Hi, if your bobbin has thread, check to make sure the bobbin is inserted into the shuttle correctly. If it is loaded correctly, check to see if the needle is able to pull the thread through the throat plate.
If it doesn't have thread, then all your sewing machine will do is make little holes because the bobbin thread is what catches the sewing needle thread to form the lock stitch to sew the material together . Check your manual on the sewing machine for where it is and how to put thread into it.
Actually you should have a "set screw" in the hand wheel. The set screw is usally locked down tight to keep the hand wheel from spinning freely. I f you can run the machine slowly and hold the hand wheel in one place but the machine continues running, then you do need to replace the "set screw". If you replace it you will find that you can offset some of the machines vibration by where you lock the wheel down. Trial and error is the only way to achive this adjustment, kind of like balancing the tires on your car.
Hi, i think there is a problem with motor which is the cause of the belt not able to turn all the way round.....
Then there is a problem with the machine that i think goes beyond your ability to fix. Maybe you have to call in a repair tech to check it out...
Thread your machine with the presser
foot UP. The disks that control the tension (thread goes through
them) are tightened up if the foot is down.
Change the machine tension with the
presser foot DOWN. Because the disks won't be engaged (see above)
if the foot is up, the disks won't move.
Start at the middle setting, 3. Go up
to tighten, decrease to loosen. Each machine is different, even 2
different machines of the same model. The best thing to do is start
at 3 and use a different color in the top and bobbin thread so you
can easily see what changes to the tension do to your stitches.
Now use a straight stitch a sew 3 or so
inches. Take a look at the top and bottom of the fabric. You don't
want to see any (or at least not much) of the other color showing
from the other side.
Loops on the bottom of the fabric means
you need to tighten (increase) your top tension. If you're stitches
on the bottom are causing puckering, then you need to loosen you're
top tension. For the most part, you really don't want to touch your
bobbin tension-leave that to a repair technician. The factory setting
shouldn't be touched except by someone who really knows what
they're doing.
Keep sewing a few inches at a time until you have the results you want. Now you're tension is where you need it!
My bobbin was threaded correctly, so I decided to check the manual on the needle-to-hook relationship. I attempted to adjust the needle bar height. I loosened the set screw and turned the handwheel so that the needle was at its lowest position. I adjusted the needle height according to the manual, but now the wheel isn't moving the needle, and I can't find the setscrew to readjust the needle height, either.
I tried running the motor at a slow speed, and now the belt won't turn all the way. I can move the handwheel about one turn in either direction, but it stops at that point.
Are you still helping me?
The handwheel will not cycle completely, even with the motor off.
