Question about Kodak EASYSHARE Z1285 Digital Camera
Kodak Z1285 Won't Turn On?
Hi I got a Kodak Z1285 camera when I try turning it on the blue light blinks and nothing else happens I changed the batteries but still the same? Can you help?
The lens is fully projected out and won’t retract?
It’s a new camera I got it this month it worked fine at first but yesterday when I try to turn it on it just wouldn’t.turn on :(
  • 9 more comments
  • Roak Jul 29, 2008
    Yes at the first try it attempted to turn on and the lens projected out like normal but then the power light went out and the lens remain out I changed the batteries and when I turn it back on the power light only blinks and nothing else happens
  • Roak Jul 30, 2008
    Ok guys I got it to work, a gentle tap on the side and it turn on and working properly
    Cheers
  • Anonymous Aug 21, 2008
    Amazing. Same problem (turned on, lens out, blue light, turned off with lens still out). Nada in the manual. Tapped, hit button. Works fine again. Very odd.
  • Anonymous Aug 29, 2008
    Bought a Kodak Z1285 and have found the memory card makes camera turn off after attempting to take a photo. Removed memory card for now.
  • Anonymous Jan 26, 2009
    ok i bough a kodak easy share z1285 and it worked fine out of the box and now when i try to turn it on the screen flashes and the blue light comes on
    !!!!!!!HELP!!!!!!!!!
    i have the same camera
    i tried the them tap trick and it still wont work
  • Anonymous Feb 24, 2009
    i mm having error L 03
  • Anonymous Mar 11, 2009
    My kodak md853 wont turn on!
  • Anonymous Mar 26, 2009
    My camera had the EXACT same problem and until I found this website and tried the tap nothing worked but the blue light. But hey, the tap worked great! So I'm wondering if there's something inside that was blocking the lens from retratcting and the tap disloges it? Does anyone know of a way to directly report to Kodak about this problem?
  • littlelauer May 07, 2009
    Same problem here.. taped the back side of the camera... then it worked and closed up and now turns on. Odd.
  • jamie Aug 13, 2011
    hey everyone with the problem with it shutting off when lens extends listen up!
    i have managed to find out Or so i i think,
    it has worked on three z1285's
    open up the acess point screws, and lift the flaps and carefully prise apart the rear chassis of the camera, here you'll see the led screen and the white button chip.
    at the top of the led screen you see two tabs to relaese the screen, then where the white button chip leads to the main board there is a little black color that you have to lift to release the buttton chip.
    now you should have the empty metal chassis, unscrew at the two points.
    now the rear of the lens should be visible remove the silver screws and take of rear casing, you will see at the bottom right a kind of black fabric nxt to the magnetic color, tuck it in with a very small blade or prescision screw driver.
    attach the led screen and the white button chip on loosely and turn on the power to see if it has worked. if so turn it off place EVERYTHING back together carefully and your all done :)
    please email me for clarity on the subject or tell me if it has worked for you,
    regards
    Jamie Berry
    jamie.l.berry@hotmail.co.uk
What a silly solution... and yet... it worked like a charm for me. So, here's what I think is going on. When this happened to me I think my batteries were weak. I think the stepper motor has just enough juice to extend the lens to a partial step. Then, stuck between the steps the camera can't boot because it can't move the lens. Tapping the camera jars the stepper to the next higher or next lower step and then the camera can boot up.
Posted on Sep 27, 2010
  • MajorDee Nov 29, 2010
    OMG. It worked! Bet the tolerance on the internal gears for the lens are extremely tight and they can bind if the battery power is too weak to recover the lens once it's extended. Thanks for the help!!!!
HAd exactly the same issue! You turn on the camera, lense comes out then the screen goes black (turns off)
The blue light stays on and the only way to get it to turn off is to take out the batteries.
Next time you turn on the device, the blue light comes on and the green led flashes, sometimes it powers down and other times the blue light stays on but you have no screen still. The lense stays out.
I tried the "tap" it approach and it now works fine! My suggestion has always been, if it don't work, kick it!! why didn't I try this with this camera firstly instead of trying all sorts of different button combinations to see if there was some sort of hard reset for it?
Thanks for the advice everyone and happy snapping!! :)
Posted on Dec 24, 2008
Same problem, lens extended and blue light on for fraction of a second. I've wrapped the camera with a towel and tapped at its back. Wonderful !!! Worked for me. I'm very happy. Thanks to you all folks !!!
Posted on Apr 26, 2010
  • proximages Nov 29, 2010
    Batteries must be well charged. Since I bought 4 Sony 2000 mAh everything is working fine. When the charge goes down I usually have the same problem and the litlle knock still works. The best for me is to have the other pair of batteries charged and replace them inmediately
Hey everyone with the problem with it shutting off when lens extends listen up!
regards
Jamie Berry
Posted on Aug 13, 2011
    btw i will not take responcibilty if you ****** it up........ do it at your own risk :)
There something missing here? You say it wont switch on but the lens won't retract?
But the lens retracts when you power down the camera?
You've missed something out ?
Posted on Jul 28, 2008
I tried tapping the back, but the lens is still extended and the blue light turns on for about a second, then the camera dies again.
Tried tapping it, didn't work (i tried tapping each side and then doing so with quite some vigour, still no success)
Posted on Jul 14, 2010
After taking one picture with my Kodak Easyshare
I've had a similar problem with my Z1285.
The problem is probably weak batteries. The Z1285 requires really good batteries. Standard alkaline batteries don't last very long, perhaps a few dozen shots, less if you are using flash.
I've had success using lithium batteries, not the rechargeable type, but the disposable lithium. Specifically, the AA4 Energizer Ultimate Lithium.
Hope this helps.
Jul 01, 2010 | Kodak EASYSHARE Z1285 Digital Camera
We have a kodak easyshare Z1285, it is only 1 year old and the last time it was used the lense extended and the camera will no longer turn on. We have tried new batteries, no change.
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 04, 2009 | Kodak EASYSHARE Z1285 Digital Camera
Optimal Zoom lens not retracting and does not turn on
Have you tried purchasing a new set of batteries and installing them into the camera? I know you said the previous ones were fully charged but if you put the batteries on the charger when they are not completely discharged they will give a false charge... It's the same issue with cell phone batteries you have to let it die as much as possible before charging to avoid battery cell disintegration..
Jul 08, 2009 | Kodak EASYSHARE Z1285 Digital Camera
Anything bright on outdoor pictures turn out pink on Kodak Z1285. What do I do to fix this?
my first guess WB setting
pls change the White Balance setting to normal and check if you have the problem rectified
cheers
pls rate if it was any help
Jul 04, 2009 | Kodak EASYSHARE Z1285 Digital Camera
Camera lens extended and blue light comes on. That is all. Cannot turn light off or retract lens Kodak Easy Share Z1285
The Lens Barrel gears are damaged ...... Get it changed by a repairman please
Oct 16, 2008 | Cameras
KODAK Z1285 BRAND NEW BATTERIES ..WHEN I TRY TO TURN IT ON THE SCREEN BLINKS THEN GOES DEAD .. THE CAMERA IS ONLY 3MO OLD AND NEVER DROPPED OR ANY DAMAGE ..
Only specific batteries can be used with this camera, look closely at the battery door. Alkaline batteries are NOT listed. You MUST use NI-MH or Li-Ion. Hope this helps...
Aug 19, 2008 | Kodak Cameras
No power to my new Kodak - Series 3 EasyShare Dock for Select Kodak EasyShare Digital Cameras
Hey ditzydiana,
If you just purchased the camera and you are already having problems with it I would not try to troubleshoot the problem I would exchange it for a new one. If you purchased the camera from a Best Buy™ store the return/exchange period on the camera is 14 days. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 27, 2008 | Cameras
Kodak EASYSHARE Z1285 Digital Camera Logo
2,798 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
