Question about Dell 5100cn Laser Printer
Replace transfer roller
I need to replace the transfer roller - I've found it, how do I replace it? Thanks, Kirk
  • 4 Answers
On google search for Dell 5100cn user manual... you will see a pdf download available. It will give you step by step instructions.
Posted on Aug 20, 2008
My magicolor 5670 is printing out faded, washed out photos. Imaging& Toners are ok...Some Images are even dark. Thanks, Mark
How about the transfer roller and transfer belt have they been replaced Transfer belt is the shine large belt and transfer roller is the sponge roller looking thing.
Sep 09, 2014 | Konica Minolta Office Equipment & Supplies
REPLACE TRANSFER ROLLER
Replace transfer roller means you need to order a transfer roller for your
dell printer. your best bet is to go to www.dell.com and order the trasnfer roller for your printer.
thanks adi
Jan 15, 2010 | Dell 5110cn Laser Printer
Replace Transfer Roller Error Message Will Not Reset After Replac
The transfer roller on this machine comes as an assembly consisting of a waste toner tank and a transfer roller. The message you are getting pops up when this tank is full, regardless of the transfer roller's useable life. There is a window on the back that when blocked by toner, cuts off an optical sensor to tell the machine that the waste toner is full. Just unclip the roller from the side, pop it out, and dump the toner out. Careful though, it's a messy job and you might want to wrap the assembly inside a trash bag while emptying it out.
Jul 01, 2009 | Dell 5100cn Laser Printer
Reset tranfer roller instructions needed
> Support & Drivers > Phaser 6300/6350 Support > Search Results Solution: Replace the Transfer Roller bttn_print.gifMake Printable bttn_email.gifE-mail this page elem_1_spacer.gif CAUTION: Do not touch the surface of the Transfer Roller as fingerprints can cause image quality problems.
  1. Push up the latch on the front of the printer to open Door A.
  2. Squeeze the orange tabs on both sides of the Transfer Roller together, and gently lift the roller out of the printer. Dispose of the old roller as normal office waste.
  3. Remove the new Transfer Roller from its packaging.
  4. Grasp the posts on each side of the roller and insert the posts into the u-shaped guides inside the printer.
  5. Push down on the base of the orange tabs until you hear a click to lock the roller into position.
  6. Close Door A.
Looks like Roller should be detected and message should go away after you replace it.
May 28, 2009 | Xerox Phaser 6350DX Laser Printer
I am reciving error code e000064
error code e000064 indicates machine having problem with transfer roller , black roller found underneath drum unit. it may require replacing or needs cleaned being soiled . this area require technical experts as transfer roller operates on high voltage . hope this helps
Oct 01, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Transfer roller usage message on Phaser 7700. replaced..still wont print
I found the answer here: http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi
Resetting Transfer Roller Life
  • Resetting the transfer roller life is to be performed only if the Transfer Roller Assembly was defective and or the assembly is replaced before an end of life or near end of life message. Not to extend the life of the assembly. Doing so may cause premature failure of other internal printer components.
  • The printer will prompt the user to reset the life counts if the assembly is replaced after receiving a Replace Transfer Roller or Replace Transfer Roller Soon message.
note_image33x30.gif    Note: If the main Menu does not appear on the front panel screen and only Replace Transfer Roller is displayed, there may be a print job that is either processing or currently printing. Try the following steps to clear the print jobs and reset the Transfer Roller life:
  1. Press the cancel button several times to flush processing jobs from the printer.
  2. If you do not receive access to the front panel menu by doing this, power off the printer and disconnect Ethernet, parallel or USB cable from the printer.
  3. Turn the printer back on, and while it is powering up, immediately start pushing the cancel key repeatedly until you receive access to the front panel menu.
  4. If the printer menu appears on the front panel screen, follow the instructions below to reset the Transfer Roller life if the printer did not prompt you to reset it:
  1. With Menus highlighted press OK.
  2. Press the Down Arrow and scroll to Supplies Info Menu.
  3. Press OK.
  4. Press the Down Arrow and scroll to Exit at the bottom of the menu tree.
  5. Now scroll up to Reset Transfer Roller Life.
  6. Press OK.
  7. Reset Transfer Roller NOW is displayed.
  8. Press OK to reset the transfer roller life.
Sep 30, 2008 | Xerox Phaser 7700 Laser Printer
In the Phaser 6250 Color Laser Printer Service Manual (which I had to have emailed to me from my toner supplier since it is not available to the general public) I went to Chapter 6 - Error Messages and Codes. I had to reboot the printer. Here is the procedure.
Entering by rebooting the printer:
1. Turn the printer power OFF
2. Hold down the Back and Information buttons simutaneously and turn the printer
back on.
3. Continue to hold the buttons until the following message is displayed on the front
panel: Service Diagnostics V#.##, Initializing ....., and then release the buttons.
4. The front panel displays the Service Diagnostics Menu.
On the display is a menu. Find Transfer Roller. Press enter on this menu where it says Toner Waste (Not Full). Back out of the menu.
All of a sudden the machine came to life. You may have to turn off the printer and turn it back on again.
Good Luck
Jun 10, 2008 | Xerox Phaser 6250 Laser Printer
TR Roller
Here is the solution for the Transfer Roller problem from brother especially the MFC-9420CN. I found it on the Brother website.
http://pub.brother.com/pub/com/pdf/no-trroller.pdf
Mar 01, 2008 | Brother MFC-9420CN All-In-One Laser...
Ricoh Aficio cl2000
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Dec 17, 2007 | Ricoh Aficio CL2000 Laser Printer
Phaser 6250 transfer roller
Hi clwest: I hope that this will help you.
Transfer Roller is at End of Life
■ Print the Supplies Usage page to verify the remaining life and Transfer
Roller install date.
■ Cycle printer power.
■ If the problem persists, follow the procedure below
Note
Look at the clear plastic window on the Transfer Roller. If toner is present in the
center of the window the Transfer Roller is at end of life and needs to be
replaced. If no toner is visible, try cleaning the CTD (ADC) Sensor.
The “Transfer Roller is at End of Life” is a warning. “Replace Transfer Roller” is
a hard stop.
Dec 15, 2006 | Xerox Phaser 6250N Printer
Dell 5100cn Laser Printer Logo
398 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
