Kenwood HM-381MD Shelf System Logo
Anonymous Posted on Feb 25, 2011
Hello, My stereo says "No Disc" when I put a CD
Bruce
Level 2:
Sergeant:
Champion:
  • Expert 242 Answers
  • Posted on Feb 25, 2011
Bruce
Expert
Level 2:
Sergeant:
Champion:
Answers
242
Questions
0
Helped
49826
Points
750
The laser lens is most probably dirty.
if you can see the little glass dome inside the CD player, try wiping it gently with a cotton bud soaked in a little Vodka or Gin (spirit) to clean the lens.
If a lens clean doesn't work - its time to choose a new up to date - all singing all dancing replacement model.
  • Anonymous Feb 25, 2011
    Thanks for your help!
1helpful
RCA RS2664 Stereo wont play CD in any of the trays but seems to try to scan to play.
Hello
The laser pickup unit's lens may be dirty or dusty. Just put a lens cleaning disc into the tray, and play it at least three times, by ejecting the disc each time, and reinsert in in to. The lens cleaning disc can be bought from most of the electronic spare part selling shops at your town, and won't cost more. If it dose not help you, the laser pickup unit of your RCA device should be replaced with same type and number. OK.
Sony CFD-S33 boom box not playing cd's
HelloP
Insert a lens cleaning disc into the set and play it at leat three times. If the fault is due to accumulation of dust, the cleaning disc will clean it out and your set will be work again. If this does not help you, the laser pickup unit of the set is faulty, and should be replaced with same type and number. The lens cleaning disc can be bought from most of the electronic spare part selling shops at your twon, and won't cost more. OK.
2helpful
Cd player won't play disc it says
Hello
Clean the laser pickup lens by insert a lens cleaning disc into the set, and play it at least three times. If it does not help you. replace the laser pickup unit, with same type and number. OK.
1helpful
Says no disc when i put in a dvd. dvd is new and clean, still won't work.
Hello
Put a video CD and see whether it reads and plays. If it also does not plays, or if video CD only plays and not DVD; in both cases; the Laser Pickup Unit is faulty and should be replaced with same type and number. OK.
2helpful
2answers
My DRC6309 RCA portable DVD player will not play disc. It says "loading" and then says "no disc". I have tried different outlets and different discs. Any suggestions? Is there a...
Hello
Either your DVD players Laser Pickup Unit is dirty or defective or its 'sled' motor has damaged. Sled motor is one, which spins the disc inside. if it does not spins, the main system IC won't get any signal that the disc is "IN", and will show the messege "No Disc". The same will happen if the laser pickup unit is defective or dirty. Insert a Head Cleaning Disc into the system, and play it for atleast 3 times. If there is any dirt or dust, this will solve your DVD's problem. If not, it should be serviced by any skilled technician. It is not a user reparable item, as you have to take out its loading mechanism completly out of it for repair. OK.
I have had the CMT-NE5 system for four years now. Great little stereo. Recently anytime I try to play a disc I get the message "No Disc". I am using compatible disks, and have tried several...
Hello
Replace the flat strip wire that connects laser pickup unit to main board. If it does not help you, replace laser pickup unit with same typa and number. OK.
Hi i have a sony car stereo that plays the radio only!
what is happening on the display is the laser reading the disc if its not reading the disc your cd player is faulty more than likely the laser is either dirty or had its day,make sure there is compatible music data on the disc,also check all the sound options on the stereo.
Trouble playing store bought cd's
itll be the lens on the player clean it with surgical spirit
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Ngoro
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
