Question about HP Compaq nx9600 Notebook
Keyboard random characters are left out when I type on the keyboard. this happened after the computer overheated and shut down.
  • Anonymous Apr 26, 2009
    I have the same problem, never can find a fix however i notice that sometimes it works perfect after a reboot.
Happened to me too - ended up needing a new keyboard, which I bought but then totally broke the pin when I replaced. So now I just use an external keyboard. You can probably get it to work with a replacement notebook keyboard, but be REALLY careful when swapping it out!
Posted on Apr 30, 2009
When im typing on my keyboard it shutsdown my computer. For Example: I press the enter key and all the open programs close and the computer just shuts down. then im typing in an adress bar and get done...
It can be virus problem. Try to go in 'Safe mode with networking' (press few times F8 when computer start to get menu options). Download ESET (Nod32) Online Scanner:
http://go.eset.com/us/online-scanner
Scan your computer with repair option on.
After that update your Windows. If you can't do that from Microsoft, you can use AutoPatcher.exe utility:
http://www.autopatcher.com/downloads/
I don't think it is keyboard problem.
You have free AVG good antivirus for homeusers.
Aug 25, 2011 | Computers & Internet
Hi, my acer aspire 4930's keyboard not functioning correctly.. when i press letter "a" it appear as "A1" same as "Q" appears "Q1".. pls help me
Hi.
Try cleaning the keyboard with a clean, dry paintbrush just in case there is anything stuck under the keys. Once you have cleaned the keyboard try typing keys to see if it does the same thing. If the keys type as normal then you have resolved the problem.
If the keys still type other characters along with the letter then there is a strong possibility that the keyboard needs to be replaced.
This usually happens when something has been spilt on the keyboard causing it to type random characters or the characters directly above or below them.
Seeing as the keyboard is a laptop keyboard you can use a wireles/wired keyboard or you can use the on-screen keyboard if you can't get the keyboard to work.
If there is anything else please post back.
Good luck.
Jun 07, 2011 | Computers & Internet
The computer shuts down by itself repeatedly
You are on the right track. Probably overheating. Open the left side cover and check the system fan and the fan on the CPU for dust. You can clean it with a small brush or compressed air that is purchased in any electronics store or Walmart.
Mar 20, 2009 | HP 378248-001 keyboard for Compaq nc6110,...
Extra characters display when key pressed
Check the NumLock Key. If your keyboard isn't typing the correct characters, you may have the incorrect input language selected. Many laptops will convert most of the keyboard into a number pad if NumLock is enabled. Press Num Lock + Function or Function then NumLock to make sure its disabled.
Cheers!
J the Guru
Aug 12, 2017 | Microsoft Visual FoxPro Professional...
Emachines Keyboard Model No. KB0511
Here you go:
Enter
The computer brings the cursor to the beginning of the next line. This key can also be pressed
to open a program after you have HILIGHTED* it. It will execute a command.
Shift ▲ Hold the shift key down and press the letter key you want to make a CAPITAL letter.
This key is also used to type the charters at the
top of some keys. Eg: Shift + 1 = ! or Shift + 2 = @
Caps Lock
Makes all letters CAPITAL letters. When the Caps Lock key is pushed, a light will
show up on the upper right corner of your keyboard
next to the capital “A”. When caps lock is turned on it remains on until you press the Caps Lock key
again. When you press the Shift key when
Caps Lock is on, a lower case letter will be produced.
Space This key places one space every time it is pressed. (The long, unlabeled key at the
bottom center of your keyboard).
←Backspace Deletes the character to the left of the cursor each time you press it. (If you hold it
down it will continue to delete so be careful).
Delete Deletes the character to the right of the cursor each time you press it.
Home Brings you to the beginning of the line the cursor is on.
End Brings you to the end of the line the cursor is on.
Esc Located in the upper right corner of your keyboard. Cancels an incomplete command;
it will also close an open menu.
Moves the cursor to the left one space each time it is pushed; does not delete the
character.
Moves the cursor up one line each time it is pushed; does not delete the character.
Moves the cursor to the right one space each time it is pushed; does not delete the
character.
Moves the cursor down one line each time it is pushed; does not delete the character.
Insert Deletes the character to the right of the cursor and replaces it with whatever is typed on
the keyboard.
↔Tab Moves the cursor to the tab marks and between columns.
Shift + print screen Prints what is on your computer screen.
Highlight (to select) To make the item stand out. To choose or select it.
? *When an icon is highlighted (left click the mouse button one time while the cursor is pointing at
the icon), the program has been chosen and the name of the icon will change color. When this has
happened, you may press the Enter key to open the program.
? *To highlight a character or characters, move the cursor, using your mouse or the arrow keys, to
the left of the item you wish to select. Press the left mouse button and hold it down while you
move the mouse to the right. Let go of the left mouse button and your item(s) should be
highlighted. Then you can choose what you want to do to the selected item(s) e.g. bold, underline,
delete, italicize, etc.
“Drag and drop” Move the cursor to the item, click the left mouse button and hold it down.
Move the mouse, while holding down the left
mouse button, to the location you want to move the item. Let go of the left
mouse button.
Cursor - The arrow on your screen. The mouse is used to move the cursor.
Let me know if this helped
Jan 02, 2009 | E-Machines eMachines Desktop PC
SNK VS. CAPCOM
Here are some random cheats I dug up.
Unlocking Extra Characters
Hold start and type at title screen.
Down, left, left, left, left, left, left, left, A Unlock Dan
Right, right, right, left, up, right, down, up, A Unlock Demitrii
Up, up, up, down, left, right, down, left Unlock Evil Iori
Left, left, left, down, left, up, right, up Unlock Geese
Down, down, down, right, down, left, left, left Unlock Goenitz
Up, down, right, right, right, up, down, left, left, down, A Unlock Mars Alien
Up, up, down, left, left, right, left, up, A Unlock Violent Ken
Up, right, right, left, left, down, up, up, up, A Unlock Zero
Hold down R1 trigger over any characters specified below to reveal the hidden characters on each
Hold R1 over Balrog Becomes Shin Gouki
Hold R1 over Chun-Li Becomes Demitri
Hold R1 over Dhalsim Becomes Dan
Hold R1 over Kasumi Becomes Shin Mr.Karate
Hold R1 over Kim Becomes Wild Iori
Hold R1 over Kyo Becomes Geese
Hold R1 over Ryo Becomes Goenitz
Hold R1 over Ryu Becomes Zero
Hold R1 over Terry Becomes Mars People
Hold R1 over Vega Becomes Violent Ken
Athena Beat 36 Characters in Survival Mode
Red Arremer Beat 36 Characters in Survival Mode
Dec 30, 2008 | Video Game Consoles & Games
Toshiba tecra s2 keyboard starts skipping typed characters and stalling
there may be a pressed key in your key board, but pls chcek the key board with keyboard tester free software to identify pressed keys.
pls remove the key board cap carefully and clean
Apr 29, 2017 | Toshiba Tecra S2 Notebook
Types wrong characters
If the typewriter is typing letters or symbols that you do not type, it is usually because the Pitch Selector is set to "PS". The pitch selector is on the left hand side and has the numbers 10,12, 15 and PS. Place the selector on 10 or 12 and you will be OK.
Also, check to make sure your printwheel is installed properly. Remove it and put it back in to make sure.
Another thing you can try is to clear the memory. To do this, turn off the machine. Place a piece of paper in the machine sideways. Hold down the MAR REL key and while holding it down, turn on the machine. Wait 2 seconds, then let go of the key. The typewriter will start typing. Shut the machine off after about 15 seconds. Then turn it on as usual. This will clear the typewriter's memory and unexpected charaters should not happen anymore.
Jay @ www.granadahillsbusinessmachines.com
Aug 20, 2007 | Swintec 7040 Typewriter
HP Compaq nx9600 Notebook Logo
75 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
