Question about Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher
Bosch 24 shu43c02uc/17
Pump keeps running after cycle complete; stops when door is opened.
i called customer service they told me to try the reset . it did not work.
the machine does a complete cycle with no problem until the end.
thanks!
SOURCE: Bosch SHU43C02UC/47
How to loose up the circulation pump
Posted on Nov 03, 2007
SOURCE: Bosch SHU3036UC not filling with water
Check the hose! I just cut a check to a nice plumber who fixed our problem in an embarassingly short amount of time. The hose going from our dishwasher to the plumbing has a 2-inch or so silver part at the plumbing end with an internal switch that helps prevent flooding. Somehow that got tripped and suddenly we had no water for the dishwasher. The plumber turned off the water for the dishwasher, reset the hose, reconnected it and he was off to the bank in no time.
Posted on Dec 23, 2007
here2helpBSH
  • 27 Answers
SOURCE: Bosch SHU3036UC draining on wash cycle
it is probably going to be a grimy door thermostat between the inner and outer panel. its hooked into the back of the soap dispenser. someone would have to take the outer panel off then clean wipe away the caked grime from the thermostat and put it back in its place. if this doesnt fix it then it could be a heat assembly problem or timer problem. in that case you would need an appliance tech out
Posted on May 30, 2009
bugsy33
  • 33 Answers
SOURCE: i am trying to find out the worth of my Bosch
about 1800 to replace call a dealer
Posted on Dec 05, 2009
  • 44 Answers
SOURCE: Bosch dishwasher not completing its cycle
Sounds to me like you have a problem with with the overflow switch or float. To access the switch or float you must pull d/w out and remove the left side panel(as you face the d/w).
Posted on Mar 29, 2010
Bosch dishwasher shx46a06uc-30
the unit will try to complete the last command it was engage in before it went in the overfill safety mode. you must perform a cancel drain cycle to reset unit to default setting. Remember the drain cycle is 2 min and must be completed to reset main control. however if it went into a overfill status you have a leak and it generally comes from the pressure chamber on the lefthand side of unit where the water enters tub
Apr 17, 2012 | Bosch 24 in. SHX46A05UC Built-In...
Bosch dishwasher starts, pumps, stops and says it's clean
We have the exact same problem with our Bosch SHE5AL06UC/05 dishwasher. Works great when it works, but we are increasingly having a hard time getting the wash cycle to start.
Apr 13, 2012 | Bosch SHE5AL06UC 24 in Builtin Dishwasher
My bosch shx46a05UC/14 will not shut off. I can open the door and the dishwasher just keeps going?
Are you please able to confirm what exactly is happening when you mention "dishwasher just keeps going".
Is it in a wash cycle and throwing the water around through the wash arms or do you just hear a pump running with water sitting in the base. Most likely there is a leak into the base and the auto stop circuit is trying to empty the dishwasher by running the drain pump. I would suggest you check the base of dishwasher for leaks.
Jan 28, 2011 | Bosch 24 in. SHX46A05UC Built-In...
The dishwasher wont turn off. It does a wash cycle but keeps running...help
you have a leak and it is activating anti flood device this switches on the drain pump to stop it flooding your kitchen if the pump keeps running even with the door open thats what it will be,will need inspection by service to trace leak.
Feb 11, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SGV43A03 DISHWASHER: pump drains all the time, even if reset!
Typically you could possibly have a leak in the base or sump which activates a little float switch. This in turn switches the drain pump on continuously and deactivates the programing cycle.Sort out the leak.
Feb 24, 2008 | Bosch 24 in. SGV43A03 Built-In Dishwasher
Bosch SHU43C02UC/47
Oct 22, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher Logo
120 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
