Question about Lasko 5440 Ceramic Compact Heater
Rattel inside LAsko Uprigth twoer fan
I purchased a Lasko Upright fan for my office around a year ago. It has just started making a rattling noise. I checked the obvious things like lose fastners and everything is good and secure. The nosie sounds like it is coming from inside the fan housing. I run this fan very litel as must of my day is spent in the field, my first thought is a bad bearing. What do you think?
  • rwrollins Jul 28, 2008
    Thanks for the information, I'll try your sugeestion and let you know the results.
    Wayne
  • 304 Answers
I would assume your diagnosis is correct for the most part. In these units they use less costly bushings in in place of bearings. The original lubricant in your bushings has dried up which is a very common problem in heaters. The heat tends to cause lubricants to evaporate. The first thing you want to do is oil these bushings with a heavy oil such as 90 W gear oil. Any motor oil will work fine, but the heavier the oil the longer you will be able to go between lubrication cycles. If the bushings are out of acceptable tolerances that lubricating does not cure the problem the only other way to fix this is to replace the bushings or simply replace the unit. I hope this was helpful. If you need more help with anything post it here and I will help you for free. That way you will get me when you need free accurate help.
George
Ps. Make sure you do not use excessive oil as this is a heater. You can go to the pharmacy and purchase a syringe like a 18ga 1 inch to use to apply the oil. Just tell them what you need it for so they don't think you are going to use it on yourself.LOL. This is what I use, You do not get oil all over the place when you use a syringe. Hope to here back soon. Keep me posted hoe you make out.
Posted on Jul 28, 2008
  • George Kohler
    George Kohler Jul 29, 2008
    When it works see if you can go back and re rate this fixya. If the oil does not fix your problem changing the bushings if they are damaged definitely will. As long as the bearings are not too bad the heavy oil will work.
    Thanks George
How to grease or oil a lasko fan model u15700
when a fan makes noise while turning,means the bearing is,
starting worn out.best to replace it.when its not turning,its allreddy,
overheated.
Jun 05, 2014 | Lasko Max Performance Pivoting Utility Fan...
Lasko tower
it will need the bearing changed. you can get copper bearings off ebay you just need to know the size or motor number.
Sep 28, 2013 | Lasko 2115 Wind Tower Fan
The fan makes an odd noise as if it were out of
Recalled: Discontinue use and see
http://www.laskoproducts.com/recall/recall_heater07.html
or call Lasko Products toll free any time at 1-800-984-3311 to receive a free replacement heater.
May 09, 2010 | Lasko 5362 Heater
Lasko ionizer 48" fan
Hi suedevito,
In case an electrical appliance does not do anything anymore, I always first check the fuse(s). There can be a fuse in the electrical plug (in case of UK-type of plug for example) and possibly also somewhere within the fan's housing. In case you do not know how to measure a fuse, just simply replace all the fuses in one go with a new fuse of the same (!) rating. I hope this will solve your problem.
Nov 08, 2009 | Lasko 48" Xtra Air Tower Fan with Air...
Lasko Box Fan Stinks!
same thing with my lasko box fan awful oil smell
Aug 05, 2009 | Lasko 3720 Floor / Box Fan
Loud noises from Lasko fan motor?
The problem most likely lies within the fan motor of your Lasko unit. I just got fed up with my Lasko tower fan (model 2515) making a rumbling noise on and off and so I took apart the entire thing. I found the noise to be coming from the Decomin 2033014 motor in the unit. Took apart the motor and found that it is so cheap that it doesn't even have bearings! Just a few plastic discs on a spindle. I tried greasing the discs again but it didn't work. The only solution is to get a new motor. I am really disappointed in the quality of these Lasko fans.
Jul 07, 2009 | Lasko 2530 Elite WindTower Fan
Lasko 2535
Lasko 52" tower fan, model 2535, works fine but has the annoying loud 3 second beeeep when turned on/off, waking us up at night. Have been unable to get at the circuit board to investigate due to non-std screws (regular slot head but with a bump in middle of slot, so slot is filled in in middle of screw head, if you will)
Any thoughts on killing the beeeeping?
Mar 09, 2008 | Lasko 2535 Stand (Pedestal) Fan
Broken bracket on lasko pedestal fan
I have the same problem. Called Lasko parts department and got one. http://www.laskoproducts.com/
Description of part on invoice - 05098021T BAG HDWR BASE T/BLK 30PTEXTURE BAG
Cost $7.50 for part plus shipping to me was at $6.61 so it was pretty cheap. Comes as a package with four screws/washers/nuts. Hope this help someone out there.
Sep 08, 2007 | Lasko 3135 Stand (Pedestal) Fan
LASKO fan problem
Check for a loose wire in the wiring harness
Sep 01, 2007 | Lasko 2530 Elite WindTower Fan
Lasko 5440 Ceramic Compact Heater Logo
937 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Steve Oakes
Craig Butler
Craig Butler
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
