Question about Maytag Microwave Ovens
I have a Maytag microwave MMV5156AAW. Just recently it doesn't heat and there is a loud humming noise. I figured it either the transformer, the magnetron or the HV capacitor. How can I isolate the problem to the specific unit??
  • Anonymous Mar 13, 2014
    runs but won't heat
  • Maytag Master
  • 9,086 Answers
It's probably the magnetron or high voltage rectifier diode.
(When a capacitor fails, it will short, causing the fuse to blow. They rarely "open up")
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
Maytag model MMV4230DS00, everything seems to work but nothing heats, no humming or noises.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 05, 2011 | Maytag MMV4203D Microwave Oven
My JES636WK01 microwave heats up but it makes a loud humming noise. I suspected the Magnetron and disconnected it. The microwave was then operated and the n oiuse was the same. Do you have any ideas
Disconnect the HV transformer leads from the magnetron and the capacitor. Make sure none of the wires are touching the chasis or other parts. If the loud humming sound is still present, it is the High Voltage transformer making the noise. If the noise goes away, it is the High Voltage Capacitor going bad.
*MAKE SURE TO UNPLUG UNIT BEFORE TOUCHING ANY OF THE HIGH VOLTAGE LEADS! ALSO, DISCHARGE THE CAPACITOR BY SHORTING THE TWO SIDES AGAINST EACH OTHER!
Apr 15, 2011 | General Electric Microwave Oven
We were using the microwave the other night and it started making a loud noise like the fan was running (although the fan was not). We let it sit for awhile and try to use it again but the noise came...
The loud noise and no heat means that the magnetron has failed. It the part that generates the microwaves that heat the food. When it fails it shorts out, causing the transformer to heat up. That is what was causing the burning smell. The cost of a replacement magnetron is around $130-150 range so it may not make sense to have it fixed.
Mar 24, 2011 | Maytag MMV4205 Microwave Oven
My oven makes a humming noise when it is running - either in heat mode or defrost mode. The noise goes from nothing to loud, then loud, then it quits. The microwave is only 2 months old and it has been...
No! this not normal and should be checked out right away, the problem could be in the high voltage transformer being loaded down by the magnetron, or possibly the turn table motor. The warranty must still be in place and I encourage you to take at vantage of it.
Jan 14, 2011 | Maytag UMC5200BA Microwave Oven
Everthing works but the heat and it makes a loud humming noise.
The magnetron has shorted probably loading down the high voltage transformer where the humming is coming from. It is cheaper to replace the oven than have it repaired.
Jan 14, 2011 | Maytag UMV1152 Microwave Oven
Loud noise and not heating up
if its making a loud humming noise you need to remove the outer and carefully discharge the high-voltage capacitor in the magnetron circuitry(caps are usually oval in shape and 3 to 5 inches long) after this disconnect one terminal of the cap and check it for being open,then do the same on the high-voltage diode and check this for front to back resistance high in one direction and lower with the meters leads reversed on the diode,the humming is coming from the transformer not being loaded by the cap and diode to double the voltage required by the magnetron tube of -2,000 volts D.C.
Apr 26, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
It is making a humming noise but not heating.
sounds like a crack in the magnetron
a bad transformer
or a bad rectifier
sorry i cant be more help
Oct 10, 2009 | Maytag MMV5100A Microwave Oven
Over range micro
Same with ours does not heat but makes a loud humming noise
Jan 12, 2008 | Maytag MMV5156AAS Microwave Oven
Microwave Ovens Logo
166 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
