Question about Biostar P4SXQ Motherboard
Does it support intel & amd?
Is the p4sxq an intel only mobo or will it support both intel and amd?
    President:
  • 2,351 Answers
Hi aventae, the P4SXQ motherboard will only support Intel Pentium 4 or Intel Celeron processors 400MHz CPU's.
Biostar's link for the P4SXQ MB.
http://www.biostar-usa.com/mbdetails.asp?model=P4SXQ
Mike
Posted on Jul 28, 2008
GD8 motherboard
The GD8 mobo spec says that the bopard is only compatible with P4 and Celeron D processors so no you cant swap it! Generally the Athlon 1800+ is a better processor but it depends on the mobo, BIOS, RAM setup etc.
Sep 09, 2009 | Abit GD8 Motherboard
Compatible AMD cpu
According to what I have found, this is an Intel Motherboard. You will not find an AMD chip to fit this. This is a socket 478 mobo. Heres the specs site: http://www.motherboard.cz/mb/matsonic/MS9367E.htm
Jun 04, 2009 | Matsonic MS9367E Motherboard
My notebook heats a lot!!!!!!
Hello, here is the deal, AMD and INTEL both have CPU's that have low heat. In your case you would have to buy a new laptop to switch from AMD to INTEL. The laptop motherboard take's only one socket type, for exp.. you would have to get another TURION at faster speeds or less speeds in the same socket family. Try to keep the vents open, sometimes the vents for the air from the fan come out the bottom not the back. You might want to invest in a laptop fan stand.
Dec 21, 2008 | HP Pavilion dv6000z Notebook
Cpu update
basing from MSI website cpu support for this mobo,
the best AMD processor you can fit on this mobo is
ATHLONXP 3200+.
Barton (0.13u) 200/400MHz FSB 512KB L2 Cache AthlonXP 3000+ 200 Auto OK AthlonXP 3200+ 200 Auto OK
http://global.msi.com.tw/index.php?func=prodcpusupport&prod_no=592&maincat_no=1#menu
Oct 13, 2008 | Intel Motherboard
E2180 Vs Athlon 64 X2 5000+
depends on what you plan to do with the cpu amd are good but a 3200 may only run @ 1.8 to 3.2 ghz depending while a intel 3200 will run 3.2 ghz.
I believe intel are more stable & run cooler than AMD but AMD benchmarks on Games better but run hotter (so get a good cooling fan & heatsink both pentium / celeron d & intel dou / dual core / core 2 dou and amd x2 have 2 cores (but watch your front side bus and cache the higher the better but the more $ also) then You need a good stable mobo that supports the chip you get (I preffer asus & msi for Gamers and biostar / msi for home users)
Sep 18, 2008 | AMD Athlon 64 X2 4600+, 2.4 GHz...
Over clocking
Use AMD overdrive to overclock to 1.3GHz.
Jul 19, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Amd 900
put on right pins pw on mobo should work
Jan 25, 2008 | AMD (K7900200256SLA) Athlon, 900 MHz...
Problem with mobo upgrade ... From Intel CPU to AMD CPU
hi dale, itsnot a good thing when you see the blue screen of death, cause recent changes hardware normaly maybeif you have changed from intel to amd using mobo and all parts are amd now , maybe if you reinstalled your operating system the new hardware that is installed will accept you software cheers steve good luck
Apr 26, 2007 | Jetway 939GT4-SLI-G Motherboard
Biostar P4SXQ Motherboard Logo
96 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
