Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Outside speakers trying to set up outside speakes already wired them in for the external speakers but can not control them independently on themselves. Know it can be done because behind it has seperate volume controls. tried switching the mono and stero around as well as 2 chan. but maybe did it incorrectly. I know it was done incorrectly because it did not work. Help please having huge party on Sat. thanks
    Champion:
  • Wurlitzer Expert
  • 211 Answers
The two volume controls only work independently when you set the jukebox to 2 channel and mono. One controls the jukebox, the other controls the speakers. There are 3 switches to change on the amp before it will work.
Dave F.
Posted on Aug 09, 2008
Receiver channel volume not identical
Remote controls normally do not adjust stereo volume levels independently, and I will assume that the problem is present on ALL input settings (tuner, CD, etc.). Check "balance" control settings, speakers and speaker wires for possible problems. Balance control at 12:00? Inspecting speaker wires and speakers do not reveal problems? Have you swapped speakers to see if problem reverses? Try this "process of elimination" and hopefully you'll ID the problem.
Mar 23, 2015 | Yamaha Remote Control RXV496RDS...
Tip
Troubleshooting Laptop Sound Problems - No Audio Output
Symptom:
Can't hear any sound out of my laptop.
Diagnosis & Solution:
If you can't get any sound out of your laptop, the most likely cause is the volume being turned down or muted. Newer laptops monitor the external sound control so when the volume is turned up or down manually, the volume control in the operating system tracks right along with it. But with some laptops, especially those with external dial volume controls rather than toggles, the volume dials are independent of the software volume control and can't be monitored in software. In this case, if the volume dial is turned down on the outside of the laptop, the sound is turned off and nothing can be done in the operating system to change that. The only way to get the sound back is to turn up the external volume dial control.
If you have checked the external volume control on the laptop and the standard laptop volume slider in the operating system (the little speaker icon in Windows system tray) & you still can't get any sound out of the laptop, then the next step would be to check for any other software volume controls. Depending on the software installed and what you are trying to do, there may still be multiple volume controls and mixer panels scattered about the operating system. If the wrong channel is muted or turned down all the way in one of these independent controls, the laptop will not produce sound.
Most of the time, the first sign most laptop users get that their audio isn't working is the absence of operating system sounds, like the Windows rush on start up, or chimes with e-mail activity. Of course, these sounds can be turned off by design as well, through the Sounds option in Windows Control Panel. So, before looking at hardware problems, make sure these sounds are not turned off.
If you try to play an audio CD and the media player shows that the song is progressing but you can't get any sound out of the laptop speakers, odds are that the volume is turned down or muted. But it could also be due to an onboard sound hardware failure. If you are confident the volume is turned on in all possible locations and you've checked Windows Device Manager for a report of a hardware failure, try listening through headphones. If the headphones work, the wiring to the internal speakers has broken or come loose. Wiring failure is only likely if the speakers are in the lid and therefore wired through the hinges.
If you don't get any sound out of the headphones & you haven't missed a "mute" being checked off somewhere in software controls, then it really is a hardware failure. If the problem is with all sounds, including Windows chimes, internet radio, etc, then the problem is that the integrated sound processor has failed. In this case, unless the sound system is on a daughter card, it means the fix would require replacing the motherboard. But if the only thing you can't do is play audio CD's, then the problem is that the output from the DVD/CD player is muted or not getting to the amplification stage.
In modern laptops the DVD/CD players feature Digital Audio Extraction (DAE) which means that music CDs can be read digitally & the data passed to the built-in sound card or an external sound card replacement for processing, amplification then output. If there's a problem with the DVD/CD connector or if the wiring has been damaged, the music CD may get spun around without the sound making it to the sound card. The DAE output chip rarely fails on the CD/DVD drive, but the connector can fail. Make sure that digital playback is enabled in the properties tab of the drive in Device Manager.
You can replace your built-in laptop sound card with a PC card, with a USB sound card or USB speakers. These replacements make good workarounds if the integrated audio system fails. They also bring with them a whole new level of software with more volume controls, which are integrated with the existing operating system software. When shopping for replacement sound cards, keep in mind that USB solutions are much cheaper than PC cards. Also, when purchasing USB speakers to replace the laptop's sound system, don't buy speakers advertised as "USB powered". The "USB powered" speakers only draw their power from the USB port, they still need to be plugged into a regular audio jack to output any sound.
Please Vote for this Tip if you found it helpful.
M. Omran
on Nov 03, 2010 | Computers & Internet
My laptop speakers are not working but there is sound when i attach headset
once cause is that your onboard speaker on your laptop was already been busted, My suggestion is better to use headset or external speaker. Or also try to navigate control panel and go to sound settings then check if their is an option for internal speaker being used. If not then better to use your headset or external speaker. Hope it helps thanks.
Sep 13, 2011 | HP 530 Notebook
Where do you hook up outside speakers
'Outside' is not a choice on the unit.
If you want to drive a separate amplifier with speakers somewhere you could replace the Main Channel Pre-Out jumpers with an RCA-Y-adapter and slave the second amp and speakers to this unit's volume controls; or you could attach a second amplifier to either TAPE REC OUT pair and the external amp and speakers would have independent control of volume locally.
Jul 03, 2011 | Yamaha DSP-A3090 7-Channel Amplifier
Speakers are mounted on the side of tv (mitsubishi CS 40503 1995 model) want to remove them and have them in a different location
"Speaker: Internal/External" controls which speaker (built-in or external) is available. Set to "Internal" for normal operation of the internal speaker system. When connected to external speakers or an external audio system, the speakers can be turned off by setting this function to "External."
From reading this I see that the speakers may be internal because the setup allows to switch between external or internal. A mounted speaker is either permanent, part of the case, or has something that the speaker case slips into. I had one like that. You simply lift them and set them else where. How far they can be moved will depend on the wire. The wire is either attached internal through the back or attached via connectors on the back. That can either be loose wire or RCA plugs. Normally the wire coming from the speakers is attached internal, making the removal of them impossible. The wire is usually 3 to 6 feet long. You can buy an external speaker wire that has RCA plugs (and or plain wire) that will attach to the existing speaker wire and TV.
Good luck and post back
Jun 04, 2011 | Televison & Video
I wish to control volume on 4 pairs of speaks at 4 different locations please
What you will need is an autoformer based speaker selector with volume control for 4 speaker pairs. This will take the left and right speaker wire out from your amplifier and distribute it to 4 pairs of speakers. Each pair of speakers gets it own volume control so you can control each room sound independently. It will also do speaker impedance matching so that your amplifier is not being over driven by the 4 pairs of speakers. The manual for the product you purchase will aid you in the proper settings of the auto former control. You can find this product from companies like Russound or Niles.
Aug 21, 2009 | Audio Players & Recorders
Driving 2 sets of speakers with an external volume control on one set.
I think it's a bad idea to use a simple potentiomenter to do what you want to. You'd be better off using another amplifier with RCA cables in between them. It's not hard to find an old amp that you could use these days.
Sep 03, 2008 | NAD C372 Amplifier
Inside speakers(1) and deck speakers playing (2) output is at very different levels
The things that affect the outside vs. inside volume are distance and ohms of the speakers if the inside ones are 4ohm and the outside are 8ohm then there will be a drastic difference in volume, also if the inside speaker wires are shorter by 20 feet then there will also be a drastic differences in volume.
What you can do is have a separate amp for inside and out with the input coming from the same receiver. The other thing you can do is put an inline amp for the outside speakers with this you can also balance the volume.
When you have longer wires you drop more voltage across them then when you have shorter ones you also has losses due to electrical interference from lights and the household wiring. To combat this I would suggest an inline amp so that you can balance the speakers more effectively and drop out most of the noise (mostly hum that you hear at a higher volume) that you are probably getting unless you put on filters on the speakers. But if you want to keep it simple than you need a separate amp with a common input, this way as well you can control the speakers to have a different volume for different situations.
Jul 17, 2008 | JVC RX-8010V Receiver
Cannot seem to calibrate.
Go to Control Panel, open device manager, and and check for any yellow checks for your
sound, video and game controllers. If there are none, your system is go. Then go to your audio manager on control panel, and set it up for whatever speaker configuration you have. I have realtec audio manager. This step is a must for configuring—you choose whether your laptop will use its own speaks or use your external speakers—you have to turn off the internal speakers and turn on the external manually. You can adjust volume there..
Oct 05, 2007 | Logitech Z-5300 Computer Speakers
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
111 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
