Question about Garmin StreetPilot C330 GPS Receiver
Reset My Garmin just stopped. I reset and it came on. Then it went off again. I reset again , it came on then quickly blinked off and I can not get it to come back on.
  • rixsaw Aug 16, 2008
    my c330 shuts off after being on only for a few minutes. battery is fully charged. fuse in plug is good. have gone through the reset steps....but still shuts down. any ideas? thanks, rixsaw
  • Anonymous Aug 17, 2008
    the street pilot comes on for a second and then turns off. It will not stay on
I had this same problem for a few weeks, contacted Garmin and was surprised at how simple the solution was!
On your car charger, unscrew the part that goes into the lighter- counter clockwise--be careful because there are peices stacked on top of eachother. Once opened, you should find a long glass fuse. Just replace that fuse, and it works like a beauty! (I bought a 5 pack for like 3 dollars at auto zone).
Before this I had done all sorts of resets & all, and this actually fixed my problem!
Posted on Jul 31, 2008
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
My garmin 1300 went completly dead while on a route with the power cord attached. Unpluged tried again . Now its working. Is this normal?
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 15, 2010 | Garmin nuvi 1300 Car GPS Receiver
Alarm keeps blinking
Hi there you can only try it may work for you.
Canon MP170 (Ink Tank Full Error):
1 - power off.
2 - hold stop/reset ,hold ON/OFF
3 - release stop/reset, push stop/reset twice, quickly, then release ON/OFF
4 - wait untill LCD display shows "Canon Idle",then push stop/reset four times, quickly
5 - then push power twice, quickly
6 - power off and power on.
Feb 11, 2010 | Canon PIXMA MP170 All-In-One InkJet...
My Garmin 305 edge does not work correctly
Normally with Garmin sat-navs you have to switch the on/off button off and hold for around 8 seconds to reset the device
Feb 01, 2010 | Garmin Edge 305 GPS Receiver
Garmin Nuvi 650 Touch Screen trouble...
Yes, this is a common problem with a new style screen being used by SHARP. Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Dec 07, 2009 | Garmin GPS
Garmin Nuvi fails to work after firmware update
When a Garmin Nuvi 205 stops working or behaves strangely, there are two steps you can take yourself to try and get it going again:
  1. Perform a Hard Reset,
  2. Run WebUpdater to reinstall the firmware.
I hope that helps.
Sep 29, 2009 | Garmin nuvi 205 GPS Receiver
Can get directions
First, has anything changed with your operating conditions? Different location in car? Different car? Does it do it when outside, in the open? (not in vehicle or building)
Have you tried a hardware RESET? The button is hidden behind the front panel, which snaps off by a fingernail slot located directly under the GARMIN logo on the front panel.
* Use caution removing and reinstalling the front panel... it's somewhat fragile... wiggle it a little to get it off.
Press where it says "Press to Reset", hold for a second or two. Charge the unit with the car cord or USB cable, then try to turn it on again.
Once you can get the unit to (hopefully) turn ON, you should run all updates (there may be several!) using Garmin's Webupdater. (Connect to computer with USB cable first.)
Hope this helps!!
Jul 15, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c550 GPS-Won't turn on at all.
could the battery be dead? Leave it to charge on the wall charger for several hours. Then try again. There is a way to do a hard reset....
Jun 08, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi GPS Stopped working
Hey everyone I might have the solution:
Just got done "fixing" mine, turns out it didn't need any fixing whatsoever, just an update.
I had the same problem most of you seem to have:
Device: StreetPilot C340 worked great when I bought it and for months until one day, it just doesn't turn on...wtf right?
I was halfway done with tech support for an RMA request, (some of you might still need this) and that's when I noticed the usb input on the side of the device (like most of you I thought, why the hell does it even have one?) I plugged my universal camera usb cord into the pc, (At this point the device was on! and charging too!) and went to the garmin website, feel free to search but you will end up with this page:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
pretty straight forward after this, follow the step by step depending on whether you have a mac or pc, download and run the "webupdater" mine was for windows, so I ran this all the way through and bam your good to go, you even have the option of updating the voice and language preference after the initial updates.
hope this helped everyone!
Nov 13, 2007 | GPS
Garmin StreetPilot C330 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
