Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Water Heating System
When I turn on the Red Heater Switch, the power cord gets HOT and then the house circuit breaker shuts off. What is causing this to happen?
    President:
  • 1,673 Answers
You need to have the wiring checked in the handle. Either the switch or wires going to the heater are bad or shorting to something they shouldn't.
Posted on Aug 10, 2008
Electrolux Epic 6500 SR - power/cord light not lit, doesn't start & blows house circuit breaker
If your vacuum has had 20 years of service it may be simply too old to repair.
Apr 15, 2017 | Electrolux Vacuums
Bounced down a step while on, blew house circuit breaker, now s548 only powers on when on its side
Rickhan,
I would recommend taking it to a Miele dealer and let them repair it. It can get rather tricky trying to put those back together. I speak from experience and I work at a Miele dealer and I leave them for the other repair tech.
Jul 04, 2015 | Miele S548 Bagged Canister Vacuum
My machine trips the electricity switch in the house when I use the carpet brush tool, this usually happens after about 20minutes or so. Do I need a new brush motor or would water be getting into the...
You probably just have a circuit breaker that's become weak or is overloaded running other things as well as your machine. Have you tried an outlet powered by a different breaker? Also, if you're using an extension cord it will raise the resistance and the current draw.
Mar 30, 2015 | Rug Doctor Mighty Pro
Vacuum just quit, while in use
If the Power from the wall receptacle was OK, and you did not trip a circuit breaker, then the motor may have shut down or the on/off switch broke. Usually your house power would go out if a short circuit occurred while plugged into the house current. Check all wires, and smell the housing for any burn odor. Look at the brush for accumulated matter that collected and stopped the motor and brush from moving. Clean if necessary.
Apr 03, 2014 | Royal 2028 Classic Household Upright...
My Bissell liftoff Revolution won't turn on. Is
Vacuums are not usually fused, but may have a circuit breaker--look for a small protruding button that when pressed, resets the breaker. The plug on the end of the cord may have a wire broken within the plug--replace it with one from a hardware or home center. Another common problem is the power switch may have failed. Order a new one from an appliance parts house. Good luck!
Apr 13, 2010 | Bissell LiftOff Revolution Pet Vac 37602...
I have a BISSELL CLEANVIEW II, I turn the power switch to "on" and am able to clean carpet for 1/2 a minute until the power shuts off in the outlet the vacuum is plugged into! The same repeats itself! I...
well yes in deed it is time for a new vac. for the motor bearings or armature are ceasing up ang causing the breaker to pop. if the vac. cord is hot then you know for sure...
Nov 12, 2009 | Vacuums
I have a Hoover Windtunnel model U5462. Plugged in, turned on, it popped and then no power at all. Not circuit breaker in house. Does the unit have a fuse or something similar?
does it have a headlight and does it work? if so then unplug the vacuum and turn the brushroller by hand a few times.then plug it back in,if it works then your motor might be bad.you can try to spray a little wd40 into the switch then.work the switch back and forth a few times first to get the lubricant worked in to the switch .try to turn it on now.see if you have any cuts in the cord.also see if the cord is pulled out of the vacuum .if so you might have a wire unplugged inside the base of the vacuum
Apr 23, 2009 | Vacuums
Shark Euro-Pro cordless vacuum won't start
Sounds like it needs to be serviced. Call customer service here to help you.
Tel: 1 866 98SHARK (1 866 987-4275)
Is it still under the 1 year warranty.
Good Luck and Please Rate FixYa!
Mar 12, 2009 | Vacuums
Unit will not turn on
Unplug the vacuum unit from the wall. If it is hard wired turn off the circuit breaker
Jul 30, 2008 | Broan-NuTone CV450 Central Bagged Central...
Bissell 6900 stopped working how do I open the thing?
Bissell 6900 Digipro ON OFF Power Switch failed. I found the wire connectors for the power switch were corroded. I fixed this by soldering the wires directly to the terminals leading to the motor. To access the circuit board and the on.off power switch I pryed off the cover for the on /off power switch and the cover for the cord retraction leaver. The covers are held on by two tabs that extend under the red cover on the top of the vacuum. Push the switch cover away from the red cover while prying the cover upwards, You may damage the two tabs on the switch cover, as I did, but afterwards, the cover went back in place and appears to work okay. WARNING: This is a home made repair of a 120 VAC circuit. If you are un qualifued to do this repair you face serious risk of a faulty solder and fire inside the vaccuum cleaner. 4fd9446.jpg78baa14.jpg
Jan 26, 2008 | Bissell 6900 DigiPro Bagged Canister...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
56 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
