Question about Olympus FE-110 Digital Camera
Camera wont power up
I belive your right about the os.
I reconnected camera to laptop but it did not see it.
was not aware of icon in lower right hand corner to disconnect.
I suppose theres no way to reboot os ??
Thanks for your help,
Joe
PS Do they still make these camera or have they replaced it with another?
  • 958 Answers
They do sell f-210 already which have a lot of problems too...
i did had one for $120. but broke down after 3 months. .
your choice...
tnx,
drcool
pls rate me on the first posting, you opened another post...
tnx again..
Posted on Jul 28, 2008
Cant download photo too my laptop
Latinlord_17,
Are you sure the camera is on and charged while it is connected to the computer?
If not, you may need to charge the device via a power adapter to ensure a better experience.
If the camera is charged, I will provide two sets of instruction, one for Mac OS X and the other for Windows.
Windows:
  1. Take the USB cable that came with your camera and plug it into the correct ports on both the camera and computer.
  2. Windows should detect the camera and launch "Windows Photo and Fax Viewer" wizard, and ask you what the default action should be when you connect the camera.
  3. Upon clicking NEXT, you should then see your photos loading up on the screen, scroll down to the button that says Import All
  4. When the download is complete, your pictures should be inside the My Pictures folder in Documents
Mac OS X:
  2. OS X should detect the camera, and prompt to launch the iPhoto application
  3. Inside iPhoto, you should then be able to see a camera icon with your camera's name on the left-hand bar. Click on this icon.
  4. Upon seeing your photos, on the right hand portion of the screen, you should see a button that says Import Pictures.
  5. After the download is complete, the pictures are stored inside iPhoto and can be viewed in the Events portion of the application.
Hope this helps.
- DJ 45cal
Jun 27, 2011 | Jazz JDC31 Digital Camera
Logitech Webcam Microphone not working
You may have a laptop with another mic installed or other mic software installed
try setting the webcam mic as default
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Jun 14, 2010 | Logitech QuickCam Communicate STX Personal...
Driver for 90000-60015-002U
When you plug the thumb drive into your USB port, does your OS detect that it is plugged in? You should get an icon in the lower right hand coner that says it is searching for device drivers.
May 04, 2010 | Computers & Internet
Just bought and installed the camera. Mic does not work, just static with test message. help. Thanks, Mark.
Typical audio set up
Laptop x webcam/mic x Vista x Yahoo Messenger
If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS
To set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Restart computer
CONFIGURE TO MESSENGER
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
Click ( > ) Messenger > Preferences > Calling and Audio
Set mic and speakers to show Default equipment
Run call up assistant to test audio equipment > Apply > OK
Dec 30, 2009 | Radio Shack VGA PC Camera Webcam
I am getting a large amount of audio feedback (pulsing) when using skype and the logitech C500 webcam. The noise may not occur the first time I connect, but almost always occurs when I reconnect. Shutting...
You do not say if you are using a laptop with built in speakers or desktop with add on speakers. Also no indication of your OS.
I think the first thing you need to try is using a headset to cut out the possibility of 'feedback'
Check out your audio set-up
Laptop x webcam/mic x Vista x Skype
TEST SPEAKERS
Restart computer
CONFIGURE TO SKYPE
Start Skype.
On the Tools menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Set your speakers as default.
Select your webcam as the default microphone.
Click 'Save'
Dec 20, 2009 | Logitech Quickcam Chat Webcam
Computer wont recognize camera to upload pictures
Dear Mv1310,
Here are the few things that you might want to check.
1) When you connect your camera to the USB of your computer and switch on the camera ... Does your computer recognize that an USB device has been attached to it? It would generally show a balloon on right hand side bottom corner in windows OS and would show a green arrow icon in the system trey when the device is ready to use. Do you see any new drive letter in "My computer"?
If you Do Not .. then
Right click on "My computer" --> Properties --> Hardware tab --> Device manager button .. Under the USB devices do you see any Red "X" or "!" marks?
Right click and un-install the devices with Red X or "!" marks.
Then disconnect the camera and then reconnect the camera back to the computer and this time the computer should recognize and reinstall the camera and this time it should work fine.
If not then please let me know if the computer recognizes any other USB devices like printer and modem ...
Please let me know the above and I would be glad to assist you ahead..
Regards,
Srinivas.
Jun 20, 2009 | Kodak Easyshare M753 Digital Camera
CAMERA VER 1.0.0
you may not have installed the driver or your system might be attacked by a virus...so first install a good antivirus and scan the system, your problem might be solved, if not just re-install the OS..!!
Oct 18, 2008 | Acer Aspire 5500 5570-2609 Laptop
No internet access
Check if the wireless network is connected properly in the laptop, try to disconnect the connection , and reconnect again ..if you still feel you are connected..at the lower right hand corner you will find the wireless network connection icon..right click the icon and click view available wireless networks, check you are connected..if yes click change the order of the preffered networksand remove your wireless network and then try connecting it..try it out and let me know...all the best
Jul 29, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Camera still will not turn on
i think you need to look at an icon at the lower right corner of the computer...once you plug a device, the computer would recognize it and keep it in mind so the procedure is always click that icon that would tell you to " you can now safely remove your hardware"
you remove the camera from the system without hitting that safely remove hardware icon .
that could have damaged the OS of the camera.
what i am suggesting is for you to plug it back and work at the computer and see if it can still recognize your camera.
if it can not , then serious problem with camera OS.
good luck on your camera,
drcool
Jul 27, 2008 | Olympus FE-110 Digital Camera
My laptop won't connect to wireless internet unless it is running off its battery. As soon as I plug the laptop into a power source, it automatically disconnects from the internet and I cannot get it to...
It seems the two oval lights on the front of the Acer TravelMate 3003LCi are not only lights to indicate WiFi traffic, but also buttons to turn the WiFi radio on and off for security reasons. If you press and hold the left side button for 3-5 seconds it should turn back on the WiFi radio. Windows XP (and maybe other OS’s) have a power saving function that turns the radio off when not in use to save the battery, so you have to use the buttons to turn the radio back on. Seems like a pain in the @$$ to me, but it’s a clients laptop not mine so he will have to live with that.
I hope this helps someone so they do not have to go through the frustration of trying to figure out why the radio has been turned off.
Nov 04, 2007 | Acer Aspire 5050-3242 Notebook
Olympus FE-110 Digital Camera Logo
60 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
