Question about Delphi XpressRC XM Satellite Radio Receiver with Vehicle Kit
Delfhi Xpress RC
I turned it on and set it up. After moving it to another car it will not power up. I tried the other car again with no luck. I have also checked the fuse in the power cord.
Turned unit on and setup 88.3 FM and I get no connection to any stereo? The Antenna is about 75% or better signal but no sound at all. I plug my old Roady XT into the same power and antenna and it works fine on any FM frequency?? Any help would be great.
Posted on Oct 07, 2008
Xpress RC Not turning on
Initially, pls try:
  • removing all the power connectors to simulate a reset and unit will revert to factory defaults. Let the connectors off for an hour or so. Thereafter, pls try again.
  • press on the power button when reconnecting the power connector.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 24, 2008 | Delphi XpressRC XM Satellite Radio...
Fully charged the choppers battery,the controller has all new batteries,turned on the chopper power switch,turn on te controller power switch and wait till light stops flashing.push on the power controll...
The light will keep flashing unless you are on the correct channel A B or C and you hit the "Light" button on the front of the unit.
As far as the high speed take offs I suggest identifying which A B or C setting is correct for your copter. In order to do this turn off the RC controller. Set the Selector switch to "A" move the left joystick "throttle" half way up and then turn on the power. Assuming that the copter is still ON it will either fire up or do nothing. If it does nothing try the same sequence with the selector switch set to "B" and try again. If nothing try "C".
Now, as far as the rapid accelleration, I read one online comment that indicated that there is some type of "programming" sequence that the unit learns by pushing the left joystick throttle all the way forward and then back to zero when you start to fly it. So after the first "blast off" set the copter back down or even hold it in you hand by grasping the the landing runners and move the throttle forward until the rotor spin up and it lifts off. In your hand it is easier to keep it from going up too quickly.
Aug 21, 2011 | JCPenney Gyropter RC Helicopter
My RC Traxxas Stampede stop working. The steering
Spin the rear wheels and make sure nothing such as a small stone is binding something up in the driveline. Check to make sure the motor has not gotten disconnected from the ESC. If you still have problems with it post again and I will try to look further into it.
Dec 05, 2009 | Traxxas Stampede Monster Truck Rtrw/Xl 5
Xm radio
Looks like my company is going to purchase a new fm radio for the company truck, I should be able to plug the xm radio into it.
Jun 03, 2009 | Delphi SKYFi XM Radio Receiver
I have a msg error code Quarkxpress 7
Sorry I only just saw your posst so this may be far too late, but at least for future reference: -36 is one of the oldest and most ubiquitous errors in the Mac world.
It's name is "ioErr" and the rather obtuse explanation for it is "I/O error (bummers)" ie, there was some kind of input/output error.
This should mean that XPress is trying to work with a corrupt file.
The most likely suspects, in rough order, are a text or picture file that XPress just tried to import; an auxiliary file such as a font, profile or XPress Xtension; a text or picture file already imported; the XPress document you are working with; your XPress Preferences file; XPress itself.
Working with XPress since version 2 on Apple system 6 I have never seen any guaranteed cure for a -36 error but there are three basic remedies, none of which is by any means certain.
Any corrupt file just might be revived by Copying it to another location.
If the file seems to be an XPress document and can be Opened at all, there is a better chance of reviving it by first making a new, blank XPress document containing nothing more than the one obligatory blank pagewith the same page size as the suspect had. Saving, Closing and re-Opening the blank document alongside the suspect, setting both documents to Thumbnails view then manually Dragging each page from the suspect into the blank will essentially cause XPress to look at what it's doing, rather than assuming that all the components are workable. Fairly obviously, it may be safer to Drag one page at a time Saving, Closing and re-Opening the "rescue" file between Drags.
Again if the file seems to be an XPress document and can be Opened at all, there is a better chance of reviving it by working with a Copy, deleting either half of its contents - whether whole pages or items on a single page - Saving the remainder, Closing re-Opening, testing and perhaps again deleting half the contents…
Good luck
Mar 31, 2009 | QuarkXPress
The remote does not turn on the Delphi XM Xpress on car unit
This problem is caused due to the fact that xm has designed there radios to completely shut off all power with the unit therefore the unit once off will not be able to recieve information from the remote. This manufacturing defect was confirmed by the xm representative, they also explained that the company is currently planning to fix this issue on the new 2009 model xpress rc
Mar 30, 2009 | Delphi XpressRC XM Satellite Radio...
New Delphi installation over older delphi car kit
Just installed the xpress RC in my Durango, replacing my SKYFi2. Both units are Delphi (all of the newer xpress RC's are made by Audiovox now, but Amazon sent me the Delphi made unit). Everything swapped out with the exception of the 12dc power cord. Had to use the one included in the new unit, plug size that goes in the new cradle for the RC is different. In the new unit I did get two "user guides" in Spanish and none in English (I wish America would adopt one friggin standard language. English) but other than that it was quick and painless.
Jan 07, 2009 | Delphi XpressRC XM Satellite Radio...
Honeywell RTH3100C
You need to go into the installer setting to change it from heatpump to single stage gas heat.Go to if youve lost them.
Dec 13, 2008 | Honeywell Programmable Thermostat Heater
Avid Xpress Pro - AVID crashes when deck is turned on
This sounds like a fatal error out side of avid settings, you're going to need to do an avid reinstall to replace any currupted files. Just back up your media capture and .bin / avb files. Does xpress let you create an omfi file just import that rather than relinking?
Nov 27, 2007 | Avid Xpress Pro - (bundle) (05600360101)...
Delphi XpressRC XM Satellite Radio Receiver with Vehicle Kit Logo
324 people viewed this question
Top Delphi Audio Players & Recorders Experts
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
