Question about GE Washing Machines
Washing machine will not agitate or spin. Motor still runs.
  • 958 Answers
Could be a coupling of the motor to the mechanical gear box..
cheers,
drcool
Posted on Jul 28, 2008
Motor on wash cycle does not spim
??? wash cycle is not suppose to spin only agitate, most machine have a dual motor function, motor runs in 1 direction for wash then in another direction for spin. do u mean it does not go into spin? if so need to check the tranny and the clutch, the motor coupler in some cases and if its not agitating washing may have bad cam dogs in agitator, or bad water pressure switch, some times a bad door switch will not allow spin or agitation?
Sep 27, 2014 | Whirlpool Cabrio WTW6200VW 4.5 Cu. Ft. Top...
I have a kenmore model 20422991 washing machine it wont agitate spin or drain but i can here the motor running
Thanks for choosing FixYa and welcome. Your drive motor controls the spinning, agitation, and draining. Even though it is running, the transmission may be bad. Replace the motor drive if this is the case.
Apr 02, 2011 | Kenmore 22422 Top Load Washer
Fills with water..doesn't wash..drains and spins..does the transmission spin in direction and wash in the other? in other words does the motor run one direction to spin and rev. to agg/
Yes it does reverse. If the motor is running in agitate pull off the agitator and check the agitator drive (bell) (white plastic bell shaped) on top of the agitate shaft is not stripped. You should not be able to turn. To remove the agitator fill first about 8 in of hot water, drain and pull up on agitator with fingers under the bottom or a belt.
Nov 22, 2010 | Hotpoint -Ariston VVSR1030HWO Top Load...
Agitator does not work
Your motor runs in forward and reverse...the spin is one way and the agitate is the other... that direction has failed. Replace the motor...
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jul 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Tub doesn't spin during spin cycle; motor is running
does the unit agitate?
is it does and it will not spin then the transmission is bad.
if the unit does not spin or agitate then check the belt.all assuming that the motor is running.
Mar 14, 2010 | Westinghouse WWS833ES Super Capacity Top...
My matag washing machine will spin but not agitate
It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Feb 01, 2010 | Maytag Performa PAV3200
Won't agitate or spin
If you mean that when the unit should be agitating or spinning the motor is running, and you lift the lid causing the motor to stop running, it sounds like the coupler.
Mar 31, 2009 | Whirlpool LSR5132PQ Top Load Washer
GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
coupling between motor and drive assy broken. take motor loose and you can get it out. Visual check first to see if motor is running when in agitate cycle.
Dec 03, 2008 | GE WBSE2090A Top Load Washer
Does wash clothes
depending on what washer u have this could be a sign that your carbon brushes are on there last legs not much to replace them but need to know what make off washer it is hun peter
May 27, 2008 | Washing Machines
WASHING MACHINE
try it on wash and let me know if it agitates hold my rating till were through please
Jan 13, 2008 | Whirlpool LSB6300PW Top Load Washer
Washing Machines Logo
15 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
