Question about Health & Beauty
Battery replacement How do I open my Remington MS3 1700 shaver to replace the battery? Thanks, Phil
  • burt1on Oct 30, 2008
    How do I open my Remington R-9190 shaver without breaking it to get the battery out.
  • Anonymous Mar 30, 2009
    I have the same problem with an remington ms5100
    Bob D.
  • 304 Answers
I have the .PDF file from remington for disassembling your shaver for you. Also this model is known for poor battery life and I recommend replacing the NiCd batteries with Lithium Ion batteries of the same size. This will give you much more shave time and 10 time the number of recharge cycles. Post me an E-mail address where you want me to sent the instructions to you or you can just E-mail me and request the instructions and I will attach the .PDF to my reply letter ( geokohler@gmail.com). If you enclose your number I will call you for free and walk you through the process.
I hope you find this information valuable. If you do please take the time to rate this a FixYa. If you ever need my help again post it here and I will be notified of your need for further assistance by E-mail. I do this for a hobby so there will never be a charge.
Sincerely
George
Posted on Jul 28, 2008
  • 1 more comment
  • George Kohler
    George Kohler Jul 29, 2008
    Hi, I sent your PDF file to you a minute ago. If you do not have the adobe reader you can download it free from adobe here:
    http://www.9-download.com/order/signup1b...
    Cut and paste this link in the address bar of your browser and fill in your info. Download and install the reader for free. You can fill it in with junk if you do not want to be contacted by adobe begging you to buy things down the road. Make sure the fake e-mail address follows the right format, like: 1@2.com Thats what I always do so my E-mail inbox is not full of trash. Do this for anything that asks you for your E-mail address except things that require you to actually respond to the e-mail to verify. In that case make up a throw away yahoo E-mail address. Just a nother free tip. Hope this helps you, If you need anything else feel free to ask as always,
    George
  • George Kohler
    George Kohler Aug 06, 2008
    Hey Phil, It magicly appeared in my ratings today. And so did a bunch of other mystery posts. Thanks for all your help getting them to look into the problem. I guess between the two of us I guess they finally checked into the problem. Thanks for all the help.
    George
    Ps. I wrote from here to confirm it id actually here now. Thanks again. If you ever need anything let me know.
  • James Crisp
    James Crisp Jun 03, 2014
    Yes I do have pdf and woul like to receive the info; crispfoc@gmail.com
Opening a remmington ms2 150 or ms2 300 razor to replace the batteries
You will find the correct battery type at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
To open the shaver you will need to gently pry off the rubberized grip on the front of the shaver. You can then access and remove two screws near the bottom. You will also need to loosen the flat metal clip plate at the top that is under the cutters. Once this is done, you can open the shaver and access the batteries
Jun 15, 2011 | Remington Health & Beauty
How do I find where the battery is located?
To open the shaver and access the batteries, you must start by gently prying off the rubberized grip on the front. Once removed, you can access and remove two screws at the bottom. Under the cutters is a metal plate/clip. Remove this clip and the front of shaver can be removed and batteries accessed,
You will find replacement batteries at shaveroutlet.com. See link below. You will need two
If this job is out of your capabilities, you might want to consider the replacement part linked below
http://shaveroutlet.com/shaver-replacement-parts/remington-ms2370-lower-unit-p-208.html
Jan 10, 2011 | Remington MS2-200 Electric Shaver
How do I get to the batteries ? I notice a seam down the middle but it will not open
First remove foil and cutter head. To open shaver, gently pry off the rubberized grip on the front. This reveals 2 screws at the bottom. Unhook the flay metal plate clip at the top that is under the cutters. You can then seperate the front and back of the shaver.
Oct 24, 2010 | Remington MS2-200 Electric Shaver
How to open remington ms3 1700 electric shaver to change battery and battery type??
Your shaver model is not designed to replace the batteries. To open it, you have to remove the side grips on oscillator housing which are glued on. Disassembling it will cause it to be all marred up.
shaveroutlet.com has an easy and inexpensive solution. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-ms31000-lower-unit-p-567.html
Oct 04, 2010 | Health & Beauty
Light come on the ms2 200, but it won't charge. I tried 2 different cords and nothing charges it. It sounds like when it starts dying out. Thanks
The batteries are dead. They will need to be replaced or replace the shaver. You will find the correct battery type at shaveroutlet.com using the link below
http://shaveroutlet.com/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
You may want to consider buying the replacement part linked below instead as it will not require the effort of replacing the batteries
http://shaveroutlet.com/remington-ms2370-lower-unit-p-208.html
Aug 10, 2010 | Remington MicroFlex R-TCT Electric Shaver
What batteries are in the reminton ms2 390?
They have Ni Cad Batteries.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 07, 2009 | Remington MS2-390 Electric Shaver
How to open for battery replacement
Found this link that may help you out. Seems like they are made to be used then tossed out. What a waste. Anyway the battery replacement issue is a common problem... http://k0lee.com/2008/04/replacing-remington-and-norelco-shaver-batteries/
May 25, 2009 | Remington R-9190 Electric Shaver
Health & Beauty Logo
1,597 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
