Question about Microsoft Windows Vista Ultimate Edition
VB6.0 how to get a virtual image of XY axis motion in an image(when finding pixel values)
  • pandey_ruchi Sep 21, 2008
    how to create a thumbnails with vb6.0
Serial wndows vista ultimate
Posted on Jul 29, 2008
Seriel w indows vista ultimate
Tip
Choppy image transitions when you view images by using the Slide Show
You experience choppy image transitions when you view images by using the Slide Show feature in Windows Vista and in Windows XP SP2 Windows Vista
1. Click Start , click Run , type regedit , and then click OK .
2. Locate and then click the following registry key:
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows Photo Gallery\SlideShow
3. On the Edit menu, point to New , and then click DWORD Value .
4. Type WinSATScore , and then press ENTER.
Right-click WinSATScore , click Modify , click Decimal , type the value that you want in the Value data
box, and then click OK .
Note To start the Slide Show feature by using different resolutions, type one of the following values in
the Value data box, as appropriate for your situation:
5
• For a resolution of 1200x1000 pixels, type 300 .
• For a resolution of 1600x1200 pixels, type 400 .
• For a full-screen resolution, type 500 .
Exit Registry Editor.
on May 25, 2008 | Microsoft Windows Vista Home Premium with...
What is the master XY SCALE
Press *28* then touch the adjust, increase/decrease the value to x scale to adjust the position of x axis, also increase/decrease the value to y scale to adjust the position of y axis
Sep 29, 2012 | Canon imageRUNNER 400S Copier
My acard technology pro burns dvds but the target dvds end up all scratchy like quality the pixels move and everything
is resolutions pixel problem only on the dvd disks you burn?
you might have to save the dvd to a file first then burn it to a dvd
are you copyning from another dvd or from a saved file ??
you might be burning it as data
this might be a problem with the quality of the dvd disks you are using or might be the software you are using there are lots of free burning sofrware programs on the internet
this might be because you have not selected the option to burn an audio or data dvd or your burning software does not support dvd burning
there are plenty of free burning software programs on the internet
http://www.majorgeeks.com/BurnAware_Free_d5839.html
BurnAware Free is one of the most popular free CD, DVD, Blu-ray Disc burning software available for Windows.
Using this program you can easily create and burn Audio and MP3 CD, Data and DVD-Video disc, ISO and Cue Image,
erase or format rewritable disc, copy your CD or DVD to ISO image.
http://download.cnet.com/magicdisc/3000-7970_4-10383679.html
MagicDisc Virtual CD/DVD-ROM is a utility designed for creating and managing virtual CD drives and CD/DVD discs. MagicDisc Virtual CD/DVD-ROM emulates audio, data, and game CDs and DVDs with ISO image, CD and DVD images. MagicDisc Virtual CD/DVD-ROM offers 200x speed and noiseless CD/DVD access without a physical drive. It supports creating up to 15 virtual drivers. You can run games, software, see movies (VCD, SVCD, DVD), and hear music directly from your hard disk without inserting and swapping CDs and DVDs. MagicDisc allows you to use almost all CD/DVD image without burning them onto CD or DVD in order to easily access your favorite games, music, or software programs. It works like a real CD/DVD-ROM: You can run programs, play games, or listen to music from your virtual CD-ROM. It can compress ISO CUE MDS NRG CCD image; can encrypt ISO CUE MDS NRG CCD image; can make ISO image from CD/DVD; It can mount UDF only CD/DVD image and multi-session MDS/MDF and CCD/IMG image.
hope some of this helps you
Sep 10, 2011 | Acard Technology (ARS-2030LD) DVD±RW...
How to get no. of pixels from given image through java
try to embeed the following coding
class ImgMod02 extends Frame{
Image rawImg;
int imgCols;//Number of horizontal pixels
int imgRows;//Number of rows of pixels
Image modImg;//Reference to modified image
//Inset values for the Frame
int inTop;
int inLeft;
Mar 27, 2010 | Computers & Internet
Why is it true that at x-intercept, the value of y is0, and at y-intercept the value of x is 0?
The x intercept is where the value of y when graphed lands directly on the x axis. The value of y anywhere on the x axis is zero. The same is true for the y intercept producing an x value of zero. The point at which the graphed line intersects the y axis gives an x value of zero. The value of x anywhere on the y axis is zero.
Jan 19, 2010 | Mathsoft StudyWorks! Mathematics Deluxe...
Error code 05,004,44:11367 on Xerox phaser 8560DN
Hi tonyswain:
This is your problem.
Run the Y-axis Drive test.
2. Check the current values.
3. Are the values within normal operating
range?
Go to Step 5. Replace the
Y-axis motor.
5 1. Run the Y-axis Belt Tension test.
3. Are the values within the normal operating
range?
Go to Step 6. Replace the
Y-axis belt.
6 1. Run the Y-axis Motor test.
2. Did the tests pass?
Replace the
drum assembly.
Replace the
Y-axis motor
Hope this helps
pdouglasss@hotmail.com
May 22, 2009 | Xerox Phaser 8560DN Laser Printer
Recorded pixels & file type are supported?
Still image (JPEG):2880x2160 (interpolated), 2048x1536, 1600x1200, 640x480 Movie (Motion JPEG (MOV)): 320x240, 160x120
Sep 19, 2005 | Konica Minolta DiMAGE E323 Digital Camera
How was EVF improved?
This camera is equipped with the TFT micro display which has about four times the resolving power (number of pixels) of past models. As a useful mode, it has "Quality mode" of 640x480 pixels (30fps) and "Motion mode" of 640x480 pixels (60fps). Quality mode: The high resolving power is the most important. The detail parts can be recognized, and it is helpful when the focus is checked. Difficult focusing on the past models can be easy without enlarging. Motion mode: It is for recording the moving subject. The same number of resolving power is displayed as the quality mode. However, as the pixels are interpolated from 640x240 to 640x480 in Motion mode, the image in the Quality mode looks better.
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
Microsoft Windows Vista Ultimate Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
