Question about Nikon COOLPIX L12 Digital Camera
Question when i connect my camera to my computer , window s stop a program o something like that i cannot go forward
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
Have you tried different usb connection?
try to connect it when all the other windows are closed.
Posted on Jul 28, 2008
I connected the cable and managed to transfer one picture from my Nikon S8100 to the computer. The computer tells me that there are no more pictures to transfer, but I cannot find them!!! Where should I...
When you connect your Nikon camera to your computer some program is automatically loading up and then transferring your pictures over. If you haven't deleted the picture from your camera then reconnect your camera back to your computer. Follow the same steps you did the first time but watch the screen carefully. When the program tells you it is copying the picture over it should have a window open to the directory that it is using for the transfer. You should be able to get to that directory in your computer to work with your picture.
If the program deleted the picture from your camera then just shoot another picture so that you have something to work with. Most programs use some kind of a naming convention when it is saving your pictures, Usually it is a name made up of the date you are transferring the picture on as well as a number. The program should open a window before the transfer is completed to allow you to use your own naming convention.
Jun 27, 2011 | Nikon S8100 Digital Camera
I am trying to get my servailliance camera hooked up via the internet. I am not getting a picture and I guess I need to set up a forwarding port on my router. How do I do this?
Look at the brand of router and model router and go to their web site. Down load / read the steps to log in to your router. Enter the URL link or IP , then user name and password. Look through the setup for a section that is labeled port forwarding. I've worked with several home consumer routers and their all web based and look pretty strange at first but study it and your see how to tell the router to forward a port to a specific IP. But that will only work it your computer always connects with the same IP on the router and that you always use that same computer to see your camera. Routers by default are DHCP and assign you an IP at random when you connect. Port forwarding would require you to also setup your computer to static IP, Meaning you MAC address would always be assigned the same IP, so the port forwarding would always be able to forward to the correct IP. Sounds much harder than it is. Your question sounds like you want to ensure the camera ip/port is passing through the router, so your home computer can see the video. Thats how you could forward a port to something. But if your wanting to see your camera from anywhere on the web then you'll want to make sure your router isn't blocking that port to the open WAN (wide area network). But I'd check your firewall on your computer FIRST>. Thats all a firewalls is for. Try connecting to your camera with your firewall / anti-virus software off for a test first. If it works then you need to be setting up your firewall on your computer and not your router. Firewall is usually part of your anti virus software and or, part of windows. Go to control panel, look for the security shield icon on XP and disable the firewall. You'll get some errors, but this is just for a test. I can't remember exactly the step for windows xp, but again look for help on your operation system of google it. Also don't forget about the lights on your router. Use them to help troubleshot. Went you plug the camera in, does the activity light come on? You can also have a bad cable...... good luck!
Apr 01, 2011 | Linksys Wireless-G WRT54G Router
I cannot download the pictures from my Exilim EX-Z40 digital camera into my PC running under Windows 7. Thanks
The last "review" I saw on this camera was in 2007 so, the camera firmware is not compatible with the newer PC operating systems "Windows 7. To continue using this camera you will need to buy a memory card reader for the type of card being used or a multiple card reader and plug the reader into your PC's USB port. The computer then looks at the memory card as an external hard drive.
You would create a "new" folder in something like "My Documents" on the PC and copy past the picture files into the new folder.
Once on the computer don't forget to do a "safe" disconnect of the memory card or you could crash the system.
Now that the pictures are on the computer hard drive you can open them in an image program like Photoshop.
When you buy another camera this whole system can follow forward even without installing the camera software programs.
Technology has advance further then your camera has programing capabilities.
Hope this was a help
Feb 20, 2011 | Casio Exilim EX-Z40 Digital Camera
Drivers for windows 98 for canon powershot a470
you do not need the disc. use "my computer" or a different program such as kodak easyshare or zoombrowser
May 12, 2009 | Canon PowerShot A470 Digital Camera
Port forwarding on my Actiontec router to access my Linksys wvc54gc camera.
I have Actiontec and didn't need to do Port Forwarding.
Normal 0 Try disconnecting the Camera from the USB port and reinstall the CD software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Jan 27, 2009 | Linksys Wireless-G WVC54GC Network Camera
Need port forwarding on my actiontec router to support my Linksys
I have an Actiontec and did not have to do a port forwarding to get the camera to work. Worth a try.
A. Skype Setup:
B. Yahoo Setup:
Windows Vista
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Dec 26, 2008 | Samsung L100 Digital Camera
Problem loading Webcam driver
Normal 0 You need to go to the manufactures site and download the VISTA driver for the camera. Then follow the info below to install the program.
Normal 0
Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Oct 27, 2008 | Computers & Internet
How to download video from digital video camera to laptop
First, you need a program on your computer that searches for connected digital video devices. Like Windows Movie Maker! Look for Windows Movie Maker on your laptop. If found, bring it up and there should be a task panel on the left side. Near the top, there should be something that says "Capture from video device". (Or something close to that.) Click on it and Windows Movie Maker will search for connected video devices. It should find you camera and will show you what you need to do. (Make sure your camera is turned on play mode.) Windows Movie Maker is a very easy to use program and allows you to add music, transitions and all kinds of cool effects to your videos. If you have any questions, please ask.
Mar 27, 2008 | JVC GR-D370 Mini DV Digital Camcorder
Can't download pictures from camera to computer
likely the easiest thing to try is to uninstall the caplio program.
go to start/setting/controlpanel/add remove programs
uninstall caplio program and then reboot.
plug in the camera and try navigating to it through my computer
if it works then reinstall the caplio program.
Jan 27, 2008 | Ricoh Caplio R3 Digital Camera
Nikon COOLPIX  L12 Digital Camera Logo
22 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
