Question about Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Power failure We recently installed the refrigerator. It is plugged into a receptacle that is on the load side of a GFCI receptacle. After a few days it started tripping the circuit and we would have to reset the receptacle. This usually happened at night. We replaced the GFCI receptacle but it still happens. Our old refrigerator was plugged into this receptacle for 18 years with no problem.
    Guru:
  • 351 Answers
Hello .. I would try plugging the fridge into a normal receptacle and see if it is OK with that .. If the fridge is not compatable with the GFCI. then you might think of replacing the receptacle, If it is behind the fridge then there is no problem, If this is one of your counter receptacles . then you should think about rewiring the circuit and locating an unprotected recaptacle behind the fridge just for its use.
Posted on May 04, 2010
  • 91 Answers
Code actually calls for the refrigerator to be on a separate circuit for this reason. you may have a refrgerator that may have a higher voltage spike at compressor start up and that is causing the trip. You can try upgrading your GFCI to a 20amp (most are 15amp). Although you may have to replace with a standard outlet if the problem does not subside.
Posted on Aug 26, 2009
Why does it trip breaker occasionally?
If there is more that only the refrigerator on the same circuit they will need to be removed. If there is a GFCI receptacle where the fridge is plugged in the GFCI Receptacle needs to be replaced with a typical receptacle because a GFCI is too sensitive for an appliance like a refrigerator. The windings in the refrigerator compressor could be breaking down or the breaker in the breaker box is just too weak for your refrigerator
APPLIANCE 911
Dec 05, 2015 | Admiral Refrigerators
Tip
Wiring a GFIC alternative.
When wiring a GFCI (Ground Fault Interrupter Circuit) receptacle you would normally connect the wire coming from the service panel or the hot wire to the LINE connection at the GFCI and then connect the other receptacles you wish to protect to the LOAD side on the GFCI. But let's say you have installed a GFCI in a garage circuit and want to run a wire to the garage door opener from that circuit without the garage door opener receptacle being protected by the GFCI but still want all other receptacles protected. Reason being that the garage door opener will trip the GFCI more often than not. You may also want to have a receptacle for a freezer in the garage. You do not want that freezer protected by the GFCI circuit as it may trip without your knowledge and cause all the food to spoil. Warning: Only install a single plug receptacle for the freezer and not a double plug receptacle. That way only one thing, the freezer, can be plugged into this receptacle as it is not GFCI protected. The way to avoid the breaker tripping is to connect the garage door opener & freezer receptacle to the LINE side of the GFCI. This way it is not protected by the GFCI and there is no danger of that receptacle loosing power due to a tripped breaker on the GFCI. When the GFCI trips power will still be available at any receptacle connected on the line side. On any GFCI you can connect two sets of wires to the LINE side. If you have more than two you will have to connect those together under a wire nut and then use a jumper wire to connect to the LINE on the GFCI. Look at the photo and you will see the 2 sets of holes to connect at the LINE side (Bottom) on the back of the GFCI receptacle. There are also 2 sets of holes to connect on the LOAD side (Upper). Of course you would use a wire nut and jumper to connect all the ground wires.8dd2149.png
on Dec 13, 2009 | Electrical Supplies
I have an LG refrigerator freezer model number GR-S392GC that keeps tripping the power box. I plugged the fridge into another source but it kept shorting out. I isolated the issue to the harness wire...
the concept for a DRYER is the same for a washer or fridge in some instances
The key to this problem is what the amp draw of the washer is when the house breaker trips.
To narrow this problem down, there are three places that could be causing the ( outlet) GFCI to trip, a malfunction in the washing machine, a problem with the downstream wiring (aka load side of the GFCI-other items connected on same circuit), or the GFCI outlet itself. If there isn't anything downstream, then plugging the washing machine into another GFCI outlet, or simply swapping out the outlet for a known good GFCI outlet, will identify if the outlet itself is faulty.
If the outlet trips when the washing machine isn't running and isn't even plugged in, then there's a fault in the wiring on the load side of the GFCI outlet.
If the issue is neither of the above, then running the washing machine and monitoring to see which step is occurring when the trip happens will isolate what part of the washing machine may be leaking current to a ground. It could be a certain water level, a motor being engaged, a transition step in the controller, etc
Beware some techs believe that most Washing machines or any other motor should not be on a GFCI! Should be a dedicated single receptacle. If there are other outlets on the washer GFCI, replace that GFCI with a single receptacle and put the GFCI on the next jump in order to protect other outlets.
Another item to check is ur lid switch which may have gotten moister inside and created a short_ or broken open and the rubber seal dried out over time, and the switch assembly will be exposed. water can splash onto the assembly, somehow causing the GFCI to trip. In any event, if you are having trouble with your washing machine stopping mid-cycle for any reason, test and replacing the lid switchis probably a worthwhile idea, as it is cheap and easy to replace.
Mar 28, 2015 | LG Refrigerators
Hoover Refrigerator Model B38tf. Causes earth leakage circuit breaker to trip. Has just started to occur in last week. What is likely cause and what rectification can be applied?
If you're referring to a GFCI (Ground Fault Circuit Interrupter) breaker tripping, a refrigerator should not be plugged into a GFCI circuit because of the sudden load it requires to start the compressor, etc when it kicks on. The GFCI breakers are meant to be very sensitive, and over time the sudden energy demands caused by a refrigerator can weaken the breaker's threshold, causing them to trip often. Try connecting the refrigerator to another circuit that isn't on a GFCI breaker. If there are no other circuits nearby, you may wish to replace the GFCI breaker with a standard breaker, and replace the receptacles with GFCI receptacles, except of course, the one the refrigerator is plugged into. Be sure and consult and use a qualified electrician for this. Hope this helps..
Oct 29, 2013 | Refrigerators
HI, I have a whirlpool refridgerator model # ed22gw, It worked fine then 3 days ago it triped the gfci I unplugged and tried different outlets with no other load on them and it would still trip the...
Refrigerators should not be run on gfci plugs .As they age , they will pull slightly more amps . Also , gfci plugs will weaken even though no previous problem with them . If you have a gfci plug behind the refrig , replace it with a normal type plug .
Mar 31, 2011 | Refrigerators
I bought a new GE 20 amp GFCI circuit breaker and installed it to a new outdoor curcuit with two separate outlets. everything seems to work fine - polarities ok etc. connnected the white gfci line to the...
You can buy an inexpensive GFCI tester for as little as $10-$12. A better one with several mv settings will cost you a bit more. This way you can test this circuit and even GFCI receptacles. Then you'll know for sure if your breaker is working.
Nov 14, 2010 | General Electric 20 Amp, 1 Pole Thick Type...
Whirlpool refrigerator trips gfci outlet
Yes ,, if the fridge outlet is behind the fridge and therefore not accessible for use by counter top appliances .. then yes change it to a regular outlet.
The cause is probably the compressor, getting a bit noisy..electrical noise I mean.
Feb 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator keeps throwing receptacle switch plate
I'm assuming this is on a GFCI outlet? May be a problem with the outlet rather than the Fridge. I had an outlet that would do the same thing when it encountered loads. I replaced it and everything was fine.
May 23, 2009 | Kenmore Refrigerators
Doesn't operate when plugged in
The test and reset is a GFCI device. They do go bad sometimes. The solution is to cut that plug end off, and install a regular cord end that is capable of handling the rated amperage of the unit. ( I assume this is 120-volt unit)
You should replace the wall receptacle with a GFCI receptacle where the unit is plugged in to prevent electrocution
May 02, 2009 | Heating & Cooling
Gfci trips.it protects 4 receptacles downstram from it.If I disconnect from downstream receptacles it will not trip.This is on kitchen counter-top circuit.All wiring and devices are only 6 months...
There can be a few different reason for a trip. 1. Amps exceed rating off GFCI ie 15 amp receptacle can only handle up to 15 amp anymore and it will trip. 2. miss wiring; neutral must be on white screws hot on black and ground, green also inlet power (line) must be on bottom screws, outlet or load must be on top 3, a short, whether it be neutral or hot touching something in the box. Frayed wire, wire next to side of interior of box or yes moisture. Also a short in an appliance aven a new one can cause a trip. Remember if the refrigerator is on this same circuit, which is not a good idea it can cause a trip. At start up the fridge can spike to near 15 amps and a voltage spike can cause a gfci to trip. There are 20amp GFCI's so that can be your last resort, if all else fails.
Jan 17, 2009 | Sharp 13K-M100 13" TV
Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
229 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
