Question about JVC Televison & Video
Turned green - JVC Televison & Video
    Novelist:
    Champion:
  • 203 Answers
First try to reset by unplugging set from power source for a few minutes. Then if that doesn't work, go into the menu and turn the color all the way down. If it is still green, you can look inside to see which tubes are glowing. Also you can adjust the screens to see if tubes are getting current. Good luck, Russmann.
Posted on Jul 28, 2008
How do i remove green mode on a camera pentax RS1000
Pentax Optio RS1000 Digital Camera Green - Questions ...
www.fixya.com > ... > Optio > Pentax Optio RS1000 Digital Camera
turn green mode off my camera how to turn offf green mode just hit the green button, its the delete pic button as well, but it can be used to turn green mode on ...
Oct 27, 2015 | Pentax Cameras
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Turn green mode off my camera
just hit the green button, its the delete pic button as well, but it can be used to turn green mode on and off.
Oct 24, 2012 | Pentax Optio E50 Digital Camera
Large green wavy lines faded in background for 2 months. Then once turn on slowly fades to solid green. Turn off for 10 minutes turn back on, good picture for 3-15 minutes, then fades to solid green....
The Green CRT has shorted and will need replacement. You can verify the problem by removing the Green CRT drive board from the green CRT dont unplug the wires just slide the board off and let it hang suspended then try powering up the set if it stays on without shutting down then you will no its the green CRT for sure. You can get a green CRT from www.tvrepairworld.com
Jun 19, 2011 | Sony KP-57WS500 57" Rear Projection...
After turning on the screen it soon turns a green tint. I just transported the tv could I have knocked something out of alignment?
yes or the green tube is going bad. if it holds solid just a little green, you just need to turn down the screen control for the green drive. if it gets brighter and brighter green until its really intense, suspect bad tube or board.
the green drive knob is hidden in the front, behind the front access panel. its labeled but hard to see, only turn the one know counter clockwise, it will be labeled G and SCREEN, there are 6 knobs
Sep 09, 2010 | Samsung HCL473W 47" Rear Projection...
Tv turns on green light blinks three times then TV turns off
Ur power supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 07, 2010 | LG 42LC2D 42 in. LCD HDTV
Lines horizonal - seems to be caused by voltage to green CRT
Your green CRT is shorted. To test put your red crt socket on the green and your red on the green. then try turning up red control if the green now works its not your tube. If the same thing happens with the red socket on the green you can be sure its the green CRT if the green works properly with the red socket, then you have a problem in the green drive circuit and not the CRT. hope this helps.
Jan 19, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Picture has turned green
Possible green CRT bad....remove lower front speaker cover
and access panel.......carefully disconnect green PC board
from green CRT ( center tube )....plug in TV..power set....should have steady red/blue pix (no green) = bad green CRT............T.
Oct 27, 2007 | Toshiba TZ55V61 55" Rear Projection...
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
