Question about Compaq Evo N610C Notebook
Can I install 1gb of ram on a compaq evo n610c
Can I put in two 512 sticks or would it not work?
  • msorgen3 Jul 28, 2008
    I went to ebay to buy them, but I see that it needs to know how many pins are required. I know it is a PC2100 DDR SDRAM SODIMM. Is it 200 pin, 168 pin, etc?
    Sergeant:
  • 313 Answers
Yes, Memory Upgrade for Compaq Evo N610C, the Compaq Evo N610C takes the PC2100 DDR SDRAM SODIMMs to a max of 1gig - and two 512 would be perfect.
The memory modules in a Compaq Evo N610C are not located where you expect them to be.
Here's how to do it.
Open the notebook, and place your fingers on the keyboard as if you were going to type. There is a panel directly beneath your left palm, just below the Ctrl and Alt keys. The panel is hooked into the front of the frame closest to you. Using a thin flathead screwdriver or knife blade, apply a bit of pressure on the panel so that you're pushing it towards the LCD while prying it up. The panel will come right off and you'll have direct access to the memory modules.
Posted on Jul 28, 2008
/thanks buddy,, u r the best!!!!!!!!!!
Posted on Sep 18, 2008
Compaq evo n610c 1gb ram is support for windows 7
Not at all!!
I've installed Windows7 in my n610c (with !gb ram) and my laptop is perfectly working.
Windows 7 is not the 'awful' Vista!!!
The most important things are W7 drivers for this laptop. In order to obtain these drivers, you've to download and install 7zip, then you've to expand in folders the exe files of audio ,video, etc.  drivers of windows xp, and let the system find the suitable drivers..
InstallingXP drivers (exe files) in W7  is not possible!
Also ram may be increased over 1Gb, but you've to install the O.S.
after having upgraded your ram, otherwise graphic card will be not working, even reinstallig its driver!!!
I've just made these operations in two Compaq evo n610c, successfully.
I'd  a problem only for Infrared port, but I've fixed it 'asking' system to find the driver into an external usb HDD full of drivers of various PCs. After a few time , also Infrared port driver was OK.
I've made a backup od windows7 drivers (you may use double driver(free) or Windriver Ghost (not free), in order to backup w7 drivers.
Regards
D.
Apr 18, 2010 | Compaq Evo N610C Notebook
How much memory can I put in this computer? It currently has 512 megs of ram
You can get 2 sticks of PC2700, 1GB each for a total of 2GB.
You can go to crucial.com to verify and make sure. You can select your computer or run their scanner to show you what you need.
Apr 16, 2010 | Compaq Evo D510 Minitower (Open Box)...
Upgrading memory on my Compaq Evo N400C notepad
i have the same Compaq Evo N400c its a ram under the keyboard check there to upgrade it i got Compaq Evo N400c 1gb ram
Dec 30, 2008 | Compaq Evo Notebook N400c
How much more memory can I install
This laptop can support up to a max of 1 GB of RAM , so if you buy 1 stick of 1 GB of RAM you need to take out the 768 MB and just put the 1 stick of 1 GB RAM, or your other option is to buy a 256 MB of RMA so your computer will still have a max of 1 GB of RAM and that would be cheaper and you can still use your old RMA on your laptop , this is the lin for the complete specs of your laptop http://www.dealtime.com/xPF-Compaq-Refurbished-COMPAQ-P4-M-1-8GHZ-256MB-30GB-14-1-TFT-CDRW-W-XP
Hope that helps...........
Sep 28, 2008 | Compaq Evo N610C Notebook
Can I install 1 gb ram into a compaq evo n610c
Yes u can Install 1 GB RAM and u can use any kind of
flathead screwdriver to remove the cover
http://www.edgetechcorp.com/memory/upgrade.asp?cid=25412
In this see the Installation Help it is having a video how to fix the Memory Module
Jul 28, 2008 | Compaq Evo N610C Notebook
Compaq Presario M2000 PC Notebook
The Bios on the laptop motherboard only will recognize a total of 1gig Ram. So the 256 stick would be removed and 2- 512 sticks installed.
May 22, 2008 | Compaq Presario M2000 Notebook
Blue Screen of death
According to this link, the memory of Compaq Evo N610c can be upgradable to 1024 mb.
http://h18000.www1.hp.com/products/quickspecs/11382_div/11382_div.HTML
Memory Upgrade for Compaq Evo N610C, the Compaq Evo N610C takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with of Memory. You can upgrade your Compaq Evo N610C to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with standard Memory installed. For best system performance use the maximum amount of allowed Memory per slot for your system. (Souce: http://www.memorystock.com/memory/CompaqEvoN610C.html)
So you have to install 512mb memory module on each slot to make up 1024mb of memory.
Did you install 512mb memory module on each slot or did you just install 1GB memory module in one slot?
Try to go back to 256mb RAM and see if you will have the same blue screen error. If you did not receive any blue screen, try to add memory into it or just insert 512mb first and then oserve again if you will have the blue screen error.
You may also want to go to these links for other suggestions.
http://www.pcfixreview.com/blog/2007/07/12/bad-pool-caller/
http://www.registrysimple.com/bad-pool-caller-fix.php
May 08, 2008 | Compaq Evo N610C Notebook
How to upgrade memory for compaq evo n610c?
The maximum amount of memory you can install is 1GB 266 Mhz SDRAM DDR SDRAM (512 -MB in slots 1 and 2)
The motherboard will not handle any amounts larger.
It is suggested that you use Compaq branded memory to ensure compatibility with what you have. Otherwise, pick two chips that are the same.
http://h18000.www1.hp.com/products/quickspecs/11382_div/11382_div.HTML#Overview
This site will show you where to find the location of the memory.
The slots are below the keyboard to the rightr of the track pad. THe "Tabs" that hold the lid down can be seen if you look at the bottom left of the keyboard area. You need a flathead screwdriver size small to remove the lid.
Apr 18, 2008 | Computers & Internet
Adding memory stick to Evo N610c
I am sending you a link which describes the replacement of the Memory stick in the computer. Please check it out and let me know if this helps. The link is as follows:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c01122797/c01122797.pdf
Do get back in case you need more information.
Mar 09, 2008 | Compaq Evo N610C Notebook
Compaq Evo N610C Notebook Logo
295 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
