Question about HP LaserJet 3030 All-In-One Printer
Re; HP LaserJet 3030 Fax -low memory problem
Hi ShineM,
Our HP Laserjet 3030 is not receiving any faxes. It will ring and then the machine's exclamation light will flash and the screen will say 'low memory hit enter',,,so when I hit enter nothing happens and the fax doesnt come through. I have tested it by getting people to fax us and they say that it doesnt go through. I have turned on and off, and cleared the memory. What should I do? Please help!
Thanks
Sabine
  • 1 more comment
  • Anonymous Apr 24, 2009
    unable to scan memory low hp laserjet 3030...help
  • shah_umang_a May 20, 2009
    WHEN SEND FAX MAMERY IS LOW MASSAGE COME.
  • Anonymous Mar 12, 2014
    I had trouble receiving a fax. It reprints this fax every time after shut down. I have tried clearing the faxes from the service menu and it still happens. When trying to fax out the machine reboots itself, then prints the partial bad fax again. There are no pending faxes. I tried to do it through the PC via the HP program, unit scanned the fax, but could not send it due to no memory. How do I clear the memory or this problem. Not sure if this is a memory problem or worse. The clearing the memory through the service panel says memory cleared "OK" but still the issue persits. Thanks.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Is this plugged directly into the wall by chance, or a power strip?
Posted on Aug 20, 2008
  • shirley Barker
    shirley Barker Oct 24, 2013
    Plugged into the wall.
I cannot print my document
Posted on Apr 08, 2010
Faxes can be sent from my HP LaserJet 3030 all in one, but aren't being received. I have a line splitter with voice messaging and 2 numbers
Try dialing your fax number from another telephone and listen to see if the fax machine picks up. Likely what's happening is that your voice messaging is picking up before the fax machine has a chance to. You can get around this by changing the delay before the fax machine answers.
May 03, 2011 | HP LaserJet 3380 All-In-One Printer
HP laserjet 1020 fax incoming fax, machine
hp laserjet is not a fax.It is only a printer.
Dec 09, 2009 | HP LaserJet 1020 Printer
Unable to receive fax from HP LaserJet 3050
Please make sure the machine is set for auto-receive in machine set up and make sure the phone cord is plugged into the line jack on the machine. If this machine is not on a dedicated phone line the machine (rings) should be set to pick up before the answering machine does.
Aug 28, 2009 | HP LaserJet 3050 All-In-One Printer
Hp laserjet 3030 fax
i have hp laserjet 3030. i cannot send or receive fax messages. i have checked with other machines as well. a beep sound is heard and there is no answer. my fax and phone lines are working fine.please help me as early as posible.
Sep 27, 2008 | HP LaserJet 3030 All-In-One Printer
Sending fax error message "low memory"
Try reading these:
General fax problems
Issue Cause Solution The document stops feeding in the middle of faxing. The maximum length of a page that can be loaded is 381 mm (15 inches). Faxing of a longer page stops at 381 mm (15 inches). If no jam exists and less than one minute has elapsed, wait a moment before press Cancel . If a jam exists, remove the media. If the item is too small, it can jam inside the automatic document feeder (ADF).
(HP LaserJet 3015 all-in-one) The minimum paper size for the ADF is 74 x 105 mm (2.9 x 4 inches).
(HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one) The minimum page size for the ADF is 127 x 127 mm (5 x 5 inches). If a jam exists, remove the media. The fax activity logs or fax call reports are printing at inappropriate times. The fax activity log or fax call reports settings are not correct. Print a configuration report and check when the reports print. Set the appropriate log or report printing times through the control panel or the HP Toolbox. The volume for sounds that the device emits is too loud or too soft. The volume setting needs to be adjusted. Set the appropriate sound volume settings through the control panel. Fax send troubleshooting Use the information in the following table to solve problems that might occur when sending faxes: Issue Cause Solution Faxes stop during sending. The fax machine to which the fax is being sent might be malfunctioning. Try sending to another fax machine. The telephone might not be working. Do one of the following:
  • Turn up the volume on the device, and then press Fax/Send on the control panel. If a dial tone is heard, the telephone line is working.
  • Disconnect the device from the jack in the wall, and then connect a telephone to the jack. Try to make a telephone call to make sure that the telephone line is working.
A communication error might be interrupting the fax job. Change the redial-on-communication-error setting to On.
See the electronic User Guide on the CD-ROM that shipped with the product. The device is receiving faxes but is not sending them. If the device is on a PBX system, the PBX system might be generating a dial tone that the device cannot detect. Disable the detect-dial-tone setting.
See the electronic User Guide on the CD-ROM that shipped with the product. A poor telephone connection might exist. Try again later. The fax machine to which the unit is sending to might be malfunctioning. Try sending to another fax machine. The telephone line might not be working. Do one of the following:
Outgoing fax calls continue to be dialed. The device automatically redials a fax number if the redial options are set to On. Press Cancel to stop the redials while the device is dialing.
To cancel a pending fax job, see "Canceling a fax job" in the electronic Users' Guide on the product CD-ROM.
See "Changing the redial settings" in the electronic Users' Guide on the product CD-ROM. Faxes that are sent are not arriving at the receiving fax machine. The receiving fax machine might be off or might have an error condition, such as being out of paper. Call the recipient to make sure that the fax machine is on and ready to receive faxes. The originals might be incorrectly loaded. Make sure that the original documents are correctly loaded into the automatic document feeder (ADF) input tray or flatbed scanner (not available with the HP LaserJet 3015 all-in-one). A fax might be in memory because it is waiting to redial a busy number, other jobs that are ahead of it are waiting to be sent, or the fax is set up for a delayed send. If a fax job is in memory for any of these reasons, an entry for the job appears in the fax log. Print a fax activity log and check the Status column for jobs that show a Pending designation. All of the numbers of a long fax number cannot be dialed. The maximum number of digits of characters that can be entered into a fax number is 50. Try manually dialing the fax number. Faxes that are sent include a block of gray shading at the end of each page. The original may be on the flatbed scanner (HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one only), with the glass-fax size set incorrectly. Make sure the setting is correct. See "Changing the default glass-size setting" in the electronic Users' Guide on the product CD-ROM. Faxes that are sent have data missing from the end of each page. The original may be on the flatbed scanner (HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one only), with the glass-fax size set incorrectly. Make sure the setting is correct. See "Changing the default glass-size setting" in the electronic Users' Guide on the product CD-ROM.
Jul 16, 2008 | HP LaserJet 3030 All-In-One Printer
Not receiving faxes
Any electrical disruption, interruption,disconnection can and will reset machine.
If you have ANY KIND of telephone answering machine BEFORE the hp3030, then you have to tell (or command) the answering machine to pick up in 2 or 3 rings. Tell the hp3030 to pick in 4 to 5 rings. I am sure that you know that a fax has a different signal then a regular "talking" signal. If both try to pick up at the same time, u confuse the ' poor little thing '.
Also:: take a look at all the wires going to the fax, telephone, answering and the wall output. Look for bent,cringed,cramped,twisted wires and replace if necessary. They will cause problems.
Mar 27, 2008 | HP LaserJet 3030 All-In-One Printer
HP Laserjet 3030 printer/scanner/fax Language has
How can i change HP laser jet 3030 printer's language?
Mar 17, 2008 | HP LaserJet 3030 All-In-One Printer
Hp laserjet 3030
do a factory reset.
careful it will delete all your saved phone number, and settings.
you might think printing a configuration page before doing so...
Jan 14, 2008 | HP LaserJet 3030 All-In-One Printer
HP LaserJet 3030 All-In-One Printer Logo
1,364 people viewed this question
Seeker5211
Seeker5211
