Question about GE JVM1650 1000 Watts Microwave Oven
Ge jvm1650wb005 I have a GE Spacesaver microwave oven that doesn't heat. Everything else seems to work fine. I just replaced the Magnatron, High voltage cap and diode. When this unit stopped working it would make a low hum noise fro 2 to 3 seconds and blow the 20 amp fuse. Now it seems to run correctly but doesn't heat anything up. Any suggestion would be appreciated. I also have a GE jvm1650BBoo8. Everything works but it won't heat.
  • GE Master
  • 19,396 Answers
You need to have a repairman checking voltage out from power adapter. If PSU volts are OK, then probably you will need to replace the magnetron.
Posted on Jul 28, 2008
  • 813 Answers
One of the internal door switches, the high voltage circuitry or the circut board may have a problem to resolve this you need a qualified appliance technician
2 Suggested Answers
SOURCE: Ge jvm1650wb005
weve had our fixed before and it's the heating element $75-$100 to fix.
Posted on Sep 01, 2008
GE profile JE2160SF03 microwave oven doesn't heat
3 things high heat low heat cencor or magnatron is bad
Apr 02, 2013 | Microwave Ovens
Ge jvm1650wb005
one of the internal door switches, the high voltage circuitry or the circut board may have a problem to resolve this you need a qualified appliance technician
Mar 31, 2008 | GE JVM1650 1000 Watts Microwave Oven
GE JVM1870 Runs, but won't heat up
use a high voltage probe to check high voltage, if present replace the magnatron if no HV replace the high voltage board this is the board that has the heavy wires to the magnatron
Feb 06, 2008 | Microwave Ovens
GE Spacesaver over the range microwave oven
GE Microwave ovens, and Microwave Ovens produced by GE but released under different brand names, have had several power problems for the past 20 years. Because it is so easy to sell parts and charge outrageous rates for repair GE never corrected the problems. They just continued it in the next model. They found that you would most likely purchase a new unit rather than paying $75. for a service charge, and $150. for labor plus parts (if out of warranty period).
Most failures were cold solder connections on the power relay board. These would come completely dis-connected after arcing and burning away the solder. Could be 1 month, could be years, but they knew it would happen. This power relay board feeds 120volts to the LV (low voltage) side of the HV (high voltage) Transformer. No High Voltage,,No cook. Everything seems to run normal, but if you listen carefully you will not hear the low tone from the HV Transformer. Over my thirty years in the business I have re-soldered rather than replace so many I couldn't count.
Next to that, a defective Magnetron.
Jan 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Spacesaver micro not heating
Your magnetron, HV diode, Capacitor, or control board maybe bad most of these components run with high voltage and difficult to test without the proper equipment
Oct 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE PRofile Spacemaker XL Microwave Oven Model# JVM1460 950 watts
Sounds like the problem is in the high voltage. Most common would be magnatron, capacitor and diode. For safety reasons this should be checked by a professional. Look in your owners manual because some high voltage parts have a longer warranty than 1 yr.
Oct 09, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
174 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
