
CPU.
1) Disconnection in the middle of the signal line.
2) Failure of the DRUM FG pulse generator (hall element).
3. No drum control voltage is supplied to the MDA.
4. No power is supplied to the DRUM MDA.
Sep 08, 2009 | JVC GR-DVL520 Mini DV Camcorder
I have a Sony UVW 1800 Beta SP deck. This morning, after completing a dub, I rewound the tape. The machine made a sound, the tape stopped and became stuck in the machine. I received an error code 02-803. I...
check your tape deck unit throughly check for any physical damage of REWIND/FORWARD Gears.and FLY Wheel.
and dis locateion of some lever positions.
defnitly you get solved
Nov 13, 2008 | Sony Betacam SP Small Videocassette 30...
Sony error code
cheak batteries and the tape your using
Feb 03, 2008 | Sony Handycam DCR-DVD305 DVD Camcorder
Not ejecting
DRUM FG
set off.
CPU.
Dec 23, 2007 | JVC GR-AXM17U Camcorder
Sony Handycam DCR-TRV350 Digital Camcorder Logo
87 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
