Question about Motorola Mobility H500 Wireless Headset
I can't get my motorola h500 to work with my Sanyo Katana
It is paired, but when I am receiving calls it rings, but won't let me answer or make calls. Can someone help me?
I cant get my motorola h500 to work with my LG VENUS 8800
Posted on Sep 01, 2008
    Sergeant:
  • 359 Answers
Take headset back and get replacement. This is a common symptom when the headset has gone bad.
Posted on Aug 25, 2008
I have a new droid by motorola and an old h500 bluetooth headset. It still pairs beautifully with my old blackberry, but won't pair with the droid. HMMM? Any tricks? What am i doing wrong?
You need to put your H500 into "pairing mode" by pressing the call button until the light turns steady blue, instead of blinking. Your droid will then see it when you are in the Bluetooth Settings screen under Networks & Wireless. I just did this myself last night and it worked fine. Be forewarned, however, that you cannot voice-dial with your bluetooth - only answer calls. There are several forums out there that are bashing Motorola & Google for not having this basic functionality.
Dec 26, 2009 | Motorola Mobility H500 Wireless Headset
Pairing Motorola h500 With Sanyo 2700 ,the sanyo can't find the H500
Make sure the head set is also in pairing mode. and also make sure you haven't already paired it previously. if it still won't find it it is incompatible or defective
Dec 05, 2009 | Motorola Mobility H500 Headset
I can hear sounds that it's ringing and on--but no caller.
Is it in mute mode?
http://www.motorola.com/mdirect/demos/how2_h500/h500.html
Feb 25, 2009 | Motorola Mobility H500 Wireless Headset
H500 Sends Signal to Speaker Not Its Own Earpiece
hi sir
u better have to do the restore factory settings..
tolls> setting>phone setting>restore factory setting..or other option install.. it restart's but it work's.. thank u sir..
Sep 03, 2008 | Motorola Mobility H500 Wireless Headset
Communication problems with Motoroala H500
i have a h500 cannot pair with my phone lg env
Aug 01, 2008 | Motorola Mobility H500 Headset
Phone shutting down
Is the phone set on 'always visible'? I think on my LG Rumor, if you have visibility sest to hidden, the phone will not look for the bluetooth. Not sure if that's it or not, but wanted to mention it just in case that might be the problem.
Jan 18, 2008 | Motorola Mobility H500 Wireless Headset
Tapping the answer button does not answer the phone
I had the same issue until I realized that I was touching the button twice,- first answering the incoming call, then immediately hanging up!
When you first tap the button there is a slight delay and the incoming call seems to be still ringing but you've really already "answered" it. Just tap once, be patient a couple of seconds and say"Hello". Your caller will be there!
Dec 12, 2007 | Motorola Mobility H500 Wireless Headset
H500 won't pair with Blackberry Curve
It might already have been figured out but if you hold the answer button on the headset down until the light stays on steady, it is in pairing mode. You can then go to bluetooth setup on the Curve and it will find the headset.
Nov 08, 2007 | Motorola Mobility H500 Wireless Headset
HELP
You can't program numbers vocally to you headset, you can only program vocally to your phone only if your phone has the voice dialing option. I have a H500 and can inform you of what I know. To turn on, hold button until blue light flashes once or twice, to turn off is the same thing. To pair your headset with your phone you have to hold down the call button until the light stays on then you use your phone to pair. After pairing the headset will flash quickly then discontinue. If you are using your headset and receive another call, you press the call button on the phone to answer the other line and to also release the call. The volume up and down buttons are found on the top and bottom of the headset, up and down is dependant on which ear you wear your headset. To mute, hold both the volume up and down buttons at the same time, this also unmutes the call. Hope this helps!
Sep 08, 2007 | Motorola Mobility H500 Wireless Headset
Motorola Mobility H500 Wireless Headset Logo
48 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
