Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
The water does not shut off when tub is full, it just keeps filling and overflows.
If it overflows from the tub then:
This can either be a fault in the fill sense tube( small tube connected to the bottom on the outer tub from the sensor at or near the top of the washer housing ) becoming blocked or broken or a fault with the sensor itself. This is inside of the machine and the lower cabinet will have to be opened to see it.
There should be two screws along the lower front edge of the washer cabinet. Remove these and the front of the cabinet will lift out towards you at a 45 degree angle an then unlatch. Unplug from power before opening the cabinet.
If it overfills from the drain hose:
then either the drain hose is too low and the water
siphons out before it reaches the maximum or there is a tight seal at
the drain hose to house drain port which will cause all the water to
siphon out.
Posted on Jul 28, 2008
SOURCE: washer overflowing from the tub
There's an air tube connected to the back of the water level switch, If that is kinked/pinched/crimped/disconnected or has a hole in it... the pressure switch will "think" there's no water in the tub and thus continue to fill it. Access your control panel and verify your air tube connection @ the level switch.
Posted on Aug 09, 2007
SOURCE: water continues filling and overflows
Our LG WM-2432H front load washer was overfilling. I got the service manual from LG on the web ( http://136.166.4.200/contents/Laundry/WM2432.htm )
and the most useful thing in that manual was a listing of special control codes that can be entered from the front panel, for example to turn on the drain pump.
I thought maybe the sensor switch was broken, but after disassembling the machine I discovered that the 3/16" ID rubber hose between the sensor switch and the bottom of the tub had shaken loose from its supports and through dragging on the back of the tub during spin cycles, had worn down and had a hole in it, allowing air pressure to leak.
After vacuuming up the shredded rubber, I replaced that tubing with a three foot length of 3/16" inside diameter fuel line purchased from a local Lowes store. I used some twist ties to secure it to the back of the washer housing so it would not drag on the drum. The washer now works fine.
You can do this whole repair by removing the back access panel, only four screws. Look for shredded rubber; the hose just slips off of the sensor and the tub connect points at both ends.
Posted on Mar 25, 2008
SOURCE: washer fills up only half way but water keeps trying to fill tub
That is because the water level switch get stuck when water level reaches that particular point.
The water level switch is activated either by a floater sensor or by a membrane sensor that detects water pressure/volume, depending on the model.
On washing machines it is usually a membrane switch, and that is faulty on your machine.
Posted on Feb 20, 2009
SOURCE: water doesn't stop filling tub and tub overflows
Hello,Sounds like a problem with either the inlet valve or the pressure switch, way to determine which on is while it is filling pull the plug..if water keeps filling it's the inlet valve..if it stops filling it's the pressure switch..If you have any other questions or concerns please feel free to comment again..good luck!! Mike
Posted on Aug 31, 2009
Aug 05, 2014 | Kenmore Washing Machines
Jan 07, 2011 | Maytag PAV2300 Top Load Washer
Oct 03, 2010 | GE WJRR4170E Top Load Washer
Jan 30, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Jan 04, 2010 | GE WVSR1060A Top Load Washer
Aug 31, 2009 | Washing Machines
Aug 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Aug 10, 2009 | Kenmore Washing Machines
Feb 22, 2009 | Kenmore 24032\24036 Top Load Washer
Oct 22, 2007 | GE Hotpoint Super 3.2 cu. ft. Washer
252 people viewed this question
