If you have had all them parts changed and its binding one moment then not working correct. the possible problem can be the abs unit, when you apply the brakes the abs controls the pressure. if the vale in the abs unit is faulty you can get this problem and worse. you may not even get a code as the coil is still fine is just its stuck. i would have this part checked or replaced.
SOURCE: 2002 GMC Sierra 1500 rear brakes
Hi joelalthomas, if they replaced your brakes and you never even made it home they had better warranty the work and as for the "it was a common problem on 2002-2004 trucks" well check for Chevy recalls as this is a safety issue that would have been corrected at no expense to the vehicle owner, do a little more research my friend and let me know what happens, I will check around a little as well in the meantime I would find a new garage.Do not pay any more as you said your brakes worked fine until they worked on it good luck to you As for your 4x4 did you look at the left side when you did the right side? and were they bled off properly? you can visually check to see if the calipers are functioning
SOURCE: How To Change Rear Brake Pads on Audi A6 2006
Remove the tires, Remove the calaper bolts, (small heads on them 12mm or so) Remove calaper, Pads are setting in a holder. Lube new pads with litheum grease and place in holder. (look at old pads, one or both may have small metel tab on one end) If the new pads have the tab, put that pad where the old pad with the tab was. (ie. tab to the inside) Press pistion in with a 'C' clamp. If it won't go in easly, it may screw in. If the parking brake cable is hooked to the calaper, it probly screws in. Use large pliers to screw in calaper piston. Place calaper over pads and install bolts (lube bolts) Rember to pump brakes befor driving . to get a solid peddle.
SOURCE: I have an audi a6 2.5tdi v6 multitronic automatic
Ouch, I suggest you check the fluid level of the transmission. If the fluid is OK, you need to ask around about a good gearbox repairer.
SOURCE: I have a2002 2.5 audi a6 how do i check the
you cant check the Transmisson oil by yourself it is located under the vehicle. you will need a hoist to lift it up and then go by the transmission and check it there.
SOURCE: Audi A6 RPM Signal from ECU
dont think you are reading the codes right because PO in front of the code is not a genuine Audi code ,well not according to my information ,try autozone who issue these codes or a snap on code reader booklet
