Question about Sony Cameras
Wish to know if you have a special program similarly to ADOBE
  • 10,594 Answers
Sorry, can you explain what you want to know...
Posted on Jul 28, 2008
Adobe Illustrator file
Hello Philip.
Try a special program Illustrator Fix Toolbox https://www.fixtoolbox.com/illustratorfix.html
If it couldn't aid you:
1) Open the preferences file and look for the entry named "enableContentRecovery", change the value from 0 to 1. This turns on the feature.
2) Launch Illustrator and choose "File>Open". Select the file from which you wish to recover the roundtrip information.
3) Click "OK" .
Aug 13, 2016 | Adobe Computers & Internet
Special programs needed to allow the user to view special effects such as sound, flash animations, etc
Go to the ADOBE.COM website and download the free FLASH PLAYER program.
You can find this at the following link:
http://get.adobe.com/flashplayer/
Just click on the underlined text above to get to the ADOBE website.
Follow the onscreen instructions to install this program and this should allow you to view flash animations online.
Thank you for using FIXYA.
Good luck and take care.
Joe.
Jul 23, 2013 | Computers & Internet
There is no MB showing under my Adober Reader 9.1.3
Adobe is a document display program in the computer with several functions. First tyoe written documents from several computers appear encoded in different formats requirng programs that decipher between versions. Adobe performs fucntions similar to microsoft word program as document reader. The improved features allows documents that were created with unique features either pictures, videos, or on programs least common to every computer become observable. Second, adobe programs inclodes features that deciver several media files beyound documents. Files of picturegraphy, videography and encriptions that are made from outdated computers or peculier programs are displayeable on the adobe program. The program has sveral versions that achieve productivity differntly. Prior versiosn adobes softwares were compartible to older computers. Acquirng adobe requires the latest versions to make posible most productiveness.
Feb 06, 2011 | Computers & Internet
How to change code I don't know the product
"How can I program my electronic keypad lock when the instructions with the Programming Code have been lost?"
The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
Complete installation & programming instructions can be found here:
http://consumer.schlage.com/Project%20Documents/P515-858.pdf
Notice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Videos for installing and programming can be found on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Scroll down and find them under the heading Electronic Security--Keypad deadbolt 365
Good luck--and please provide feedback if this helps!
Oct 24, 2010 | Schlage BE365-PLY BE365PLY626 Satin...
Every time I try to open the program, I'm getting this: Adobe Photoshop Elements 6.0 (Editor) has stopped working. Windows can check online for solution to the problem. Check online for a solution and...
Do Solution 1 first, then try Solution 2. Proceed to Solution 3 only if you wish to operate your device directly from within Photoshop or Photoshop Elements Editor.
Solution 1: Disable the TWAIN plug-in. Photoshop and Photoshop Elements Editor do not load plug-ins whose file name begins with a tilde (~). Rename the TWAIN plug-in to prevent Photoshop and Photoshop Elements Editor from loading it.
To disable the TWAIN plug-in:
  1. Do one of the following:
    • If you are using a 32-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    • If you are using a 64-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files (x86)\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    Note: If you do not know which edition of Windows you are using, see Determine whether your computer is running a 32-bit or a 64-bit edition of Windows (kb407673).
  2. Rename Twain_32.8BA to ~Twain_32.8BA. (You may not see the filename extension .8BA.)
When the TWAIN plug-in is disabled, you cannot operate your device by choosing File > Import > [Device name] in Photoshop or Photoshop Elements.
If you do not wish to operate your device directly from within Photoshop or Photoshop Elements, then you can use other software -- such as the software that came with the device, the Windows Scanner And Camera Wizard, or Windows Photo Gallery -- to operate the device and save image files from the device. (For instructions, see the documentation for the other software.) Then you can open those files in Photoshop or Photoshop Elements.
Solution 2: Disable older scanner files in Windows. If Solution 1 does not solve the problem, open the C:/WINDOWS/Twain_32 folder and move all files in that folder except the wiatwain.ds file to another location. Older scanning files in this folder can cause problems with more recent drivers and applications.
If you would like to operate your device directly from within Photoshop or Photoshop Elements, then proceed to Solution 3.
Solution 3: Troubleshoot installed drivers and re-enable the TWAIN plug-in. If you use a scanner, all-in-one printer, or another TWAIN-compatible device on your system, then the device's driver may be out-of-date. Download the latest version of the driver for your device from the manufacturer's website. Follow the manufacturer's instructions to install the driver. (If you have more than one TWAIN-compatible device, then download and install the latest driver for each device.)
After you have installed the latest driver for each device, re-enable the TWAIN plug-in and restart Photoshop or Photoshop Elements.
To re-enable the TWAIN plug-in:
  2. Rename ~Twain_32.8BA to Twain_32.8BA. (You may not see the file name extension .8BA.)
If Photoshop or Photoshop Elements successfully starts with the TWAIN plug-in enabled, then you can operate your device by choosing File > Import > [Device name].
If Photoshop or Photoshop Elements fails to start, then the driver for one or more TWAIN-compatible devices that you no longer have or no longer use may be causing the problem. (A driver will remain on the computer even after you disconnect a device.) Identify each device that you do not use, and then follow the manufacturer's instructions to completely remove each device's driver.
After you remove the driver for each device that you do not use, restart Photoshop.
If Photoshop or Photoshop Elements still fails to start, then the driver for one or more of the devices that you currently use is incompatible with the TWAIN plug-in. In that case, disable the TWAIN plug-in (see Solution 1: Disable the TWAIN plug-in) and leave it disabled. (You may also wish to periodically check the device manufacturer's website for driver updates. If an updated driver becomes available, then repeat this solution.)
Jul 31, 2010 | Adobe Photoshop 6.0 for PC
Is there any site i could download adobe photo shop 8.0 version for free?
no there is none. there are free out there or cracked but the functionality is limited, for example you cant update, you cant install special plugins, you cant go to photshop download inside the photoshop software, you cant have special effects, you may not support some file formats, and many more.
trust me it is not worth to do. I am a graphic artist too, i suggest buy original.
http://www.adobe.com/
they have special promos now.
Jul 02, 2010 | Adobe Photoshop 7.0 for PC
Symbol LS2208: Suffix with 2 x ENTER
You may need to enter two "rules", each adding an "enter" to the data. This is programmed by scanning special barcodes in the manual, which you can download here:
http://www.modul-bio.com/media/Symbol_LS2208_Manual.pdf
Aug 27, 2009 | Symbol LS2208
Can i uninstall 7.0 if 9 installer is showing up on my desktop
Yes! Go to Start>Control Panel>Add/Remove programs where you can uninstall the version you wish. Adobe also has an excellent support site at http://www.adobe.com/support/
Oct 20, 2008 | Adobe Acrobat 7.0 for PC
Adobe reader 8.0
You cannot copy the image, but you can make a snapshot of the screen. Magnify the document as much as you like to see the image after copying, then press PrintScreen button on your keyboard. Now you can paste it into any program.
You might also load the PDF file into some image processing program to convert it into image file. For example Adobe Photoshop or IrfanView is able to do this. (IrfanView requires GhostScript plugin to open PDF files.)
Third solution is installing a special printer driver which is able to print into image file instead to real printer. But all I know requires registration or limited some way.
Aug 14, 2008 | Adobe Acrobat® 8.0 Standard Full Version...
Scale
You do not mention having any photo editing program now.
It depends upon which photo editing program you have, as how to do it.
If you download Adobe Reader 8 http://www.adobe.com/products/acrobat/readstep2.html
You also get Adobe Photoshop 3.2 Starter Edition. Both are FREE.
In Adobe Photoshop select the photo you wish to print. Then on the menu bar select File then Print. Then select the Custom Size radio button. Adjust the scale to the size print you are wanting, in this case 2.0 x 2.0
Be sure to come back here for my rating on this solution.
Dec 05, 2007 | Adobe Photoshop 7.0 for PC
Cameras Logo
13 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
