Question about ASUS R1E-B1 Tablet PC
No power I have a asus f3s series laptop which is not getting any power to it. The battery pack has a green light going but nothing on the laptop. The power pack usually heats up a little but this is not happening either.
  • 284 Answers
It will only heat up if power is being used, but it could also mean that the adapter is bad.
check with a multi tester inside for red and outside for black, check to see if you are getting at least 15 volts or higher voltage.
make sure you set the multitester to VDC, Thats Direct Current Voltage or DC voltage.
if you are getting power thru the adpater head try wiggling the tip a bit to see if theres a broken wire inside the head Adapter head tends to break at the tip sometimes.
if your getting power then you might have a broken adapter plug in the laptop, you might a suitable adapter plug at a electronic store or ebay, might need or reqiure some soldering on the board if you dont know how to solder i suggest you leave it to the PRO's.
if no power coming from the adapter then time to replace the adapter, i figure adapter last about 1-2 years before they need replacing due to wear and tear and neglect. If you do not take care of your electronics they will not take care of you!.
Good luck
Posted on Jul 28, 2008
Nothing happens when I rub my mouse keyboard on my Asus Transformer T100. How do I get it to be visible
Ok I have been thinking about your problem. How long did you actually charge your Asus Transformer?
You might need to charge it about 8 hours minimum to get it to work efficiently. Try that and see what happens.
Jan 05, 2015 | ASUS Transformer Book T100
Asus MeMO Pad HD 7 won't turn on or charge.
Ah ASUS. I have a Memo 10. Had the same problem when it was 6 days new. Asus has a UI that is bad.
1. First try to charge via USB to your computer. If you get any result good, leave it a bit.
2. Leave it plugged in and see if it will turn on. If you can get it to turn on ... do this.
3. Find the back up and restore/factory reset. Back up your data, pics, music. etc.
4. Do a factory reset... it will say everything of yours will be delted. Proceed.
5. Restart the tablet.
6. Go into settings and TURN OFF Asus's UI. On my Memo 10, under settings is a menu called "Asus Customized settings" in the sub-menu turn OFF "Use ASUS Quick Setting" yours may say something a bit different.
7. Restart. The look will be different but no worries. On the upper right see if your tablet it charging. It will be a battery with green and black and a lightening bolt in it. If it is charging try your wall wart charger.
Jul 20, 2014 | ASUS MeMO Pad HD 7
Nexus 7 tablet flashing white light
I am very familiar with this problem with the 2nd gens and it is almost always a sure sign that the tablet is not getting enough power to charge up and will not boot. Sometimes this can happen from the tablet not getting used for a while and getting completely drained. The other possibilities are A) the USB charging port is becoming worn out and won't charge or B) the battery is no longer holding a charge, much like a car battery in the winter. Get an original Nexus 7 wall charger and leave it charging through the wall outlet and not a computer, this has more power. If the light is blinking, it makes me think the USB is not the issue, so chances are after an hour or two it will have some life again.
Jun 14, 2014 | ASUS Google Nexus 7 8GB Tablet Unlocked...
ASUS T100 stuck at preparing automatic repair message will.not reboot
Hello there, i just owned a brand new Asus T100 for 2 days and today on the 3rd day after purchasing, i faced problems during boot/start up where the laptop gets frozen on the Asus logo screen.
I tried holding down the power button for 10 seconds and turned it on again. It ran a series of windows software updates before the start up, then after all software updates have been completed, the laptop resumed to freeze at the Asus logo screen again. I tried holding the power button for 10 secs followed by holding the power button and volume up button at the same time, to get into automatic repair/repair mode. THIS HELPS, get into the repair mode!
To cut it short, i tried the other advanced options as well as the restart button in the repair mode but to no avail. After carefully reading the different options in the 'advanced options' in repair mode...
Here's what worked for me:
1) If you're stuck at the Asus logo screen which doesn't seem to boot for ages or at least 10 minutes, hold down the power button for 10 seconds and let the screen turn black. (I did this with my charger plugged in, not too sure if it matters)
2) Count to 10 seconds. Switch the laptop on by HOLDING THE POWER BUTTON + VOLUME UP BUTTON at the same time. This will send the laptop into an 'automatic repair', followed by a 'diagnosing this PC' and after which you will see a blue screen which is the repair mode.
3) On the blue screen you will see 2 buttons, 'Restart' and 'Advanced Options'. Click on 'Advanced Options'. (DO NOT CLICK RESTART, it does nothing as you will get stuck again at the logo screen)
4) After clicking 'Advanced Options', click 'Advanced ....' (i forgot what exactly) and click 'STARTUP REPAIR'. This is the crucial part.Then follow whatever the system promts you.
5) Afterwards, it will attempt to repair your system then lead you back to the logo screen for startup.
6) Wait a few minutes and you should be able to get to your login screen as usual.
Hope this helps. I chanced upon it by guessing which would actually help me.
Nov 19, 2013 | ASUS Tablets & eReaders
Back cover popped off- won't power up
just replace it motherboard possibly got broke when it hit .
Nov 22, 2017 | ASUS Google Nexus 7 Tablet
Motion Computing C5 Tablet PC won't power on
Hi! I do understand that you are having the problem on the laptop turning on. Try another option, turn off laptop, remove cables and battery, press and hold power button for 10 secs. Reinsert the cables and battery on the laptop. Then turn it on. If the laptop did not turned on, remove the power cable and turned on the laptop. If still didn't, remove the battery and insert the power cable. If still did not work then check if there lights flashed on the laptop when turning it on. If still does not, then you need to contact the pc manufacturer for repair and possible replacement. Otherwise, if there is light on the laptop, then there might be a problem either the battery or the power cable itself. If there is light on the laptop but no power cable, most likely the monitor did not work simply because the battery works due to the fact that there is light on the laptop. On the other hand if there is light when plugging in the power cable on the laptop, then you need to check and insert another battery if it works. Otherwise you need to replace the battery...
Jul 06, 2010 | Motion Computing C5 Tablet PC
My toshiba r10 laptop wont turn on the green power light to the front is on but the yellow battery light only comes onn when i plug in the power cord to it and it only stays about 2 seconds
Ok here's what you will do
1) Unplug the notebook from the ac adapter (charger power cord)
2) Take off the battery pack on the notebook
3) Once the ac adapter and battery is off the notebook, hold down the power button for 15 seconds
4) After 15 seconds, let go of the power button
6) Now press the power button once.
7) If the unit boots, the unit suffered a slight surge
8) If the unit does not boot and remains dead, the unit suffered a severe surge and may be burned out and needs replacing
I hope this helps and let me know how it goes afterwards
May 03, 2010 | Tablets & eReaders
Asus F3S Laptop Graphics Card Died
If you have run the laptop in safe mode it uses the standard VGA graphics driver, and this indicates the onboard graphics card is still functioning.
Try connecting and external monitor to your laptop and the boot up your laptop.
Then :-
1. Download the latest graphics driver from ASUS WEB site.
2. uninstall the graphics driver.
3. Reboot the laptop and install the new graphics driver.
4. Shut down and remove the external monitor and reboot.
5. Goto the Control panel - Display and check/set the settings for screen resolution, Colour setting etc.
Nov 13, 2008 | ASUS R1E-B1 Tablet PC
ASUS F3S startup problems...
Have you tried doing a system recovery using the "hot" keys for the machine. Contact ASUS support for the instructions.
Apr 11, 2017 | ASUS R1E-B1 Tablet PC
ASUS R1E-B1 Tablet PC Logo
287 people viewed this question
Top ASUS Tablets & eReaders Experts
Alun Cox
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
