Hi, I have added a USB 2.0 4 port PCI card to my PC, when I run the support disc to add the driver it says no hardware found. All the instructions say are plug in the card and run the disc, is there something else I need to do or is it likely I have bought a faulty card. Kind Regards
  • 144 Answers
Dear Friend,
If you have windows xp, generally when you add new hardware. Windows does show found new hardware window, where you can select the driver for your new hardware.
Go to control panel=> Add new hardware & then select the appropriate drivers for your card.
Hope this solves your problem.
Posted on Jul 28, 2008
Partlist pl-peusb3.0-nec 4 port usb3.0 pci-e card driver win-7
I recently purchased Partlist PL-PEUSB3.0-NEC-2P 2 Port USB3.0 PCI-E Card from MSY in Australia and found some drivers that worked at sabrent.
Specifically the PCIX-USB3 USB 3.0 2 PORT DESKTOP PCI EXPRESS CARD (GREEN BOARD) drivers at http://www.sabrent.com/downloads.php
Nov 25, 2012 | Televison & Video
Tip
Options for Adding Serial Ports The serial port is prevalent on PC's ...
The serial port is prevalent on PC's as well as scores of industrial, scientific and consumer devices, making it a convenient starting point for communications. Since RS-232 itself is only suited to short connections (50 ft. max.) many applications require that it be adapted to fit requirements. RS-422, typically used for extending RS-232 communications, provides full duplex communications between two devices. It can also provide one way communications from one master to several slaves. RS-485 communications standard allows cable lengths up to 4000 feet. It also provides very high noise immunity. Multidrop connections up to 32 different nodes can be made over a single twisted pair cable along with a signal ground connection.
This article summarizes the choices a system designer has when adding a serial (RS-232, RS-422, or RS-485) communications device. There are many different ways to add additional serial ports to your Desktop PC, Palm, or Laptop PC. USB, PCMCIA, PCI and ISA are some of the methods that will be discussed.
The Universal Serial Bus (USB) provides a high data rate and Hot Swap connection for PCs, providing an easy connection to a wide variety of multimedia and network USB devices. Generally considered to be for home or office use, USB is finding its way into Industrial applications.
PCMCIA Serial Ports are yet another way to add serial ports to a PC that has PCMCIA Slots available. Most Laptops today offer only one (if any at all) DB9 type serial ports. A PCMCIA Serial Card is a good way to add a serial port (or ports) to any laptop that is low on available serial ports (RS-232, RS-422 or RS-485).
PCI Cards are becoming more popular as a way to add serial ports to desktop PC's. PCI type slots are becoming the "norm" in standard PC's today, and PCI Serial Cards are an excellent way to add serial ports. The standard Desktop PC may only come with one serial port standard (if any serial ports at all). PCI Serial Cards use Software Drivers to address the ports to the PC.
ISA Cards are yet another way to add serial ports to the older desktop PC's. ISA type slots are becoming scarce in standard PC's today, but are still an excellent way to add serial ports. The ISA Cards are typically addressed using dip switches and shunts or jumpers to set IRQ's for each port. No Software Drivers are required with ISA style serial cards.
Palm OS PDA's may be connected to RS-422 or RS-485 data circuits using Palm adapters. These adapters offer total portability for collecting data and field service chores. The Palm device and the adapter will usually slip into a shirt pocket. Some models use the PDA's connecting cable, some include a cable and some are cradles that allow the PDA to nest in place and connect directly to the Palm base socket. PalmTerm Freeware allows you to transmit and receive data from the Palm serial port.
on Sep 12, 2010 | Computers & Internet
Can a Windows 95 have a usb port installed
Yes.
Load the required driver from Microsoft but it will not be USB 2 only USB 1.
Oct 16, 2010 | Computers & Internet
SunTech(SYBA) USB2.0 4+1 Ports PCI Card (NEC)
hi,
Kindly find the mother board manufacture and visit the site and download latest drivers and if your running xp kindly update with SP3 pack.
Jun 15, 2010 | E-Machines eMachines Desktop PC
Ctrl keys dont work, bought new key board and have same problem, have windows XP
First rule out drivers
- remove the keyboard driver and instruct windows to reinstall the driver
Next check for hardware issues
1. Plug this keyboard into another PC to see if the same problem persists
2. If the problem does occur it is the keyboard (get a new one if that is the case)
3. If the problem does occur then it is not the keyboard it is the port that u are plugging it into.
IS IT USB?
4. If it is a USB Keyboard, plug it into another USB port
5. If the problem persists on all USB ports on the system board, then the problem is the USB ports only IFF the keyboard works fine on another system in other USB ports
Is it PS/2?
If it is not a USB keyboard and it is a PS/2 board, again, and it works fine on another PC, then you have a defective PS/2 port on the system board.
Solution
Get a PCI card with USB ports and install it. Plug ur keyboard into that.
Mar 14, 2010 | Dell Dimension E310 PC Desktop
How to upgrade to USB 2.0
hi this could be that the usb ports on your system are only usb v1 and not usb v2, if you require your items to run on usb v2 you will need to get a usb v2 pci card the things will work still just at a reduced rate of speed there will be no drivers for your usb ports to upgrade them as it is hardware related and not software related, usb v2 cards are generally cheep to buy and easy to install and set up....hope this helped
Feb 25, 2010 | Computers & Internet
Lost install instructions for Hi-speed usb 2.0 5-port PCI card.
The drivers are here. You shouldn't need to do anything to install the card other than plug it into a PCI slot in your computer and install the drivers.
Hope this helps. Thanks for using Fixya!
Feb 19, 2010 | Belkin Hi-speed USB 2.0 5-Port PCI Card [...
Hardware not found?
please try to clean the mouth of the PCI slot by wiping with a white paper..... re fix it, power the machine and allow the hardware to be detected... you can now try installing the driver software ....
Aug 07, 2009 | Parallel PCTek High-Speed 2-Port PCI...
Upgrading two USB ports on front panel
Hi..
there is no such converter..
those pins should connected to ur mother board only...
once check ur bios settings..
or
use external usb hub..so u can get multiple usb ports that u need...
Jan 01, 2009 | HP Pavilion 761n PC Desktop
No dial up port. how do i install?
its unusual for a pc not to have a phone line connector, it's a basic fitment, unless it's been removed otherwise you need to purchase a pci slot modem card.
Remove the side of pc, find a spare white elongated pci slot, press in the card, restart pc, the hardware will be found then prompt you to install the driver disc supplied.
Sep 03, 2008 | Computers & Internet
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
