ECS 755 A2 motherboard problems
Hello i'm disperate pls help me ... i have an ecs 755 a2 motherboard and the leds and pwr button don't work it's starts but nothing appears on the screen and when i try to turnit off the button dont work pls help me....:((
    President:
  • 2,351 Answers
Make sure you have the correct front panel header connected correctly to the case wires. Open you're manual to page 12 under the English section. There you'll find a picture of the front panel header & how to connect the case's LED's to the motherboard.
If you no longer have the manual you can download it from ECS at this link.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=381&DetailName=Manual&MenuID=1&LanID=0
Chances are you may have the wire's connect backwards. (Positive + connected to the negative - ECT).
Example, pin 1 is the + for hard disk drive & pin 3 is - for the hard disk drive. Cases vary on wire colors, normally if each connector has a common colored wire (solid color) that common wire would be the negative. Stripped wires are negative. Other cases use white colored wires as negative & colored wires as positive. As far as you not receiving any display. Try removing the AGP card & clean the copper contacts. Clean with alcohol.
Place a couple drops onto a cotton swab & clean the copper, both sides. Blow out the AGP slot with canned air. Re-check all connections, power & data cables before closing the case. Power on the system & check the front led's for operation.
If you still fail to get display, re-check the connection from the monitor to the case. Try you're monitor on another system. If good than you're video card could be bad. You're motherboard can run an 8x/4x speed AGP 1.5volt (only) graphics card.
Good luck zeratu_l !
Need more help? Post within this link.
Mike
Posted on Jul 28, 2008
Where can I fine manual for 755-A2 I went to EliteGroup www. No luck. Can you please HELP. Thank You
Try this:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=381&DetailName=Feature&MenuID=1&LanID=0
Sep 26, 2010 | EliteGroup ECS 755-A2 Motherboard
Will Intel 965 Extreme Edition / 3.73 GHz work with this board - ECS P43T-A2 - cpu fan comes on but no video
Sorry, but the Intel Pentium 4 Extreme Edition 3.73GHz CPU is not supported.
You need to check out the supported CPU list for the P43T-A2.
Click on the link provided;
http://www.ecs.com.tw/ECSWebSite/Support/CPU_Support_Model.aspx?detailid=898&MenuID=69&LanID=0
Main web site for the ECS P43T-A2 MB;
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=898&CategoryID=1&DetailName=Feature&MenuID=44&LanID=0
It will support, Intel Core 2 Extreme QX9650 (C0),
3.0GHz, (2x6MB,1333 MHz,LGA775)
Hope you find this helpful!
Mike
Nov 10, 2009 | EliteGroup ECS P43T-A2 Intel P43...
POST-Beep-Code List availible for Phoenix-BIOS? ECS 755-A2
The problem is with your RAM. Try installing the RAM in another slot. Install your AGP card slowly. I can assure about your motherboard yet you have no problem without assembling. Keep informing.
Feb 22, 2009 | EliteGroup SiS755 (755-A2 V1.0)...
ECS 755-A2 USB 2.0 no working
The best thing to do is uninstall the USB drivers on the machine and download off ECS the latest firmware and install.
Jan 07, 2009 | EliteGroup ECS 755-A2 Motherboard
Motherboard 755-a2
I go Why can't I install Windows XP on my S-ATA HDD by SiS964? A: You have to copy the driver paired with the motherboard package into a floppy disc before you installing WinXP or Windows 2000 on your system, and follow the notice showed on the screen to insert the floopy disc. The system will grab the needed driver from the disc to finish the installation of S-ATA HDD automatically.
Because SiS964 was announced before than Windows XP and WinXP therefore it can't recognize it. If you want to install a whole new WinXP (or Windows 2000) on S-ATA HDD by SiS964, you need to copy the necessary driver from the directory named floopy image on your driver CD to one floopy disc. When you begin to install OS, follows the instruction to put your disc into floopy drive. After this, you will keep on installing your WinXP smoothly. If you use P-ATA HDD, you don't need to do like this.
t this off the sis.com web site what does it all mean.
Sep 03, 2008 | EliteGroup ECS 755-A2 Motherboard
Sytem wont post
remove the rct battery and try again power on again.
Also look for and replace bad cappacitors. If nothing works, you need a new momo!.317cfa4.jpg
Feb 12, 2008 | EliteGroup ECS 755-A2 Motherboard
ECS 755 A2- PC wont boot up with my X-FI sound card Extreme Gamer all i get is a black screen when turning pc with my sound card atached to mobo.
on most motherboards you have to install soundcards into the top or no 1 PCI slot if you dont it wont boot up. a lot of people install thier modem in that slot if yours is it will have to be moved to the bottom slot, this should fix your problem.
Jan 10, 2008 | EliteGroup ECS 755-A2 Motherboard
What's going on?
please check ur memory card it might not be inserted in the slot properly or might be fault with the memory card
Jan 03, 2008 | EliteGroup ECS 755-A2 Motherboard
Motherboard
Well you really need to get a manual for that. Check the website and download the manual with that model, for sure there is one.
I guess you have connected all the connectors there incorrectly so better look for a manual.
Dec 09, 2007 | EliteGroup ECS 755-A2 Motherboard
Computers & Internet Logo
548 people viewed this question
David Payne
David Payne
