Question about RCA D61W20 61" Rear Projection Television
Television cuts off
It has been actin okay but for the last two weeks sometimes the tv will stay on then at other times you cut the tv on and about 5 mins later it shuts off and wont come back on until about 10 mins later and will repeat until it starts working again. what could be the problem?
  • 2,920 Answers
Weak power supply
Posted on Sep 03, 2008
Why won't my Samsung LCD tv boot properly at startup
Hi Tom,
This is becoming a theme with Samsung TV's, Samsung have extended warranty cover for some customers with this problem, have a look at this post for more info and the link to Samsung:
have 60 Samsung led tv Sound keeps cutting out all night for 3 5 seconds...
Feb 13, 2016 | Samsung 9000 Series UN65F9000AF 65" 4K LED...
TV keeps cutting off
A very common problem for this set has been bad electrolytic capacitors on the power supply. There are 2 in this model that are 1000uf at 35 volts that will commonly cause this. When they go bad they will normally be domed or mushroomed on top rather than be flat, so they should be easy to locate. If you can solder, they would be easy to change yourself. You can get the caps just about anywhere online for only a few dollars. A repair shop would probably charge around $100 to make this repair if it is indeed bad capacitors.
Jul 31, 2010 | Insignia LCDTV26 26 in. Television
My panasonic pt50lcx64 will not stay on, sometimes wont even turn on, but when it does, it lasts about 5 min then cuts off and the yellow light blinks 2x every 5 sec
Try typing your model tv along with the words "trouble codes" This could be a code 22 or a 2. Sounds like a bad connection or bad component failing such as capacitor or resistor. The tv may be shutting down as protection against what it senses as a power supply failure.
Jan 08, 2010 | Panasonic PT-50LCX64 50" Rear Projection...
Engine managment light stays on constantly aand when starting the car it cuts out after 5/6 times trying it starts. on long jornets in traffic the car feels like its gonig to cut out and the oil light...
I had this problem jusrt before last week-end with my Leganza. Sorry to say but it was the BM Bearing and it is now going to wrecker Heaven. If it is the same your motor is about to blow up.
Hope not for you
Aug 12, 2008 | 1999 Daewoo Leganza
Sony KV32s22
Hi: Sounds like it might be an overheating part, and the short is shutting of the set. Or it could be an intermittent connection in the pc board. Either case it would have to be repaired by a expert.
Mar 11, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv cuts off and on.
Sounds like a bad SSB(small signal board) module. Better take it to a RCA AUTHORIZED service center.
Sep 06, 2007 | RCA D56W20 56" Rear Projection Television
This sounds like a protection system cutting in. This happens if there is a major fault and continual use would lead to a fire risk.
Aug 09, 2007 | JVC AV-27F702 27" TV
RCA D61W20 61" Rear Projection Television Logo
118 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
