Question about HP OfficeJet G85 All-In-One InkJet Printer
G85 USB failure
I have an HP G85xi that is about 5 years old. All the copy and FAX functions are working but the USB connection is no longer functioning. I have replaced the communication cable and the problem still exists. Any ideas? The USB cable was fine - it works on other printers.
  • momoftwinsae Aug 07, 2008
    I also have a G85xi about 5 yrs old and the same problem just occured yesterday. Fax and copy work fine but not USB functions. Also, at the same time the black ink leaked all out of the bottom of the tray. My husband is taking it apart right now.
  • michael60 Aug 16, 2008
    I have a 6 year old OfficeJet G85 with a failed usb.  I reseated a boards and cable and it came back to life for a couple of weeks and died again and reseating did not help this time.  changed usb cable no help
    Scholar:
  • 87 Answers
You will have to replace the main board in order to get a new USB connection. Have you tried using the parallel connection. Looks like a regular parallel connection but smaller. It takes a special cable that was originally sold with the printer. We have those cables for $15 if needed. The USB cable may be out but the parallel connection may work fine.
Inkworks
866-381-0541
Posted on Nov 06, 2008
HP G85 / Auto feed
You need first to take the printer apart and clean the rollers and make sure no foregn object is causing the problem and after that after cleaning and still have problem reller replacement maybe needed....
Oct 30, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Hi do you recomend i buy a second hand hpg85 seller says its in perfect working condition. My concern is: how old is this machine and are the parts still available should i require them.On offer is also a...
I bought my G85xi in 2000 from Costco. I have used it with care & have had only a few problems with it (bad cartridge once, dried out cartridge once, bad FAX board which was replaced under warranty). The quality of the printing, etc is excellent. I've been using the large color #78A cartridge (38 ml.) from Costco which costs about $53. A pack of 2 black #45 cartridges is about the same ($52) (42 ml.)
I also bought a slightly used G85 from a flea market (mainly for back-up parts). I have an hp 6110 all-in-one bought in 2005 which is better than the models produced today, but not as rugged as the G85. Also, HP has rigged the newer models (including my 6110) so that you can't do any printing if the cartridge is determined to be low in ink. to make matters worse, they don't tell you which cartridge is low - only give a message to "remove & relace the cartridges".
Oct 19, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
I am trying to renstall drivers and software for HP OfficeJet G85
ok you can find the add and remove button in control panel to remove the older version.
go to start menu then control panel
Apr 02, 2009 | Apple HP Officejet G85xi InkJet Printer
Please, describe all steps to re-install driver software for hp/g85 printer, after I use g85 self removal. I have Symantec Personal Firewall and Systemworks. I need to know all security that needs to be...
the usb devices are diffrent u need to connect the usb cable after u install the driver it will ask u to connect the usb then only u need to connect it frist u uninstall all the old drivers & do the installion
Nov 28, 2008 | Office Equipment & Supplies
I want solution for my HP Offifejet G85
Here is a link to the HP website where you can download the manuals in the language you need. There are options for language on the G85 by entering your country code and the software has a language option also when you install it.
HP Officejet G85 manuals
HP Officejet software
You have the option to download the manuals and software in the language you want. If you continue to have problems just add a comment.
I hope this helps, good luck.
Oct 17, 2008 | Apple HP Officejet G85xi InkJet Printer
Printer not able to hook up to new Dell
your printer the g85 on the backyou will see below yhr bar codes where the power cord is four connections. looking at it from the back facing you on the far right is the power cord next to the power cord is the cord from the top lid second from the left i dont use this but i think it is the serial connection and far left connection is the usb cable the usb is the best on to use the two phone lines on what i call the leg or base far left remmber they need a special phone cord most cords only have two wires hooked up this on needs all four or it just want work right.hoop this helps
Jun 01, 2008 | HP G85xi All-Color InkJet Printer
Cord needed to work with our new Dell computer
i have a g85xi my self and you will need to use a cable to connect from the g85 to your usb port on the dell i have a hp wich is basicly the same one end of the cable be square and the other end is a usb end
HP G85 auto-answer
yeppers...same thing happens to mine. So, I simply set it to receive faxes manually now.
Jan 18, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP OfficeJet G85 All-In-One InkJet Printer Logo
185 people viewed this question
Seeker5211
Seeker5211
