Question about GE JE1860 Microwave Oven
GE Microwave - Power Cord Appears to be Dead
I have a GE microwave in which the power cord appears to be dead. We tried plugging the GE microwave into another outlet & it still doesn't work. Is it worth it to get the power cord fixed/replaced or should I just buy a new one? Also, does the magnetron tube affect the power cord at all?
  • 116 Answers
Most microwave ovens are equipped with an internal fuse. This is typically located where the power cord enters the cabinet. The cabinet will have to be opened to verify the fuse.
The magnetron is not directly attached to the power source, it has to be stepped up in voltage significantly, either through a transformer or inverter.
It is usually best to have professional tech check the fuse for operation. Most shops will do this for a small fee if you drop the unit off yourself.
Posted on Jul 28, 2008
Will not turn on . Appears as though there's no power.
I'd try to unplug for a while. Could be a bad power cord for the microwave itself. I recently had a toaster problem. Bad wire right at the departure from the plug.
May 12, 2015 | Sharp R-930AK Convection/Microwave Oven
The control panel of microwave dead. No lights on the panel. There is power to the outlet
If it worked after unplugging and reinserting, it is possible that there is a wiring problem with the plug and wiggling the wires "re-made" a connection. Try plugging in to another outlet to eliminate a dodgy outlet problem.
Mar 26, 2015 | GE Microwave Ovens
No power
yes there is an internal fuse connected to the cord inside of the cover.normally at the connection of the cord.
Nov 08, 2013 | General Electric PVM1870SMSS Microwave...
Hi! Our GE Spacemaker microwave (JVM241BL) stopped working..... nothing on it works at all. We have checked the breaker box in the basement and made sure it is plugged in. We are assuming it is a fuse...
Turn off the power before starting this process. If the oven is dead, the fuse is probably blown. Remove the two screws that hold the touch pad and control board in place to access the fuse. Once inside, look towards the back and follow the power cord that enters the rear of the microwave to the fuse. It should be a 15 amp ceramic fuse.
Dec 04, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
The oven is totally dead. No light, fan etc. Replaced fuse internally, found no current at the fuse. Outlet has 120 v. Oven was run empty prior to going dead! Any thoughts?
check power between power cord connection and inernal fuse,start at cord connection and work way to fuse conn.eliminating possibe problem area
Oct 11, 2010 | Maytag MMV5000 Microwave Oven
Have a GE model JVm1650bh05 Microwave. I put in
Check the fuse in the bottom of the oven ... near where the power cord enters.
Oct 19, 2009 | GE JVM1630 Microwave Oven
GE Sensor Microwave JES1855 died
Mine went dead after about 6 months. I had problems with my breakers and I found out that it was the microwave that blew all of them. I also found out that this perticular microwave is a fire hazard and should be recalled. It has caused me alot of headache. The breakers in my house are brand new and they are put out by GE also. It caused me to loose the food in my freezer, I did not know my freezer had lost power. It would cause my entire lights to go off and then they would come back on. I have checked around and I found out that the power cord on the back of the unit is very loose. I had a person to come in and look at it, he thinks its the power cord.
Feb 20, 2009 | GE JES1855 Microwave Oven
Ge spacemaker jvm1533 is dead wont turn on
check the circuit breaker first it may be the fuse is blown The fuse may be located behind the grille following the power cord on the rside of the unit.
it may be a bad thermal fuse or oven thermostat.
Dec 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My RV unit got a power surge and the microwave looks dead.
Yes they have fuses, I am positive it's your fuse, take all 5 screw's off and you'll see it at the back on the right hand side were the ac cord goes in.
Jan 19, 2008 | GE JVM1440 Microwave Oven
GE JE1860 Microwave Oven Logo
252 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
