Question about Neovo F 317 17" LCD Monitor
F-317 neovo monitor
Comes on then after 2 to three minuts will go off after it blinks a few times. Turn off then on will come up then right back off.
  • 5 Answers
The problem is probably caused by the inverter, in my case it was not caused by the capacitors but it was the circuitboard underneath the two coils. The coils are glued with a somewhat corrosive glue that eventually eats away the copper underneat an will cause a loose contact over time. Just desoldere the coils and scrape the glue and corrsion of, Then reconnect the corroded connection by soldering a wire from one side to the other and youre done.<br /> <br /> Good luck in fixing your monitor.<br /> <br /> Smokey<!-- from fixya rte -->
Posted on Aug 16, 2010
  • 813 Answers
This problem is very often caused by dry electrolytic capacitors on the inverter board. If you have some skill with soldering you could try to change them. When buying new ones ask for LOW-ESR capacitors for switching mode power supplies (SMPS) and 105°C, they are a little bit more expensive than normal electrolytic capacitors, but are designed for this aplications so they lasts more. Normal el. caps will also works fine so when you cannot buy LOW-ESR for SMPS use normal ones.
Posted on Jul 28, 2008
Why does moniter keep saying check video cable when turned on it is connected right
It is quite common for new flat screen monitors to report this as computer boots up. If it comes back on each time and continues then just ignore it. PC's switch the video output on and off as they power up. This is normal. New monitors are just impatient. Ian.
Sep 18, 2011 | Neovo F-417 17" LCD Monitor
Neovo F-417 contantly autoadjusting - help!!!!!
Check to see if the auto button is sticking (press it hard a few times, and wiggle it)
If it's not that then It's probably the power supply blinking out (monitor thinks it was shut off and back on)
If so, There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you aren't tech savvy, this unit needs to go in for repair.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering).
Mar 01, 2011 | Neovo F-417 17" LCD Monitor
Neovo F-417 monitor keeps switching off and takes several minutes to be able to switch it back on again
The power supply of your monitor have problem.Leak capacitor at ur power supply need for replacement
Oct 04, 2010 | Neovo F-417 17" LCD Monitor
Monitor starts, about three minutes no picture but
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | Proview PL926WBi 19" LCD Monitor
I own an AG SX 17 neovo monitor, which I got from my company; as they were going to throw it away because the light of screen decreased and after 2 seconds the screen would go blank. When I turn it off and...
a lot of monitors are having trouble with defective capacitors in their power supply ...the bad capacitors will usually have their tops buldged up .. they are not expensive but you would need to know how to solder and basic electronics .
Apr 02, 2010 | Neovo SX-17A 17" LCD Monitor
The right side of my monitor is black and I cant see all of my icons on the left side
This seems as though there is a synchronization problem between your computer and monitor. If you monitor has an Auto Config button, push it. Or go into the screen menu (buttons on monitor) and find the auto setting there. If that doesn't work, check your display properties (right click on an empty space on the screen) and make sure you desktop is set to the same size as you computer screen. Hope this helps! Look forward to hearing back from you!
Feb 26, 2010 | Neovo F 317 17" LCD Monitor
Power problem
low power consubtion first on ur moniter then cpu
Jun 19, 2009 | Acer AL1717 17" LCD Monitor
Goes Blank after 2 to 3 min of turn on.
Jul 28, 2008 | Neovo F 317 17" LCD Monitor
Mag Innovision LT776s 17 in. Flat Panel LCD
I have the same problem except it usually happens after Ive left my computer idle for a while... i.e . Overnight, I usually turn off the monitor and I hit the button after I come back to turn it on. I get the same flashing light for several minutes. This has been a problem for several months, but only recenly have i gotten the same error message you mentioned. Each time ive booted the computer up cold or restarted it has worked fine but this time it took longer along with displaying the message: Top Left to Right: SH770 P001 Bottom Left to Right: AU M170EN05 Anyone else who can clear this up?
Mar 04, 2007 | Mag Innovision LT776s 17" LCD Monitor
Neovo F 317 17" LCD Monitor Logo
152 people viewed this question
Top Neovo Computers & Internet Experts
Questman
Questman
Level 1 Expert
Dimitar Todorov
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
