Question about Akai LCT2785TA 27 in. LCD Television
Part is m8 the part #
    Problem Solver:
  • 13 Answers
You asked: "is m8 the part #"
I don't see any thread for an original post, so I'm not sure just who you are asking, or what part you are refering to.
I can tell you this:
m8 is not a common part number, although I'm sure someone used it somewhere.
A MUCH MORE COMMON USE OF "m8" :
The term "m8" is often used as an abbrevation for the word "mate", commonly used as a friendly greeting or salutation, mainly in England and surrounding areas.
If that's not the case, maybe you could include a little more detail with your question.
Hope this helps you out, m8.
Sincerely ,
=doublèdgè=
Posted on Oct 08, 2008
Bizhub 951how to remove code c-0104
Dear Noorul,
Your question seems to be related to a copier. It is categorized under tv & video. I hope this is the information you are looking for:
Code
C-0104
Description
Abnormality of the vertical conveyance motor (M8) power in the printer control board (PRCB). An error detection signal (blowout of ICP) of M8 is detected when M8 is turned ON.
Causes
• Vertical conveyance motor (M8) • Printer control board (PRCB)
Konica Minolta bizhub Pro 951 Error Codes
Sounds like you have some replacement of parts that are needed. Let me know if you need a service manual. I will look for that.
Blessings!
Jul 05, 2017 | Televison & Video
How can I use my hotspot for the HTC one m8. Originally it was a Verizon phone but I now use straight talk. Everything this far is all legal no hacks
      The password is the key other people need to enter on their device so they can connect and use HTC One (M8) as a wireless router. To helpmake your Wi-Fi hotspot more secure, tap > Advanced. Choose from the available settings, and then press . Tap the Portable Wi-Fi HotspotOn/Off switch to turn it on.
      Using HTC One (M8) as a Wi-Fi hotspot - HTC.com
      www.htc.com/us/support/htc-one-m8/howto/465106.html HTC
    Feedback
    HTC
Jan 23, 2016 | HTC Cell Phones
I would like to know if I can install an borg warner m8 tail section onto an borg warner m12 transmission that way I would not have to change from the torque tube subsention
I just found out that all that you have to do is . You have three options to go with one change the bellhousing from a borg warner m12 transmission. two use and borg warner m12 transmission but use the yoke head from the m8 onto the yoke of the m12 yoke .Three use a chryler/amc tf727 torque command transmission.Use the yoke from the m8 weld the head on to the spline of the 727transmission weld the m8 tail section onto eather transmission and that way you can keep the torque tube suspension on your classic 770 with the 287.Your rear end should be an AMC 20 to stand the torque from the AMC 360 engine with about 350 hp .last but at lease get the trany mounts.
Feb 10, 2015 | AMC Cars & Trucks
Do I need m6 or m8 bolts for the wall bracket
M8 is a higher grade of steel indicating a stronger bolt, m6 should be fine but m8 would be better.
Jun 18, 2014 | Digihome LCD TV
Screw size for mount and tv un32f5500af
This TV is VESA mount compliant with a spacing of 200MM x 200MM. the mount holes are M8 1.25 and about 23MM deep. 3 of the holes are recessed and one hole is near surface. Adding a 2-3 MM margin for a typical washer and the mount itself, M8 1.25, 25MM screws might be the best to mount this TV.
I am using the Sanus simplicity SMF3 mount (bought from costco). The spacers provided with this mount are 22MM which makes the supplied M8 35MM screws too small with the spacers. Without the spacers, the supplied M8 16MM screws are too small. With spacers, I think the screw size should be M8 45MM and without spacers it should be M8 25MM
I am thinking a vinyl washer might be a good addition to the assembly (with my sanus mount).
Found this site useful to understand the screw dimensions.
http://www.fastenermart.com/html/metricsizes.html
Dec 22, 2013 | Samsung Televison & Video
What type of RAM is used in this..? either DDR1 or DDR2
ECS 865G-M8 (V1.0) supports:
DDR400/333/266 (DDR1) and supports up to 2 GB.
I hope it helped.
Jan 24, 2010 | EliteGroup 865G-M8 (V1.0) (MB865GM8)...
Rev counter
ello m8,, i see u have a few testers to try out by scorch there,, all i can anserw 4 yuh to your question,, is electronic rev counters if there is no cable,, work off the coils m8,, u can try a quick tester, by runnin a wire from the live or plus from one of the coils and touching it to the live of the rev counter,, bike must be runnin tho,,try that 2 m8,, cheers
Feb 28, 2009 | 2000 Sachs XTC Racing
Input cable
Hi Eric, you can use Black Color Cable (1.8 m) with 3.5 mm Stereo Mini Jack x 1 pc,
1.8 m (6 ft.) Cable with RCA Pin Jack, and 8-pcs No Skid Pads or you contac support for your particular speakers, considering is a good brand, here, http://www.yamaha.co.jp/english/product/av/products/pc/m8.html
there you may found your cable.
Carl
Nov 05, 2007 | Yamaha YST-M8 Computer Speakers
Akai LCT2785TA 27 in. LCD Television Logo
99 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
