Question about Cameras
Minolta Maxxum 3200i Flash does work
I have a Minolta Maxxum 7000i camera with a 3200i flash. My problem is the flash stopped working. The batteries are new and inserted properly. When I attach the unit to the camera all the control lights (on the back of the unit) work and the flash appears to be ready for use. But when I actually take the photo the flash doesn't flash. Any ideas?
    Champion:
    Scholar:
  • 216 Answers
Try to short out the flash and see if the flash flashes.
Remove flash from camera.
New or fresh bateries installed.
Get wire with insulation and remove both end bare to 1/4"
Turn on flash and wait until light turn green or ready.
Touch one lead to center of flash pin, touch other end to the outside(rail on the side) pin.
Flash should discharges.
atdlee@netzero.com
Posted on Aug 02, 2008
What type of Batteries does the Minolta Maxxum 7000i take?
6 Volt Lithium photo battery
www.ebatts.com/minolta_maxxum-7000i_digital-camera_batteries_part_b-151.aspx
Oct 16, 2012 | Konica Minolta Black Minolta Maxxum 7000i...
When I install the battery in my 7000i it makes a noise the screen has two lines appear but the camera will not turn on.
I had a similar problem with my 8000i. Parts are getting scarce for these older Maxxums, but you can still get it repaired. Unless you are emotionally attached to this 7000i consider replacing it. You should be able to find another on Ebay for a decent price. You might also consider the subsequent generations which offer better AF performance. The 650xi, 700xi and 800xi are all good cameras and available on Ebay. Lighter versions like the Maxxum 70 and the XTsi are also available. The last of the film Maxxums was the single digit 7. It is generally regarded as the best of the Maxxum series, but still sells on Ebay over 150.00 typically. These subsequent models will take all your maxxum lenses and flashes. These newer models offer many other features and often less weight to carry around.
lightspiritphotography.com
Nov 12, 2009 | Minolta Maxxum 7000 35mm SLR Camera
What year was the Minolta Maxxum 7000, serial number 16043985? Thanks, Karla
I do not know for certain. You might find that answer on the Yahoo Minolta groups.
The Maxxum 7000 was introduced to the US market in 1985. Sold as the Alpha 7000 in Japan and Dynax elsewhere, it was replaced by the 7000i in a couple years. Then the 700, the 700xi, the 700si, the 70 and the 7 was the last film based 7 series. There
They also made 8000i, 800si, etc. The 9 series was the Minolta Professional cameras and they had the toughest bodies, weatherproofing, higher shutter speeds, and more.
Later models introduced better autofocus, better exposure options, wireless flash, faster film advance, etc.
Nov 10, 2009 | Minolta Maxxum 7000 35mm SLR Camera
I have a Maxxum 7000i 35mm camera and in the display there is the word Help flashing what does this mean This happend after i tried a differnt lens, the lens opened than closed The lens that i tried was a...
Konica lenses do not fit Minolta cameras. I think you messed something up.
Minolta MC and MD lenses worked on the older manual focus Minolta bodies. They will also work on the Phoenix and Seagull clones of the old Minolta bodies.
The Konica lens should only ever be mounted on a Konica camera.
Your 7000i is now a Minolta paperweight. You need to send your 7000i for repair or replace it.
You could also look on Ebay for another Maxxum body to use your lenses designed for the Minolta A mount. As a rule, camera lenses are not interchangeable. You can use any Maxxum lens on any Maxxum body as a rule, but Minolta changed their flash shoe after the original 7000 series. Flashes that work with your 7000i will work with any subsequent Maxxum.
Oct 25, 2009 | Minolta Maxxum 7000 35mm SLR Camera
BATTERY COMPARTMENT& PUSH TO SHOOT BUTTON EATEN AWAY BY BATTERIUES GONE BAD
Maxxum 7000 are cheap these days. Get a used one on Ebay and keep yours for parts.
Better yet, get a 7000i, 700xi, 650xi, 800xi or a Maxxum 5, 7, or 9. Why? More focus points, faster AF, more options, same lenses. But you will need to replace your flash.
BTW...remove batteries when you aren't put it away.
Oct 04, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Bad Minolta Maxxum lens?
Oddly enough, the camera and lens are working just fine now - or at least they appear to be. I'll shoot some more when I have good lighting and 1-hour them tomorrow for the results.
Nov 24, 2008 | Konica Minolta Maxxum QTsi with 35-80 lens...
The flash unit for my Minolta Maxxum 7000i turns on but no "whine" of a capacitor charging. It goes back off on its on after a few seconds. Pushing the test button has no effect. Is this an owner...
Hello
Flash guns are not normally that easy to repair, and most of the guns for the Minolta 7000i are getting pretty old and parts are becoming scarce.
The first thing to check is that the batteries are good, make sure you are using rechargeable or some of the new high power AA batteries, cheap bulk buy batteries are no good for flashguns.
Second, make sure the battery contacts are nice and clean.
If you still have problems post again but with the model of the flashgun as well.
Oct 03, 2008 | Cameras
I have a Minolta Maxxum 7000i with a 3200i flash unit. The flash is not working. The batteries are fresh and inserted properly. The control lights on the flash unit light up when I am ready to shoot but...
Can you fire the flash manually? there might be a red button on the flash for you to do this. If you can operate the flash manually, then take an eraser and clean the contacts on both the camera, and flash, then take a Q tip, and a little rubbing alcohol, and whipe down the contacts AND the two contact springs located under the two side rails on the top of the hot shoe. I've had the same problem before. Dirt grease, and grime get in there and prevent full electrical contact.
Jul 27, 2008 | Cameras
Minolta Maxxum 7000
ONline manual from Minolta says "winding motor problem", try removing battery and reinstalling. It didn't work for me though.
Jul 13, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Cameras Logo
690 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
