This will give much detailed that will earn to make it more achievable in creating with 3d interior software.
SOURCE: just made a floppy disk from quick font plus and now
1>Turn on machine
2>touch PROG (menu on top)
3>insert desired font disk
4>touch floppy icon
5>select font/font size
6>touch each letter consequtively until speeled (use "_" in menu for a space between words/names.
7>When done, touch REP (menu on top)
8> then start to sew by pressing start/stop
SOURCE: Have 3D software,Pfaff 2140 machine and Hus Designer Diamond mach
I have loaded the 4D software and have communication with my Husquvarna machine through that. I communicate with my Pfaff through the old 3D software on my computer.
SOURCE: husqvarna viking designer 2 embroidery machine. Wont work on my
Buy a PC, or get the program that mac has that supports pc programs. I've seen it work so I'm sure it's an optioin. Mac people don't like the program, but it will create an environment that supports PC programs.
SOURCE: Husqvarna Viking Designer I breaking needles
Dls8864's suggestion was a very good suggestion - make sure the metal stitch plate is pushed all the way to the back. Also make sure that the thread is feeding freely - if it is catching on something it can cause the needle to be pulled aside and make it break. Does the design fit properly inside the hoop you are using? If the foot and/or needle strike against the side of the hoop, that will cause a breakage. Is the bobbin thread okay - not making a bird's nest underneath?
SOURCE: unable to load 3d embroidery on hp windows 7
3D was intended to be used on XP and also worked for some time on Vista with the proper manipulation of updates. I don't believe that it will work at all on Windows 7.
4D does work on both Vista and Windows 7. It does need the latest update for Windows 7.
