Question about Hotpoint WMA50 Front Load Washer
Hotpoint WMA50 How do I change to rubber seal, as mine has been torn? Many thanks Lesley
    Problem Solver:
  • 4 Answers
You can buy a replacement from hotpoint.
Posted on Nov 25, 2010
Please tell me where i can get a new door lock for my hotpoint WMA50
hotpoint website should sell them i got something for my dryer from there.
Sep 27, 2010 | Hotpoint WMA50 Front Load Washer
Where is the water filter kept on the hotpoint aquarius wma50
Remove lower rear panel of washer, locate and remove large black hose fastened to bottom of drum, filter is located inside the hose.
Sep 19, 2010 | Hotpoint WMA50 Front Load Washer
What age is the hotpoint wma50?
It could be anything up to 5 years or more.
Dec 14, 2009 | Hotpoint WMA50 Front Load Washer
My Hotpoint wma50 1000spin is not pumping out all the water
Check /clean filter its located next to sump hose ..Switch off pull plug 1st ..
Oct 02, 2009 | Hotpoint WMA50 Front Load Washer
Hotpoint WMA50 won't final spin, and water stays in drum
Running with a restricted water supply probably took out the pump.
The stator requires a steady water supply for cooling and lubrication. Without this accelerated wear between the stator & magnetic poles occurs.
This additional clearance makes the magnetism insufficient to spun the impellor.
Oct 17, 2017 | Hotpoint WMA50 Front Load Washer
I need to change the door seal on a Hotpoint Aquarius WMA50
Basic diy tools should be ok. Take out lid screws behind plastic caps on edge(will be stars but small flat will do it).Lift front of lid and push back to remove.Remove kick plate and take out screws behind it.Remove band holding front end of seal and detach seal from rim of opening. Remove screws holding door lock and push lock through. Remove soap drawer & take out screws behind it.Carefully bring panel forward & slide to right to remove(Take care here with board &wiring)Remove screws holding front panel & lift front panel & remove it.Remove band from seal and your there.Note locating slot on seal. If possible get an extra pair of hands to hold panel with board to avoid damage.
Nov 16, 2008 | Hotpoint WMA50 Front Load Washer
Hotpoint wma46 door lock
make sure door seal is fitted correctly to the cabinet. you may find that all that is required is to push the door harder than usual till the seal beds in
Mar 29, 2008 | Hotpoint WMA46 Front Load Washer
Top loader
I would check around the door seal see if there is a hole in it, it will probably be around the side somewhere.
Nov 18, 2007 | Hotpoint WMA50 Front Load Washer
Hotpoint WMA50 Front Load Washer Logo
90 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
