Fax/tel mode How to setup the machine to receive in fax/tel mode ? I was delegated by a mayor from a small village who bought this machine. This person bought the machine with 2 user manuals but none of them in our language (romanian), or english/french - languages we also understand. All I need is a user manual in english (for this moment). thank you
  • mocamircea Jul 28, 2008
    the machine is fax-L160
Canon fax-L160
Posted on Sep 01, 2008
    Genius:
  • 2,120 Answers
Make / model?
Posted on Aug 31, 2008
How do i change from manual receive mode to auto?
You want "Fax/Tel" Mode. To do this follow instructions below.
To set a receive mode follow the instructions below.
a Press Menu.
b Press a or b to choose Initial Setup.
Press OK.
c Press a or b to choose Receive Mode.
Press OK.
d Press a or b to choose Fax Only, Fax/Tel, External TAD or Manual.
Press OK.
e Press Stop/Exit.
The LCD will display the current receive mode.
Apr 04, 2011 | Brother MFC-465CN InkJet Printer
The fax keeps ringing it does not pick up
This sounds like the FAX mode is not set properly.
Follow these steps.
Press Menu
Press up or down arrow until it displays "Initial Setup"
Select Initial Setup
Press up or down arrow until you see "Receive Mode"
Select Receive Mode
Select your choice: Fax Only, FAX/ Tel depending on your connection.
If your fax is connected to a telephone line that shares dial tone with a handset, choose FAX/Tel
Press STOP/Exit
Jun 15, 2010 | Brother MFC-6890CDW Printer
Will not receive faxes. Line rings when phone was
make sure the mode switch is set to "fax"... not "tel", or "fax/tel". I think the mode indicator is on the top of the fax machine and it's a light that should be on next to "fax"
Oct 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
We can send faxes but we can not receive faxes. The fax machine that sends the fax tell it that our line is busy. Is that a machine problem or a phone line problem?
Problem lies in your Receive Mode setting. If you don't have a dedicated phone line for the fax machine, you need to set it up for either Manual where you answer every call or Fax/Tel whereby the Fax machine determines if the incoming call is a fax or phone call. Instructions per Intellifax 4100 Manual.
Select a Receive Mode
Choose the mode that best suits your needs by pressing the Mode button
repeatedly until the FAX and FAX/TEL lights show the setting you want to use.
Manual
You must answer every call yourself.
The Brother machine must be started manually
to receive faxes.
Fax
For use with a dedicated fax line.
Every call is answered as a fax.
Fax/Tel
For receiving fax and voice calls on one line.
The FAX answers every call and receives a fax or
double rings for you to pick up a voice call.
TAD
For use with an answering device.
The TAD answers every call and stores voice messages.
Fax messages are printed.
Apr 20, 2009 | Brother IntelliFAX 4100 Laser Fax
Canon faxphone will not recieve fax
Most of my fax mahines I setup,I setup with the fax only mode,and then I change my incomming ring to 7.This give you enough time to answer the phone and minnimize the risk of losing faxes.If a external phone is connected to the phone and you receive a fax call,you press 25 on the external phone and the fax switch to rceive.
Feb 27, 2009 | Canon FAXPHONE L80 Laser
Not sure how to setup the tel/fax mode correctly
The JX200 has four modes of fax receipt - Fax/Tel, Manual, Answering Machine, and Fax Only. The Fax/Tel mode, which you have indicated is your desire, is meant to let the fax machine automatically switch between fax and voice calls. Documents are received automatically, and the machine rings for voice calls.
Set the mode by pressing [Receive Mode/Resolution]. Every time you press [Receive Mode/Resolution], the mode changes cyclically.
If you set Fax/Tel mode, you can control precisely how the fax handles incoming calls by adjusting the following settings:
• Adjust the time the fax takes to check whether a call is from a fax machine or a telephone (<RING START TIME> setting).
• Adjust the length of time the fax rings when the call is a voice call (<TEL RING TIME> setting).
• Set whether the fax switches to receive mode after the ring time set in <TEL RING TIME> has elapsed (<DEFAULT ACTION> setting).
1. Press [Menu].
2. Use arrows to select <DATA REGISTRATION>, then press [Start/Copy]. The LCD displays <USER SETTINGS>.
3. Use arrows to select <RX SETTINGS>, then press [Start/Copy]. The LCD displays <ECM RX>.
4. Use arrows to select <FAX/TEL AUTO SW>, then press [Start/Copy]. The LCD displays <RING START TIME>.
5. Press [Start/Copy]. The LCD displays <8SEC.>
6. Use the numeric buttons, or arrows to enter the time the fax waits before ringing when it receives a call, then press [Start/Copy] twice.
7. Use the numeric buttons, or arrows to enter the time the fax rings while waiting for someone to pick up the Handset, then press [Start/Copy] twice. The LCD displays <RECEIVE>.
8. Use arrows to select <RECEIVE> or <DISCONNECT>, then press [Start/Copy]. This setting tells the fax what to do if the Handset is not picked up within the specified ring time set in step 6.
9. Press [Stop].
Setting ends and the fax returns to standby mode. The machine will now handle calls as indicated in the settings you input.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Jul 31, 2008 | Canon FAX-JX200
Can not receive fax
Make sure the fax is set to receive automatically. The receive mode must be set to one of the following modes: Fax Only, Fax/Tel Auto Sw, or Ans Machine. If it is set for Answering Machine, be sure the machine is connected to the fax, turned on, and contains a recorded outgoing message.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Jun 24, 2008 | Canon FAX-JX200
Sharp fax machine: help!
look to see if it is in tel,fax,or a.m. mode you need to have it in fax mode.tel=telephone,a.m.=ansering machine
May 09, 2008 | Sharp FO 3150 Plain Paper Laser Fax
Receiving a fax
Brother web site has manual for download
check tel cord goes from wall to socket marked "line" on fax, with filter if DSL
check receive mode Auto or Manual to suit enviroment.
Check tel/fax mode
check distintive ring setting
Nov 08, 2007 | Brother IntelliFAX 1840C Plain Paper...
285 people viewed this question
jasbo
jasbo
