Acs 755 a2
Ded leds ..............help .............................pwr btn work only for start then nothing happend if pressed ................help help help help pls
  • 2,427 Answers
Basically your bios need resetting or clearing there are 2 ways, you can use your main board manual to locate the jumper as descrobed below or if you cant find it or that fails then proceeed to the other method described.
.) Find the Jcmos or Jp1 or JBAT jumper located on the board. Its a 3 pin jumper currently set to 1 and 2,,, set it to 2 and 4 wait a few then set it back to 1 and 2.
If you cant find the jumper or that fails then
  1. Locate the battery on the main board
  2. unplug the system then remove the battery and the memory(rams)
  3. press and hold the power button for 3 seconds
  4. release
  5. replace the battery then the memory (rams)
  6. pulg in the system and turn it on, it should boot
  7. load the optimised defaults by entering setup , follow the on screen instructions to do this
  8. thats it your done
Posted on Jul 29, 2008
How can i correct the front panel connections
your motherboard has three sockets for the front panel connection:
-USB socket, to connect any front usb ports you might have
-AUDIO socket, to connect speaker/microphone socket on the front of your case
-FRONTPANEL socket, where are connected the turn on/reset buttons, the ide/power leds and the buzzer. To connect all the pin in the right way, refer to the attached picturefranzer_2.jpg
Hope it helped,
Franz
Mar 02, 2011 | Gigabyte GA-8SMML Motherboard
I need a manual so I can set-up board HD LED, PWR LED PWR BTN, RST BTN SLP LED/BTN, etc.
http://www.ecs.com.tw/ECSWebSite/Index.aspx?MenuID=0&LanID=9
This is the ECS website. Try the downloads section and in the search put in your model number to see what resources they offer. If that does not get you anywhere, in a google search type the model of your motherboard there and put manual after the model number. That should let you find it.
Cheers!
Oct 28, 2010 | EliteGroup Computers & Internet
Here you go! :)
http://download.intel.com/support/motherboards/server/s5000pal/sb/d31968004_s5000pal_userguide.pdf
Cheers!
Oct 28, 2010 | Intel S5000PALR Motherboard (891957) USB...
Where can I fine manual for 755-A2 I went to EliteGroup www. No luck. Can you please HELP. Thank You
Try this:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=381&DetailName=Feature&MenuID=1&LanID=0
Sep 26, 2010 | EliteGroup ECS 755-A2 Motherboard
ECS 755-A2 won't go past BIOS Screen
do you have the setup cd that came with the board. the drivers probably need to be installed. if so run the disk and install the drivers and it will work.
Mar 13, 2009 | EliteGroup ECS 755-A2 Motherboard
Wiring color code sequence for the pins to the front system panel for an asrock p4i65g motherboard. There are 4 double pin connectors. Jim/Sudbury
Can't say what the colours on your case wires are because they do vary but they should be marked up PWR SW (or PWR BTN), HD LED, etc.
Looking at the pin layout there should be a row of four with the pin on the far right missing and underneath a row of five with the last one on the far right being unused.
12 3 4
OOOO
5 6 7 8 9
OOOOO Pins 3 and 4 are PWR. Pins1 and 2 are PWR LED.
5 & 6 are Hard drive and 7&8 are reset
Feb 22, 2009 | Asrock P4i65G Motherboard
I have an emachines t6520 and the power sw wire, HDD led wire, and the power led wire hve been disconected
On the system board, on the left edge next to the primary IDE connector, there is a 9 pin header.
I usually get a magnify glass and look down on the header . From right to left,you will see PWR led pins closer to the edge of the motherboard.and the Power BTN next to it.(the side of the pins that has 4 pins on it)
Then on the other side, you will see the pins for the HDLED across from the PWR led. Then the Reset pins across the PWR BTN.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 29, 2008 | E-Machines eMachines Desktop PC
ECS 755 A2 motherboard problems
Make sure you have the correct front panel header connected correctly to the case wires. Open you're manual to page 12 under the English section. There you'll find a picture of the front panel header & how to connect the case's LED's to the motherboard.
If you no longer have the manual you can download it from ECS at this link.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=381&DetailName=Manual&MenuID=1&LanID=0
Chances are you may have the wire's connect backwards. (Positive + connected to the negative - ECT).
Example, pin 1 is the + for hard disk drive & pin 3 is - for the hard disk drive. Cases vary on wire colors, normally if each connector has a common colored wire (solid color) that common wire would be the negative. Stripped wires are negative. Other cases use white colored wires as negative & colored wires as positive. As far as you not receiving any display. Try removing the AGP card & clean the copper contacts. Clean with alcohol.
Place a couple drops onto a cotton swab & clean the copper, both sides. Blow out the AGP slot with canned air. Re-check all connections, power & data cables before closing the case. Power on the system & check the front led's for operation.
If you still fail to get display, re-check the connection from the monitor to the case. Try you're monitor on another system. If good than you're video card could be bad. You're motherboard can run an 8x/4x speed AGP 1.5volt (only) graphics card.
Good luck zeratu_l !
Need more help? Post within this link.
Mike
Jul 28, 2008 | Computers & Internet
Motherboard
Well you really need to get a manual for that. Check the website and download the manual with that model, for sure there is one.
I guess you have connected all the connectors there incorrectly so better look for a manual.
Dec 09, 2007 | EliteGroup ECS 755-A2 Motherboard
Computers & Internet Logo
563 people viewed this question
David Payne
David Payne
