Question about Lite On SOHR-5238S CD-RW Burner
Lightscribe enable is a lite-on cd rw sohr-5238s lightscribe compatible
  • 1 more comment
  • kaleidoscope Jul 28, 2008
    i don't know
  • kaleidoscope Jul 30, 2008
    thanks for your help. how do i delete this problem so no one else tries to answer it lol. as i don't need it solving anymore
    thanks for finding this out for me i tried everywhere on here to find solution. much appreciated
    Sergeant:
  • 310 Answers
Afraid it doesnt have lightscribe built in.
All the best
John
Posted on Jul 29, 2008
Won't run games
Go to Start menu lower left corner and click on Help and Support
In the Search Help Box type old Games
Then click on hyperlink to Make older Programs run in this version of Windows
Then click to open the Program Compatibility trouble shooter and follow the directions or (a quicker way that worked on mine is to go to the program itself once installed and right click on it, then select properties, then click on the compatibility tab
Hope this helps you
Nov 30, 2011 | Lite On (SOHR-5239V) CD-RW Burner
How could i make my Lite-on-sohr-cd-rw burner burn and read DVD+R/DVD-R? Because When i put it in the drive the computer doesnt show it as if it isnt in there.What do i do?
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer:
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone:. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Jul 14, 2011 | Lite On SOHR-5238S CD-RW Burner
How can i make my Lite-on-SOHR-5238s CD-RW burner read and burn stuff on a DVD+R/DVD-R? Cause when i put it in my computer doesnt recognize it.
Hi Justin If it's a CD-RW burner then you can't burn any DVDs in it. You need to get a DVD burner instead - they are very cheap now.
I need help finding out why my computer says no burner connected when ive burned disc from my liteon driver before from windows and now when i go to burn it say connect burner when ive checked the...
sounds like a faulty electrical connection check all connections that attach PSU to your burner or go into administrative tools,computer management, device manager if yellow? uninstall or roll back then once you uninstall diconect from PSU then re attach re-install
Jul 27, 2010 | Lite On SOHR-5238S CD-RW Burner
Computers
most backup software can do this.
If you have about an hour to wait, you can use the shareware version of winrar to create a multi-volume .rar compressed file. You can set the target file size (in this case 700mb) and it will split it up automatically.
Note that when you restore the data in the future you would have to copy the data all into a single folder before restoring it.
Another option you have is to buy an aftermarket backup/archiving program. nearly every one except the free one with windows will let you burn to cd/dvd.
Aug 13, 2008 | Lite On SOHR-5238S CD-RW Burner
Lightscribe
They will have the lightscribe logo on them if they are compatible. They need to have a special ink embedded on the lable side.
Jul 28, 2008 | Lite On SOHR-5238S CD-RW Burner
Lite On LTR-52327S
We bought a new cd burner
Jun 13, 2008 | Lite On (LTR-52327S/5238S)...
Pc does not recognize when i insert a cd
with ur cd ROM u will get a cd which contains driver if ur cd ROM U NEED TO INSTALL IT AND ITS AUTO RUN PROCESS SO INSTALL IT AND REBOOT THE PC>rate me SOLVED IF ITS HELP FULL
Oct 30, 2007 | Lite On SOHR-5238S CD-RW Burner
Lite-On SHM-165H6S & Lightscribe 1.2 media
have you tried updating the software to the latest version, there are probably patches on the manufacturer's website.
Oct 27, 2007 | Lite On Lite-On SHM-165H6S DVD+R/RW -R/RW...
How can I fix this. (The door won't stay closed)
The problem can be fixed but probably not at your end. Get it done bya trained technician.
Oct 06, 2007 | Lite On Lite-On 52x32x52 CD-R/CD-RW IDE...
Lite On SOHR-5238S CD-RW Burner Logo
75 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Gbenga
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
