Question about Kenwood Audio Players & Recorders
Dead right channel
The right channel in my Kenwood KRF-V6070D is not wworking. I have replaced the power outpu IC, but still no go. It seems that the input to the IC could be muted. Any idea?
Regards,
Tony
    Novelist:
    Champion:
  • 218 Answers
Might be an output relay with a bad contact. If you have an oscilliscope you will see sound before but not after the relay. Try wiggling and pushing on/off all the tape monitor buttons and any mode switches. If you have a pre-out/ main-in switch then try switching that several times (with the unit off) then try it. Good luck.
Posted on Jul 28, 2008
My ken wood krf v5050d automatically goes back to standby what is the cause
hello! i need help with this, i have the same amp Kenwood KRF-V5050D it seems that it had a short circuit on the speaker terminals, close to the 2 12v relays wich are close to each other and the 2 transistors kia 7812 and kia 7912 was turned black, i have replaced them, and i have disconnect the 2 big IC but the amp still does go in the protection mode, but when i disconnect the 2 transistors kia 7812 and kia 7912 the amp does stay on. i have checked almost everything and it seemed to be good. i have checked every transistor and replaced some capacitors, but i have not replaced the 4 big capacitors, with all the 0.22j resistors and all the terminal relays and the 2 big ic disconnected the amp still goes on protection mode. i had this amp returned from ebay and the buyer is waiting for it to be repaired, i would aprecciate any help.
ujka.pjetracaj@hotmail.com
Kind Regards.
Oct 07, 2013 | Kenwood Rc-r0511 Home Theater Receiver...
Kenwood KRF-V6070D no audio
• If you have a multimeter, check for DC outputs on the amps,
coming from IC301/401 (hybrid IC)
• Or use a headphones .It could just be some cold solder joints
( if there is no humming in headphones) or regulators
on the power supply.
• Check other inputs, you might find one working.
Let me know if you need further assistance!
Sep 10, 2012 | Kenwood Audio Players & Recorders
How do I hook up a pioneer dynamic expander ex9000 to a kenwood KRF-V7030D receiver?
• Pioneer EX9000 out to Kenwood V7030D play In
• Pioneer EX9000 in to Kenwood V7030D rec Out
• instruction on page 8 of the manual
PDF] KRF-V7030D KRF-V6030D KRF-V5030D KRF-V4530D
Jul 31, 2012 | Audio Players & Recorders
Kenwood krf-v4060d receiver display problem, its work for some time but after that no display, sound work fine but not able to see any display on receiver
it is possible that the voltage to the filament of the display is absent. This is normally a 3.6 volt AC which comes from the transformer and it can be lost a the connectors or the circuit board. It will be best to use a multimeter to trace the voltage to the display unit. check the voltage to the display driver IC, check the negative grid voltage to the display , if there is an open resisitor of the feed to the display voltage to the IC. Finally check the continuity of the filament of the display unit.
The driver IC is also a suspect , sumulate heat and see if the fault comes up easily which can confirm the case.
Sep 05, 2011 | Kenwood KRF-V4060D Receiver
Kenwood krf-x9995d surround issue
It's likely the power amp is faulty. However if you can't get in touch with Kenwood, then take it to another repair shop or go back to the other and tell them you can't get in touch with Kenwood and could they have a look at it anyway.
May 27, 2017 | Kenwood Audio Players & Recorders
Amplifier main channel non operational.
first pull out the power transistor then biased the output terminal. base,emitter have dc volts .4 to .5 collector to emitter have full voltage. if this voltage are in ur pre amp buy new trasistor
Sep 09, 2008 | Audio Players & Recorders
117 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
