Question about Maytag Dryers
My new dryer is makeing thumping noises when its runningsounds likr a pair of shoes are in it
  • Anonymous Mar 27, 2014
    Thump thump pause thump thump
    Novelist:
  • 116 Answers
Depending upon the model the drum rests on a set of rollers or glode strips. If the drum has a flat spot or overly large seam then it will thump. If the thump is about once a second.
I have seen this a number of times on the Performa line. The drum needed to be replaced to correct it.
Alternately if there is a flat spot on a roller it will sound faster than once a second.
This is usually covered under a manufacturers warranty.
Posted on Jul 28, 2008
Kenmore dryer making a thumping noise
Your dryer has rolls on the drum and they are going bad and need to be replaced
Mar 22, 2014 | LG DLG3788W Gas Dryer
Creda simplicity TVU1 tumble dryer is making a thumping noise while drying
Hi dave hemming.
I do not believe it is a bearing that is causing your thumping noise
No...you do not need a new drum...all you need is new drum rollers
You probably have a flat spot on one of the rollers, it will make the thumping sound when the drum rotates.
Go to the following webpage and get your drum rollers and install them and that should take care of the noise you are hearing
Please take time to rate me
Bud
http://www.appliancepartspros.com/index.aspx
Oct 13, 2012 | Dryers
I have an electric frontload dryer. If I turn it on with nothing in it, it sounds like there is a shoe tumbling around. If I open the door and spin the drum by hand, each revolution the drum makes, there...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Nov 22, 2010 | GE Dryers
Dryer makes a "thumping" sound even when it is running and clothes are not in it. Sounds like a pair of shoes are in there being dried.
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 18, 2010 | LG DLE3777 Electric Dryer
SOUNDS LIKE YOU ARE DRYING SHOES IN THE DRYER. EVEN WHEN THE DRYER IS EMPTY!
Bad rollers
These rollers get a flat spot on them and make a thump type noise with every revolution. More HERE
Jun 10, 2010 | Kenmore Rear Control 8885 Dryer
Thumping noise (similar to shoes drying) and burnt smell
that one needs a serviceman to look at it too many variables as to cause
Jan 23, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
Maytag neptune dryer making a thumping noise while drum turns, as if there were a tennis shoe in it, but there isn't? Ideas?
heatman101
Jan 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Clunking noise, like a tennis shoe, top right rear of dryer
HI sounds to me like your drum support is worn, it would make a thumping sound. You have 2 you should replace them both.
If you are needing a part - call this toll free number 1 877-489-5610, I have used them many times, they are the best. Best of all overnight shipping!
Sep 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Thumping noise in atlantis dryer after drying heavy mattress pad
Have you husband do a visual inspection of the drum and literally feel it to see if anything is caught or stuck on the drum. The motor also may have something caught in it as well. This would be the motor that turns the drum.
Dec 15, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
LG ELECTRIC DRYER
Henry, its going to be 1 of 2 things. Check inside your drum, see if the vent in the rear has burning or discoloration around it. If it does, it sounds as if your vent is restricted causing the unit to overheat, so clean/fix/replace the venting and your support pulleys will need to be repalce ie flat spots from overheat. If there is no scoarching marks and you know its not the vent or heat issue, the drum seam may have parted causing the thump as every revolution is made.
Apr 04, 2008 | LG DLE2514 Electric Dryer
Dryers Logo
156 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
