Question about Neovo F 317 17" LCD Monitor
Goes Blank after 2 to 3 min of turn on.
First comes on and then will go bright then dim then will go off completely. Is there a board in the monitor that I can change and get it back.
  • 813 Answers
This problem is very often caused by dry electrolytic capacitors on the inverter board. If you have some skill with soldering you could try to change them. When buying new ones ask for LOW-ESR capacitors for switching mode power supplies (SMPS) and 105°C, they are a little bit more expensive than normal electrolytic capacitors, but are designed for this aplications so they lasts more. Normal el. caps will also works fine so when you cannot buy LOW-ESR for SMPS use normal ones.
Posted on Jul 28, 2008
Why does my HP vs17 monitor screen keep going to blank black screen like it turned off but did'nt.....blue power button light is still on? Everything is running but no picture.....keeps happening everytime...
this old monitor has 2 issues.
1: it has CCFL tubes that love to burn out (backlamps)
most this old are long go, yell,dim.,blinking or DEAD.
2: push the menu button on front of mon. turn off power saver.
3: if the PC goes to sleep, or hibernete mode (parked)
then that is 100% normal
if you dont like feature then go to windows control panel
click power, ICON and turn off all monitor sleep /hibernate modes.
that assumes windows, no OS stated.
if the lamps are dead,
use flash light pointed to sceen, see data. ? bingo for bad CCFT tubes.
as seen here
http://www.pcdied.com/monitors.html#flashlighttest
Jan 12, 2018 | HP Vs17 17" LCD Flat Panel Monitor
Dim backlight
you need to contact the manufacturer and ask to replace the backlight...
May 20, 2010 | Toshiba Satellite 15" Flat Panel LCD...
When I turn on the bright lights, one headlight goes out. when I turn off the bright lights, the other headlight goes out
you may need 2 light bulbs. check real close, if they go out compltely or really dim.... if dim, you have a ground wire issue, if they go out completely the bulbs are bad.
Oct 15, 2009 | 1994 Chevrolet S-10 Blazer
X20G-Naga III screen goes blank after 1-2 secs
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 31, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
POWERSAVE
I have A "Dell" E152FPc, and I have found an open transistor (Q201) on the Power Supply Board. My monitor comes on nice and bright for approximately 2 seconds, then goes dark; the power LED is steady. The voltage to the PWM IC is waky.
Before you try any hardware troubleshooting go to your control panel and turn off any power management options.
May 26, 2008 | Dell E171FPb 17" TFT LCD Flat Panel...
Wont stay on
IF there is no display even with a flashlight, the P/S board is malfunctioning. Bad capacitors or LCD driver board circuit. Mine did this and it was bad caps, 4 of 8 were bad and a burned out chip on the P/S board.
Oct 20, 2007 | Proview PL913S 19" Flat Panel LCD Monitor
Monitor goes blank automatically after about 40 minutes...
Hi Randygui, Sounds like the back light inverter board is bad. It's a very common problem. LCD's use four small cold compact fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Nov 20, 2006 | BenQ FP71G 17" LCD Monitor
Monitor goes blank
Nov 16, 2006 | Dell E153FPc 15" TFT LCD Flat Panel...
Screen goes blank
Hi jkm007, Sounds like the back light inverter board is bad. It's a very common problem. LCD's use four small cold compact fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Nov 12, 2006 | Videoseven V7 L19PS 19" LCD Monitor
Neovo F 317 17" LCD Monitor Logo
116 people viewed this question
Top Neovo Computers & Internet Experts
Questman
Questman
Level 1 Expert
Dimitar Todorov
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
